Topic: Sonar and MIDI Mapping (Read 5508 times) previous topic - next topic
dingledow
I'm not sure what you mean.  This is all the code I have:
Code: [Select]
//Feel free to use this code.
//Please be respectful by acknowledging the author in the code if you use or modify it.
//Author: Bruce Allen
//Date: 23/07/09
//Digital pin 7 for reading in the pulse width from the MaxSonar device.
//This variable is a constant because the pin will not change throughout execution of this code.
const int pwPin = 7;
//variables needed to store values
byte note = 0;            // The MIDI note value to be played
long pulse;
  //This opens up a serial connection to shoot the results back to the PC console
  Serial.begin(31250);
  pinMode(pwPin, INPUT);
    //Used to read in the pulse that is being sent by the MaxSonar device.
  //Pulse Width representation with a scale factor of 147 uS (microseconds) per Inch.
  pulse = pulseIn(pwPin, HIGH);
  Serial.println(pulse);
  mappedPulse = map(pulse, 827, 15000, 0, 127);  //map value to 0-127
//  plays a MIDI note.  Doesn't check to see that
//  cmd is greater than 127, or that data values are  less than 127:
void noteOn(byte cmd, byte data1, byte data2) {
   Serial.write( byte(cmd) );
   Serial.write( byte(data1) );
   Serial.write( byte(data2) );
PaulS
Code: [Select]
You can't just start using a variable without defining it's type.
What will you do if the pulse time is less than 827 or greater than 15000?
dingledow
How do I define it's type?
Would you be able to change the whole code that I post just before?
dxw00d
Code: [Select]
byte mappedPulse = map(pulse, 827, 15000, 0, 127);  //map value to 0-127
Before you go much further, google 'c tutorial' and learn the basics.
dingledow
I've put this together:
Code: [Select]
//Date: 23/07/09
byte sonarnote = 0;            // The MIDI note value to be played
long pulse;
  sonarnote = mappedPulse;
  // play notes from F#-0 (30) to F#-5 (90):
   for (sonarnote = 30; sonarnote < 90; sonarnote++) {
     //Note on channel 1 (0x90), some note value (note), middle velocity (0x45):
     noteOn(0x90, sonarnote, 0x45);
     delay(10);
     //Note on channel 1 (0x90), some note value (note), silent velocity (0x00):
     noteOn(0x90, sonarnote, 0x00);
     delay(10);
I just want to have it so it play a high note when you are close to the sensor and a low note when you are away.
AWOL
So, you set sonarnote to mappedPulse, then play 30 to 89 anyway?
dingledow
I want the notes it plays to be realtime depending on the sonar distance.
I basically want to change this:
Code: [Select]
     delay(10);
     delay(10);
So it plays notes based on what the sensor is mapping.
I don't know if any of this is right!!
PaulS
Quote
Can't your ear tell you? You need to turn up the volume on your device. I can't hear it!
dingledow
Right... thank you all for your help.  I have got it basically working with this code, but I have a few more refinements that I would like help with.
Code: [Select]
//Date: 23/07/09
const
int pwPin = 7;
int pulse = 0;
int mappedPulse = 0;
int prevPulseVal = 0;
int prevnote = 0;
  pulse = pulseIn(pwPin, HIGH);         //read input from potentiometer
  if (pulse>827){
   noteOn(0x90, mappedPulse, 127); //Control Change (Ch 1), Controller 7 - default control for volume.
   noteOn(0x80, mappedPulse, 0);
The code above does this:
If the sonar is more than a specific distance away, it will play a note.  After 500 ms, it will put the note off.  This loops, which means that if it's over a certain distance away, a note will be played every 500ms, even if it's the same note repeating.
How can I change to do the following:
When the sonar is more than a specific distance away it will play a note.  The note will play forever until the distance is changed.  For example, if I'm 30cm away, an F# will play.  If I stay at this exact distance, another note will not play until I change my distance, let's say to 32cm, then a G note will play.  How can I do this.
I know that I need to store a value for the previous note, but I'm not sure how to go about doing it.
Thanks
PaulS
Quote
No. You need to store the previous distance. On each pass through loop, compare the current distance to the previous distance. If different, send a noteOff command, based on the old distance, and a noteOn command, based on the new distance. Then, make the old distance equal the new distance.
Put the code for getting mappedPulse in a function:
Code: [Select]
int readPulse(int aPin)
  int mapVal = 0;
  pinMode(aPin, INPUT);
  unsigned long pulseTime = pulseIn(aPin, HIGH);         //read input from potentiometer
  Serial.println(pulseTime);
  mapVal = map(pulseTime, 827, 15000, 0, 127);  //map value to 0-127
  return mapVal;
Get rid of a bunch of global values that don't need to be global, like pulse.
Call the function, in loop():
Code: [Select]
int currNote;
int prevNote = 0;
   currNote = readPulse(pwPin);
   if(currNote != prevNote)
     // Turn off the old note
     // Turn on the new note
   prevNote = currNote;
