Topic: HELP with Infrared emitter + sensor problems (Read 19851 times) previous topic - next topic
njs707
I just realized I worded my last post poorly, when I say " light was on "... I did not mean IR led, I meant incandescent light only, just to test how much the values change when someone would turn a light switch on or off.  The room was completely dark, then I switch an incandescent light on, then off.  Not ir led, sorry for the confusion if there was any.
njs707
Man this stuff is frustrating.
Ok, I want to set up an IR receiver that will calibrate to the environment... ( check to see how much ir light is in the environment) and then set that as the new zero level, so if the other IR receiver receives a little more ir light than that new zero ( threshold), then an led will turn on.  To test this, I simply have 2 of the exact same infrared receivers hooked up the exact same way with the exact same resistors to analog 0 and 5 on the arduino.  The 2 receivers are not more than 1 inch apart and are at the same level vertically.  The problem is they are receiving vastly different ir values?? why?
here is the code and the resulting values.....
int Calibration;
int Receiver;
  int Receiver = analogRead(A5);
  int Calibration = analogRead(A0);
  Serial.println("Calibration Input = ");
  Serial.println(Calibration);
  Serial.println("Receiver Input = ");
  Serial.println(Receiver);
here are the values..
Calibration Input =
133
Receiver Input =
359
Calibration Input =
141
Receiver Input =
377...
HOW COULD THEY BE SO DIFFERENT?
