Topic: Stackoverflow Bug? (Read 3502 times) previous topic - next topic
Tasty
Hey,
Ive got a Problem with this Code: http://pastebin.com/NegXa8cS
The Error wenn Compiling/Uploading is this: http://pastebin.com/4UpydAcx
if i change the Code to this: http://pastebin.com/e3HnYTBK
i can upload it, but all other clients like firefox can't connect to it, its giving me an "connection interrupted" / "Verbindung Unterbrochen" (in german)
What can i do to fix this?
Thanks,
Greetz
robtillaart
#1
Apr 11, 2012, 06:28 pm Last Edit: Apr 11, 2012, 06:32 pm by robtillaart Reason: 1
The java error's indicate an error in the IDE, maybe your java needs an update.
On what board are you running this code?
finally I see ...String ... in the code and I know this class is not the most memory efficient.
and the line starting with
client.println("<!DOCTYPE html> ....
is only runnable on a MEGA I assume.
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
dxw00d
And a truck load of client.print() statements eating your SRAM.
Tasty
"finally I see ...String ... in the code and I know this class is not the most memory efficient. "
Should i use char instead?
"On what board are you running this code?"
Its not an original arduino board, its the arduino board from here: http://www.franzis.de/elektronik/lernpakete-elektronik/franzis-lernpaket-fuer-arduino
"maybe your java needs an update."
would an java update help?
"And a truck load of client.print() statements eating your SRAM."
I used this method to check if it cant handle the long string, but if i do it like this its uploading, if i do it in one long string, it doesnt upload and give me the error i posted above.
Thanks for the answers. ;)
dxw00d
Which version of the IDE are you using?
Each of the character literals in the client.print() statements is moved into SRAM before your code starts running. I haven't counted the number of characters, but you only have 2KB of SRAM, and those strings are eating a lot of it.
Tasty
#5
Apr 11, 2012, 07:09 pm Last Edit: Apr 11, 2012, 08:54 pm by Tasty Reason: 1
So would char fix it? or is there any other method to load such a big html file?, maybe switch to sdcard load the html file and then switch to the wiznet chip?
dxw00d
The answer is to keep things in flash, and find a way to stop them being copied into SRAM. If you are using IDE 1.0, then there is an easy way to do that, with the F() macro. This
Code: [Select]
          client.println(F("HTTP/1.1 200 OK"));
prints the string directly from flash.
Tasty
Im using the 0023 IDE, should i download the 1.0?
robtillaart
Quote
what is holding you back to try?
Rob Tillaart
Tasty
#9
Apr 12, 2012, 12:11 pm Last Edit: Apr 12, 2012, 12:25 pm by Tasty Reason: 1
ok so i downloaded now the 1.0 IDE and tryed this code: http://pastebin.com/5YUzMQxX
and i still get this error: http://pastebin.com/34XGByJd
if i use this Code: http://pastebin.com/ZePNgA30
the IDE says the sketch is too big..
What could i do now to solve it?
robtillaart
#10
Apr 12, 2012, 12:23 pm Last Edit: Apr 12, 2012, 12:28 pm by robtillaart Reason: 1
It definitely looks like a bug in the IDE application, not the Arduino code
- what platform do you use? mac linux PC?
Rob Tillaart
Tasty
#11
Apr 12, 2012, 12:26 pm Last Edit: Apr 12, 2012, 12:29 pm by Tasty Reason: 1
Im using an PC.
This Java-tester is saying me that i have the version 1.7.0_03
dxw00d
Perhaps a 6000+ character string is too long.
Tasty
yeah, but how could i trick it?, for example put the html file on my sd-card then read it and then display it, would that work?
dxw00d
Split it up and send a number of shorter lines.
