Topic: An analog keypad. Will it work? (Read 2573 times) previous topic - next topic
liuzengqiang
Someone was asking for a solution to sensing 48 buttons. I thought since I might need a solution to a similar problem, I mocked up a diagram that uses 1 analog pin, 8 digital pins, and 7 resistors. Will it work?
The digital pins will be pulled to GND for the active column and left in tri-state for non-active columns.
Thanks.
Serial LCD keypad panel,phi_prompt user interface library,SDI-12 USB Adapter
robtillaart
#1
Apr 12, 2012, 06:50 pm Last Edit: Apr 12, 2012, 06:56 pm by robtillaart Reason: 1
Yes, you must scan allong the pins to see which row has a pressed button.
something like this (not tested)
Code: [Select]
int keypress()
int x;
int row = -1;
int key;
for (int i=0; i< 8; i++)
 digitalWrite(pin[i], HIGH);
 x= analogRead(A0);
 digitalWrite(pin[i], LOW);
 if (x  < THRESHOLD)
    row = i;
if (row > -1)
 return 8*row + lookup(x);  // to do ;)
return -1;
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
robtillaart
you could also use a shift register serial in parallel out (needs 3 lines IIRC)  - http://arduino.cc/en/Tutorial/ShiftOut -
shift in 1 bit high and then clock it from bit 0 to 7 -
don't use shiftOut() but do the clocking in your own pace!
Rob Tillaart
robtillaart
how about this project 64 using a MCP23S17  - http://www.spikenzielabs.com/SpikenzieLabs/Project_64.html -
there are some nice videos too ;)
Rob Tillaart
fkeel
In theory you could get away with no more than two analog pins, I believe...
http://embodimentlabs.tumblr.com/
http://paulstrohmeier.info/
robtillaart
in theory with one analog pin and 48 very precize resistors, say 100 ohm + 5240 ohm
would give 48 steps from 0 to 500 in analogRead => so diff between 2 values is about 10  - just larger than noise (~2 bits)
advantage is that the SW would become very simple: button = analogRead(A0) / 10;
However in practice ....
Rob Tillaart
fkeel
I had not even considered that. I *like* that approach....  :-)
liuzengqiang
Rob,
Thanks for the link. There's no code on the site though. I was a bit concerned when driving with a port extender but since this extender has an open-drain mode, there won't be problems. Still one needs to use it so inactive columns are not driven to opposite polarity. It would short if you drive column 0 to high and 1 to low and hold two buttons one from column 0 and one from 1. If I use arduino pins under tri-state mode, the problem is solved.
I think I will give my own schematic a try with a membrane matrix keypad. I have a bunch at home. Next time I order from digikey, I'll grab a few of those port extenders. :)
robtillaart
it is not visible as a hyperlink, just click on the filename and you fly to - http://www.spikenzielabs.com/SpikenzieLabs/Project_64_files/Button64v4.pde -
Rob Tillaart
liuzengqiang
