Topic: Has anybody seen these nice "doughnuts" for easy soldering? (Read 11629 times) previous topic - next topic
bibre
Check these out, guys:
SOLDER, RINGS,FOR THROUGH HOLE,50 PCS,GAUGE .020
https://www.jameco.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=10001&langId=-1&catalogId=10001&productId=2117114
I know how to solder, but I think I'll order some of these just to try them. They seem like a very good alternative for those who are learning how to solder or who are still "afraid" of trying.
I hope this is of help.
Steen
that's really nice ö but very expensive, €6 for only 50 pieces seems a lot to me..
but it is really good to learn or to make it easier, i might get one set too, just to try it out :)
AWOL
That looks like a really expensive solution looking for a non-existent problem
bibre
#3
Apr 05, 2012, 09:09 pm Last Edit: Apr 05, 2012, 09:12 pm by bibre Reason: 1
I agree, EXPENSIVE they are! But when you have never soldered an IC socket or chip, I guess that's a jumpstart way to learn how to do it. And then forget about these expensive tiny doughnuts.   ;)
cmiyc
It seems like these would teach bad-soldering habits more than it would help to teach how to solder.
The solder should not come in contact with the iron's tip, which is what these things look like they are intended to do...
Capacitor Expert By Day, Enginerd by night.  ||  Personal Blog: www.baldengineer.com  || Electronics Tutorials for Beginners:  www.addohms.com
dean8020
The data sheet does indeed show you are supposed to touch the solder with the iron.
Also it shows all its examples on a board with very large plated thru holes, that the solder 'fills up'.
Would be interesting to see how well they perform on veroboard or something, as the rings are much bigger than the component legs.
And as everyone seems to be saying, the price  :smiley-eek-blue: That's more than a bobbin of solder, which will do hundreds if not thousands of legs...
cmiyc
Products like this are why I like to say:  "There is no such thing as a stupid product.  Only the people who buy it."
dean8020
#7
Apr 05, 2012, 11:06 pm Last Edit: Apr 05, 2012, 11:10 pm by dean8020 Reason: 1
The large holed, plated thru board in the video is a 'SchmartBoard' by the same company, also supposed to make soldering easy,
They offer a free sample on their website, I guess it's restricted to the US though
http://www.schmartboard.com/index.asp?page=schmartland_samples
Maybe some people could give it a go, we might be missing the best thing since sliced bread (in the circuit prototyping world).
Edit:
It appears I have confused/misled myself,
The free sample may be for their 'Hand soldering surface mount IC' board, which genuinely look quite interesting.
http://www.schmartboard.com/schmartboard_dc_ez_instructions.pdf
MarkT
They are also lead/tin solder rather than lead-free.
It must be soul-destroying work threading them all onto the leads of a DIP package only to sneeze and have them all scatter to the floor!
Osgeld
#9
Apr 06, 2012, 02:23 am Last Edit: Apr 06, 2012, 06:13 am by Osgeld Reason: 1
geez bend a pin or 2  $)
though its good to see jameco finally got with it and offers USPS shipping now, ... it used to piss me off so bad to order one little piddle squat item (like a tip for my iron) and see the bill jump up darn near 10 bucks for UPS or fedex ground, its why I have been using the same tip for almost 3 years with lots of care ... though its getting really close to time for a new one
nevermind they managed to cheese me off, now if you just want a 4$ soldering iron tip they charge you 5 extra bucks to meet their minimum order requirement ... and of course their selection is quite ... um ... thin so its even harder to get stuff, that cost more, at jameco
http://arduino.cc/forum/index.php?action=unread;boards=2,3,4,5,67,6,7,8,9,10,11,66,12,13,15,14,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,86,87,89,1;ALL
westfw
Quote
Hmm.  That's not what I was taught.  "solder, tip, wire, and pad should all intersect" (more or less.)
I think AWOL's comment was perfect, though.  Soldering TH really isn't that hard...
terryking228
Quote
The point is the two materials in the joint need to be heated to soldering temperature before the final correct amount of solder is applied. This may not work well with a clean soldering iron tip and the two parts to be soldered because there is mostly small-point contact.
Adding a very small amount of solder/flux right at the junction of the iron tip and the two parts right at the beginning often really improves the heat transfer between the 3 surfaces. When the solder suddenly flows it's your visual indicator that the temperature is correct.
THEN apply the correct final amount of solder and it flows fast and you're done.
I realized years ago that I had evolved to doing that and I teach people to solder that way, usually with good results.
Regards, Terry King terry@yourduino.com  - Check great prices, devices and Arduino-related boards at http://YourDuino.com
HOW-TO: http://ArduinoInfo.Info
terryking228
Other Subject:
Prototyping Boards that solder well:
Some examples were given above.
I can find lots of low-cost protoboards, both single and double-sided, but they do NOT have plated-through holes.
What are YOUR favorites (links, please) from various sources. Any on Ebay??
I want to add good prototyping support to http://YourDuino.com
DISCLAIMER: Mentioned .. my own shop...
dean8020
Are you looking for our favorite prototyping boards,
Or our favorite plated-through hole prototyping boards?
terryking228
Quote
Are you looking for our favorite prototyping boards, Or our favorite plated-through hole prototyping boards?
Sorry! I wasn't specific enough..
Mainly plated-through proto boards, including those that may have surface-mount sections.  I am looking at boards that could be used by serious experimenters/developers and support using sockets and connectors that would have secure connections to both sides.
That said, if someone really likes a board without plated-through and finds it productive and cost-effective I'd like see that too!
I may have some boards built.. if anyone has Eagle/other files for a board they like, I'd like to see that too  :)
Thanks!
