Topic: Problems with using the ArduinoUno with the Rainbowduino (Read 2710 times) previous topic - next topic
Bronko
hey guys, i´m a beginner searching for some answers to my stupid questions XD
Please be appreciative, as i sad i´m new at all this, but I need to do this for school...and sorry for my bad englisch^^
I´d like to use my rainbowduino with my ArduinoUno...and maybe with the mtXcontrol...
I tried to follow the instructions on this page:
https://github.com/rngtng/mtXcontrol/blob/master/README.markdown
So I
-installed arduino
-Choosed the right Board (Arduino UNo) and the right SerialPort (COM5)
-Uploaded blank sketch
-connected the 5Wires as shown on the picture http://www.rngtng.com/2009/06/25/rainbowduino-here-it-is-and-how-to-program-it/
But than:
I loaded the firmware.pde sketch on the Arduino IDE and tried to upload it, but than he shows me the massage: `Rainbowduino`does not name a type while marking the line:
Rainbowduino rainbow = Rainbowduino();  //max 10 Frames
I guess it´s because I didn´t chenged the processor type to 168, because my  ArduinoUno has an 328...
Or did i do smt. diffrent totally wrong? :P
-If it´s the processor type problem...how do I change the processor type?
ortsac
I've had numerous disappointments before trying to make mtXcontrol work and i found this  posted someplace else and I used it successfully for the mtXcontrol sketch:
The new version of mtXcontrol and corresponding firmware run on rainbowduino may not work, so you may try this (I've tested ok):
1. Download the mtXcontrol_windows.zip and Rainbow_mtX.zip here:
http://code.google.com/p/rainbowduino/downloads/list
2. Connect your rainbowduino in proper way to your computer that you can program it through COM.(Remember to change the port to use COM1)...this is very important!!! this version of mtXcontrol was hardcoded for COM1
3. Unzip Rainbow_mtX.zip to your arduino code directory (no need in the arduino library), open Rainbow_mtX.pde by arduino and program it to your rainbowduino.(If it compiles failed, there may be another rainbowduino class in your arduino library, so back up and remove it).
After programmed, the rainbow Matrix will be all in white.
4. Unzip mtXcontrol_windows.zip and run mtXcontrol.exe.
If there's error reported, like "not found javaw.exe", then you need to add the java path to your environment variable (On my computer is: D:\Program Files\arduino-0018\java\bin ). Am I understood?
If there's no error reported, just enjoy controlling your rainbow!
peterkalt
hi ortsac,
it does not work at my ArduinoUno with the Rainbowduino. my steps:
2. I connect my Rainbowduino with my ArduinoUno to my computer, like this http://www.rngtng.com/2009/06/25/rainbowduino-here-it-is-and-how-to-program-it/
   the Rainbowduino the lights as the image (COM1)
3. I open Rainbow_mtX.pde by arduino-0022
4. if I want to upload Rainbow_mtX.pde, I get this error message:
Binary sketch size: 3136 bytes (of a 32256 byte maximum)
all the lights go out for 1s
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x00
avrdude: stk500_initialize(): (a) protocol error, expect=0x14, resp=0x00
avrdude: initialization failed, rc=-1
         Double check connections and try again, or use -F to override
         this check.
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x51
I've tried to change the board in arduino-0022, but without success.
do you have a solution? Thanks. PK
