Topic: 7 Segment Library for Arduino 1.0 (Read 8284 times) previous topic - next topic
lloyddean
Do you know how to use 2 7-segment displays?
Yes, why do you ask?
lloyddean
arisimoes
i belive you can't make a funcion with the same name over other funcion of arduino like setup(); change the funcion name
qtechknow
Now, the library is working, and I would like to add another function to this.  The new library will be named Pineapple, and will use a shift register to drive the 7 segment led.  I have made the new .h file, and the .cpp file, and example code to work.  This library uses the shifter library from bildr, also.  So I need the shifter library to work in the Pineapple library.  I do not know how to initiate the shifter library in my .cpp file or .h file.  This is the current .h, .cpp, and example code for my library.
.cpp file
Code: [Select]
#include "Arduino.h"
#include "Pineapple.h"
#include "Shifter.h"
uint8_t Pineapple::pins(int a, int b, int c, int d, int e, int f, int g, int dp, boolean common) {
    _a=a;
    _b=b;
    _c=c;
    _d=d;
    _e=e;
    _f=f;
    _g=g;
    _dp=dp;
    _common=common;
    segmentPins[0] = _dp;
    segmentPins[1] = _g;
    segmentPins[2] = _f;
    segmentPins[3] = _e;
    segmentPins[4] = _d;
    segmentPins[5] = _c;
    segmentPins[6] = _b;
    segmentPins[7] = _a;
    for(int i=0; i < 8; i++) {
        pinMode(segmentPins[i], OUTPUT);
void Pineapple::write(int number) {
    boolean isBitSet;
    numeral[0] = B11111100;  // 0
    numeral[1] = B01100000;  // 1
    numeral[2] = B11011010;  // 2
    numeral[3] = B11110010;  // 3
    numeral[4] = B01100110;  // 4
    numeral[5] = B10110110;  // 5
    numeral[6] = B10111110;  // 6
    numeral[7] = B11100000;  // 7
    numeral[8] = B11111110;  // 8
    numeral[9] = B11100110;  // 9
    if (_common == HIGH) {
        for(int segment=1; segment < 8; segment++) {
            if(number < 0 || number > 9) {
                isBitSet = 0;
            }else{
                isBitSet = bitRead(numeral[number], segment);
            isBitSet = ! isBitSet;
            shifter.setPin(segmentPins[segment], isBitSet);
            shifter.write();
    }else{
                isBitSet = 0;
            }else{
            shifter.write();
    if (_number == '.' && _common == HIGH) {
        shifter.setPin(_dp, LOW);
        shifter.write();
    if (_number == '.' && _common == LOW) {
        shifter.setPin(_dp, HIGH);
        shifter.write();
        shifter.write();
    if (_common == LOW) {
        shifter.write();
The current .h file.
Code: [Select]
#ifndef Pineapple_h
#define Pineapple_h
class Pineapple
public:
    uint8_t pins(int a, int b, int c, int d, int e, int f, int g, int dp, boolean common);
    void write(int number);
private:
    int _a, _b, _c, _d, _e, _f, _g, _dp, _number;
    byte numeral[10];
    int segmentPins[8];
    boolean _common;
#endif
The example code.
Code: [Select]
#define serial 4 //SER_IN
#define registerClock 3 //L_CLOCK
#define serialClock 2 //CLOCK
#define number 1
Shifter shifter(serial, registerClock, serialClock, number);
Pineapple pineapple;
  pineapple.pins(0, 1, 2, 3, 4, 5, 6, 7, HIGH);
  pineapple.write(1);
The error message I get says the shifter wasn't declared in this scope, and I know that that means I have to initiate the shifter library in the pineapple library.  Any help?
lloyddean
Remove the leading 'shifter.' wherever used in your .cpp file
qtechknow
Thanks lloyddean for your reply.  Yes, I'm 11, but I don't post that here because I want people to take me seriously.  For the code, I got a TON of error messages.  It said when I take out all of the shifter.'s, that all of the names with out shifter. are "not declared in this scope".  Here is my current .cpp file.
Code: [Select]
    _a=a;
    _b=b;
    _c=c;
    _d=d;
    _e=e;
    _f=f;
    _g=g;
    _dp=dp;
    _common=common;
    boolean isBitSet;
                isBitSet = 0;
            }else{
            write();
    }else{
                isBitSet = 0;
            }else{
            write();
        setPin(_dp, LOW);
        write();
        setPin(_dp, HIGH);
        write();
        setPin(_dp, HIGH);
        write();
        setPin(_dp, LOW);
        write();
lloyddean
qtechknow
lloyddean
More specific then.  Where is 'setPin' defined.  I see no implementation for it
qtechknow
How would you define setPin and write() if they are already part of the shifter library?
lloyddean
First of all my apologies revert back to your original "Pineapple.cpp" as posted above.  I didn't notice you we're using a third party library a gave wrong advice.
All you'll need to do as add a line to your "Pineapple.cpp" file as below letting the compiler know that 'shifter' has been defined outside of the current compilation unit (file) as follows:
Code: [Select]
extern Shifter shifter;
