Topic: Arduino as Capacitive Sensor (Read 63271 times) previous topic - next topic
paulb
Feb 10, 2007, 03:57 am Last Edit: Feb 10, 2007, 04:28 am by paulb Reason: 1
Some experiments with the Arduino as a capacitive sensor. All it requires is a 10 M resistor and a piece of wire. I was able to sense a hand about four inches from my 1.5" sq aluminum foil sensor.
Included are some machine code and port manipulation and an easy smoothing filter.
// CapSense.pde
// Paul Badger 2007
// Fun with capacitive sensing and some machine code - for the Arduino (or Wiring Boards).
// Note that the machine code is based on Arduino Board and will probably require some changes for Wiring Board
// This works with a high value (1-10M) resistor between an output pin and an input pin.
// When the output pin changes it changes the state of the input pin in a time constant determined by R * C
// where R is the resistor and C is the capacitance of the pin plus any capacitance present at the sensor.
// It is possible when using this setup to see some variation in capacitance when one's hand is 3 to 4 inches from the sensors
// Try experimenting with larger sensors. Lower values of R will probably yield higher reliability.
// Use 1 M resistor (or less maybe) for absolute touch to activate.
// With a 10 M resistor the sensor will start to respond 1-2 inches away
// Setup
// Connect a 10M resistor between pins 8 and 9 on the Arduino Board
// Connect a small piece of alluminum or copper foil to a short wire and also connect it to pin 9
// When using this in an installation or device it's going to be important to use shielded cable if the wire between the sensor is
// more than a few inches long, or it runs by anything that is not supposed to be sensed.
// Calibration is also probably going to be an issue.
// Instead of "hard wiring" threshold values - store the "non touched" values in a variable on startup - and then compare.
// If your sensed object is many feet from the Arduino Board you're probably going to be better off using the Quantum cap sensors.
// Machine code and Port stuff from a forum post by ARP  http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1169088394/0#0
int  i;
unsigned int x, y;
float accum, fout, fval = .07;    // these are variables for a simple low-pass (smoothing) filter - fval of 1 = no filter - .001 = max filter
 DDRB=B101;     // DDR is the pin direction register - governs inputs and outputs- 1's are outputs
 // Arduino pin 8 output, pin 9 input, pin 10 output for "guard pin"
 //  preceding line is equivalent to three lines below
 //  pinMode(8, OUTPUT);     // output pin
 //  pinMode(9, INPUT);      // input pin
 //  pinMode(10, OUTPUT);    // guard pin
 digitalWrite(10, LOW);  //could also be HIGH - don't use this pin for changing output though
 y = 0;        // clear out variables
 x = 0;
 for (i=0; i < 4 ; i++ ){       // do it four times to build up an average - not really neccessary but takes out some jitter
   // LOW-to-HIGH transition
   PORTB = PORTB | 1;                    // Same as line below -  shows programmer chops but doesn't really buy any more speed
   // digitalWrite(8, HIGH);
   // output pin is PortB0 (Arduino 8), sensor pin is PortB1 (Arduinio 9)
   while ((PINB & B10) != B10 ) {        // while the sense pin is not high
     //  while (digitalRead(9) != 1)     // same as above port manipulation above - only 20 times slower!
     x++;
   delay(1);
   //  HIGH-to-LOW transition
   PORTB = PORTB & 0xFE;                // Same as line below - these shows programmer chops but doesn't really buy any more speed
   //digitalWrite(8, LOW);
   while((PINB & B10) != 0 ){            // while pin is not low  -- same as below only 20 times faster
     // while(digitalRead(9) != 0 )      // same as above port manipulation - only 20 times slower!
     y++;
   delay(1);
 fout =  (fval * (float)x) + ((1-fval) * accum);  // Easy smoothing filter "fval" determines amount of new data in fout
 accum = fout;
 Serial.print((long)x, DEC);    // raw data - Low to High
 Serial.print( "   ");
 Serial.print((long)y, DEC);    // raw data - High to Low
 Serial.print( "   ");
 Serial.println( (long)fout, DEC); // Smoothed Low to High
TM
#1
Sep 16, 2007, 07:39 pm Last Edit: Sep 16, 2007, 07:42 pm by TM Reason: 1
hi, I tried to make your code work but no chance  :'(
I am using a 3.3M resistor and I don't have a clue  :-/
Here is a picture:
The white cable has a piece of copper ( 4x3cm ) at the other end.
I am new to arduino so you might find me quite silly. I was planning on using a qt but if your technique works it's better.
Thank you for your time and contribution to arduino.
TM
Hi again, I am really confused  :-?
I just changed the cable position. I moved the cable connected to pin9  and the white cable on the line above. Then I linked the 2 lines with the resistor and now It works !!!!!
I put a picture for the newbies like me ( and documentation ) :)
I am sorry for all this, hope that at least it will help others. It must be really silly the way I have done it in the first place. I really need to learn the basics.
Great code by the way, thanks for that !!!
TM
#3
Sep 16, 2007, 08:24 pm Last Edit: Sep 16, 2007, 08:29 pm by TM Reason: 1
I really enjoying your technique !!! It's brilliant !!!  :D
It's going to work perfectly for our project. If you are in the UK and not far from Brighton at the beginning of November, It would be a pleasure to see you at the private view. Here is a link to the website for more info : http://www.sonicbody.co.uk
Thanks again.
Digger450
If you're curious, the reason it didn't work in your first picture is because you basically bypassed the resistor and your white wire and simply had 8 and 9 connected to each other.
TM
Hi, I've been thinking about what you said. Is it because the two legs of the resistor are on the same line so the two legs are connected together instead of having the two legs separated?
Anyway,Thanks for your previous explanation.
Digger450
That is correct.  Good luck with your project  :)
madskoser
Hi
I've been trying to do this but I can't get it to work.. Wired everything up as on the photo and then ran the program but nothing happened. Can you give a description on how to do this currectly since I apperently do something wrong.
thanx
//Mads
TM
Hi, did you find what was wrong ?
I am not a expert so I can't really help.
Are you following the second picture?
Maybe your resistor is not the good one, if it's to low it won't do anything.
Maybe your sensor is wrong. Try with copper or aluminium foil ( like in the one in your kitchen ).
Also, I used the commented part of it instead of the 'PORTB' thing.
Here is my code, it's really a quick one just for testing. The 'activation' thing with untouched and store as to be better. I am wondering between the difference between two person or a same person after a different day. It seems that somedays I have more electricity in my body then other days.
I haven't test with the original code again as I am looking into the multiplexer now.
// CapSense.pde
// Paul Badger 2007
int  i;
unsigned int x, y;
int ledPin = 5;   // select the pin for the LED
float nonTouched, store = 0;
 //DDRB=B101;     // DDR is the pin direction register - governs inputs and outputs- 1's are outputs
 pinMode(5, OUTPUT);
 analogWrite(ledPin,255);
 delay(10);
 analogWrite(ledPin,0);
 x = 0;
   //PORTB = PORTB | 1;                    // Same as line below -  shows programmer chops but doesn't really buy any more speed
   //while ((PINB & B10) != B10 ) {        // while the sense pin is not high
   while (digitalRead(9) != 1) {    // same as above port manipulation above - only 20 times slower!
     x++;
   delay(1);
   // PORTB = PORTB & 0xFE;                // Same as line below - these shows programmer chops but doesn't really buy any more speed
   //while((PINB & B10) != 0 ){            // while pin is not low  -- same as below only 20 times faster
   while(digitalRead(9) != 0 ) {     // same as above port manipulation - only 20 times slower!
     y++;
   delay(1);
 accum = fout;
 store++;
 if (store<50) {
   nonTouched = fout;
 if (store>50){
   store = 50;
 Serial.print( "   ");
 Serial.print( "   ");
 Serial.print( (long)fout, DEC); // Smoothed Low to High
 Serial.print( "   ");
 Serial.println( (long)nonTouched, DEC); // Smoothed Low to High
 if (fout>nonTouched+3){
 else{
Apart from that can't really help. Good luck
madskoser
Looks cool.. :-)
And thanx for the help so far.. But I have one problem and that is that the file is to big to fit on the Arduino board. Why can this be??
I will tell you more about the process of the project later...
Thanx
//Mads
westfw
The floating point used will presumably add quite a bit of code to a sketch...
madskoser
So what can I do about  that? I'm really newbie to this.. Learning as I go..
Thanx for your time and help
TM
#12
Sep 27, 2007, 10:22 am Last Edit: Sep 27, 2007, 10:24 am by TM Reason: 1
Strange, maybe you have a older version of the arduino. I looked at mine and I still have plenty of space left after uploading the code. Weird.
It could the float variable like westfw said but that I would find this strange. That would mean you are very very limited then. Try without the two variable I added, so at least you could see something in the Serial Monitor if that's the problem. It's the button next to the Upload one. Upload your code, when done click this button and wait a few second.
// CapSense.pde
// Paul Badger 2007
int  i;
unsigned int x, y;
 pinMode(5, OUTPUT);
 delay(10);
 x = 0;
     x++;
   delay(1);
     y++;
   delay(1);
 accum = fout;
 Serial.print( "   ");
 Serial.print( "   ");
Good Luck.
madskoser
I fixed the problem with size.. Was working in an old version of Arduino - so now it's no prob.
But I don't seem to get any signal, numbers or anything out..
What could be the problem?
Thanx for your time
TM
I think you have wired correctly. Do it like on the second picture. On yours, the pin8 and 9pin are not connected as they are on 2 seperated parts. The 2 two parts are not connected. See what I mean?
