Topic: Strange Brushless ESC / Arduino issue - some ESCs work and some do not. (Read 2100 times) previous topic - next topic
kashif
I have done a lot of Googling and but couldn't get solution of my strange problem.
After going thru forums and some hit-n-trial, I managed to put together the following code. The code works perfectly fine on one of my brushless ESCs but doesn't on other two.
I have checked, all of the ESCs are in working order. Here is the stat after several tweakings of "delay" function timing and "arming" timing.
ESC 1 (Dualsky 25Amp) = Works perfect
ESC 2 (Freewing 30Amp) = Doesn't even arm
ESC 3 (unbranded) = Arms after setting the "delay" in arm() to 2000 (I can hear 3 beeps for 3S battery) but stays quiet afterwards.
Code: [Select]
#include <Servo.h>
Servo myservo;
unsigned long lastPulse;
void arm(){
setSpeed(0);
delay (1000);
void setSpeed(int speed){
int angle = map(speed, 0, 100, 0, 180);
myservo.write(angle);
myservo.attach(5);
arm();
setSpeed(0);
delay(750);
setSpeed(5);
delay(750);
setSpeed(10);
lastPulse = millis();
   if (millis() - lastPulse >= 750)
      setSpeed(15);
Mastino
I am not expert but you shouldn't arm ESC with 0. I had the same problem.. So what you need to do:
1: Remove ESC
2: Disconnect motor (important)
3: Turn transmitter on
4: Turn ESC switch on
5: Adjust the "neutral" trimpot until the LED goes out.
6: Pull Trigger to full throttle, and adjust the "proportion" trimpot until the LED *just* turns to maximum brightness. LED should turn red when you push the trigger. (reverse)
7: Re-install ESC, Re-connect motor and have fun.
And when you will arm the ESC with arduino it should be like this:
myservo.write(90); //position 90 degrees
myservo.write(30); //position 30 degrees
Hope it helps!
sirbow2
http://dduino.blogspot.com all my Arduino/electronic projects!!!
{NEW} Getting Started, Learning, Reference + FAQ PDF!!:
[url]http://ar
DuaneB
As sirbow2 says above, it might be the throttle range.
You often need to program an ESC when it is first used in a new model to set the max and min throttle range. If you have not done this, is it pot luck whether your ESCs will arm. From what I can see, your result so far suggest pot luck is at work.
Do you have access to an RC transmitter and receiver that you can use for the initial programming ?
Do you have the manuals for the ESCs that describe the initial programming process ?
Duane B
rcarduino.blogspot.com
Read this
http://rcarduino.blogspot.com/2012/04/servo-problems-with-arduino-part-1.html
then watch this
http://rcarduino.blogspot.com/2012/04/servo-problems-part-2-demonstration.html
Rcarduino.blogspot.com
