Topic: RBGLed Library (Read 2855 times) previous topic - next topic
citrus
This is my first arduino library.. It's just a simple RBG led controller with a few basic functions..
The library is available on github:
   http://github.com/citrus/RGBLed
Here's the public API:
   RGBLed(int red, int green, int blue);
   void on(int color);
   void mix(int color1, int color2);
   void off();
   void red();
   void green();
   void blue();
   void yellow();
   void purple();
   void turquoise();
   void animate();
   void next();
   int  mode;
I've included an example sketch that has a button for toggling the mode and a potentiometer for controlling the animation speed. The LED starts off so don't forget to press the 'next' button!
* RGBLed Library Example
* Copyright 2010 Spencer Steffen, spencer<at>citrusme<dot>com / http://citrusme.com
#include <RGBLed.h>
#define BTN_PIN A4
#define POT_PIN A5
int _btnDown;
int _value;
int _delay;
// Initialize the LED with pwm pins.
RGBLed led = RGBLed(9,10,11);
 pinMode(BTN_PIN, INPUT);
 pinMode(POT_PIN, INPUT);
 Serial.print("MODE: ");
 Serial.println(led.mode);
 _btnDown = digitalRead(BTN_PIN);
 if (_btnDown == 1) {
   led.next();
   delay(250);
   return;
 if (led.mode < ANIMATE) return;
 led.animate();
 _value = analogRead(POT_PIN);
 _delay = map(_value, 0, 1023, 2, 99);
 delay(_delay);
Here's how my board is setup for the example sketch.
Check it out and post your thoughts.. Thanks!
-Spencer
http://citrusme.com/
Cybot_Rules
i love the concept, mayb you could make a function so you can say wether it drives the outputs high or low (dependign if its anode or cathode commen) and i would really love a function to send a Hue value to it, once you mkae it easy to send the hue or RGB value to it im definatly over the moon, im building a custom xbox case that is full of rgb leds and im planing to have the colour fade across the xbox, so if i could use this to send the hue to like 10 rgb leds one after another i would be over the moon :D
Thanks, and keep up the good work.
citrus
Glad you like it and might find it useful! If I find some time to revisit this i'll incorporate your feature requests.
-Spencer
32teeth
#3
Oct 27, 2010, 08:43 pm Last Edit: Oct 27, 2010, 08:44 pm by 32teeth Reason: 1
On our project:
Sparky Jr. RGB LED
controller for video mages fightstick light up we use a jumper connected to a pin.
by default the code is for common cathode. if the jumper is plugged in. the code switches to common anode.
#define cathode LOW
#define anode HIGH
int active = HIGH;
int signal = LOW;
int on = cathode;
int off = anode;
set jumper pin and pull down (set HIGH as default)
test for active common anode jumper pin
reset variables accordingly for commone anode
pinMode(jumper, INPUT);
digitalWrite(jumper, HIGH);
if(digitalRead(jumper) == LOW){on = anode;off = cathode;active = LOW;signal = HIGH;}
