Topic: Password protect my Ethernet Web Server - SOLVED (Read 31521 times) previous topic - next topic
DaveO
I am posting this in the hope that, after sponging so much info and learning from this great forum over the past few months, I may be able to contribute back something that could be of use to other users.
After completing a small home automation system with controls accessible over the internet, I was concerned about (accidental or deliberate) unwanted access to the web server interface page.
The following is a basic sketch to password protect the web server page.
Credits : A major credit goes to Zoomkat for his huge input with this project. Without his help and coding, I would never have got this completed. Thanks Zoomkat.
This code may not be perfect ( except for Zoomkat's contributed parts ), and it may not be the most efficient way, but it is how I want my system to work and coded with my basic understanding so that I could follow it's operation.
The code works as follows :
If the code can not find a valid session ID in the received http, it displays the login page which requires a password.
When the user logs in, the current millis() is set as the session ID.
The page of options that is displayed after login contains the session ID in all the hyperlinks.
Click on a hyperlink sends the session ID and the command / action number to the Arduino based server.
The server then validates the session ID and performs the command / action, or if the session ID is invalid, shows the login form again.
There is a variable in the code ( passExpireMil ) that sets the idle time to wait before deleting a session ID. If set to passExpireMil = 60000, then if any link on the served page is not clicked within 60 seconds, the session expires and you need to login again.
Each click on any link on the page restarts the passExpireMil timer.
Code: [Select]
#include <SPI.h>
#include <Ethernet.h>
//ethernet setup
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //physical mac address
IPAddress ip(192,168,1,101);           // change to ip in lan
IPAddress gateway(192,168,1,254);      // change to internet access via router
IPAddress subnet(255,255,255,0);       // change to subnet mask
IPAddress myserver(41,00,00,00);       // not used in this code, but used if writing data to a server based file
EthernetServer server(82);             // server port : remember to set port forwarding on the DSL router
EthernetClient client;                 // Define a client object
const int passCount = 20;
unsigned long passIDstart[passCount];  // array to record start time of user sessions
unsigned long passIDlast[passCount];   // array to record last time of user sessions
unsigned long passIDvalid = 0;         // set default as passID : 0 = missing or invalid
unsigned long passExpireMil = 60000;   // expiry time for automatic expiry of valid passID
String readString;                     // used to clear away incoming data that is not required
char myPass[] = "1234";                // Valid password (1234 for testing)
char DoAction[] = "DoAction";          // keyword for DoAction commands
char buffer[256];                      // buffer for debugging
char xx1[20];                          // temp char for the long converted to char
char JoinedChar[100];                  // char to hold the joined strings
String LastAction;
/* incoming data : Get a single client char                                   */
char gchr(void){
while (!client.available());         /* Await data from client           */
return client.read();               /* Return input character            */
}                                      /* end: gchr()                        */
/* incoming data : Get an entire line from the client                         */
char *glin(char *buf){
char c,*p = buf;                    /* Input char, input buffer pointer   */
while (' ' > (c = gchr()));         /* Discard (leading) control chars    */
do *p++ = c;                        /* Move input char to line buffer     */
while (' ' <= (c = gchr()));        /* Until control char encountered     */
*p = '\0';                          /* Terminate line in buffer           */
return buf;                         /* Return pointer to input string     */
}                                       /* end: glin()                        */
/* Arduino standard setup() function                                          */
void setup(void){
pinMode(4,OUTPUT);                     /* pin selected to control          */
Ethernet.begin(mac,ip,subnet,gateway); /* Initialize ethernet device       */
server.begin();                        /* Listen for connections           */
Serial.begin(9600);                    /* Connect to serial monitor        */
//initialize the passIDstart array to hold zero values in all elements
for (int i=0; i < passCount; i++){
 passIDstart[i] = 0;
Serial.println("Setup Done");
}                                         /* end: setup()                     */
/* Arduino standard loop() function                                           */
void loop(void) {
if (client = server.available()) {    // Request client connection
 while (client.connected()) {      // Is there client data available?
  glin(buffer);                 // Get HTTP request line by line
  Serial.print("The current millis is : ");
  Serial.println(millis());
  Serial.print("Received: '");  // Show what we received from
  Serial.print(buffer);         // the current client
  Serial.println("'");
  passIDvalid = 0;              // set the passIDvalid to 0
  LastAction = "";
DaveO
rest of the code to follow the above code  ( forum limitation on number of characters in a post )
Code: [Select]
   if (strstr(buffer,"logform")) {    /* Is logform keyword present?         */
    Serial.println("Found logform");
    if (strstr(buffer,myPass)) {    /* Is password present?                */
     Serial.println("Found myPass");
     // clear the rest of the incoming buffer
     char c = client.read();
     if (readString.length() < 100) {         // read char by char HTTP request
       readString += c;                       // store characters to string
     if (c == '\n') {                         // if HTTP request has ended - blank line received
      Serial.println("Header Flushed");
     /* Login form processing */
     // get the first open passID storage space and create a new session ID.
      if (passIDvalid == 0 && passIDstart[i] == 0){
       passIDstart[i] = currentMillis;  // set the variable to use as the passID
       passIDlast[i] = currentMillis;   // set the last time the passID was used
       passIDvalid = passIDstart[i];
       Serial.print("New alocated passID = ");
       Serial.print(passIDvalid);
       Serial.print(" in array space ");
       Serial.println(i);
       LastAction = "Login Completed";
     }                     // end of loop for get the first open passID storage space
    }                         // end: if password is present
   }                             // end: if logform in line
   Serial.println("Processing input");
   // clear expired passIDs from array - housekeeping each time a server connection is made
    if (passIDstart[i] != 0){
       if (currentMillis >= passExpireMil){
      if (currentMillis - passIDlast[i] >= passExpireMil){
       passIDstart[i] = 0;
       Serial.print("Cleared passIDstart ");
       Serial.println(i);
   unsigned int GotAction = 0;   // shows that no DoAction command received
   // look for DoAction commands in the input buffer
   if (strstr(buffer,"DoAction")) {    /* If DoAction keyword is present         */
    Serial.println("Found DoAction keyword");
    Serial.println("Looking for valid passID");
    //see if a valid passID exists in the DoAction line
     if (GotAction == 0 && passIDstart[i] != 0){
      ltoa(passIDstart[i],xx1,10);  // convert the long to char
      //check for the passID + DoAction keyword + action code in the buffer
      JoinedChar[0] = '\0';               // clear the destination array
      strcat(JoinedChar, xx1);            //add the passID to the array
      strcat(JoinedChar, DoAction);       //add the keyword to the array
      strcat(JoinedChar, "on001");        //add the action code to the array
       if (strstr(buffer,JoinedChar)) GotAction = 1;
      strcat(JoinedChar, "on002");        //add the action code to the array
       if (strstr(buffer,JoinedChar)) GotAction = 2;
      strcat(JoinedChar, "on003");        //add the action code to the array
       if (strstr(buffer,JoinedChar)) GotAction = 3;
      if(GotAction != 0){
       Serial.print("Found DoAction ");
       Serial.print(GotAction);
       Serial.print(" for passID : ");
       Serial.println(passIDstart[i]);
       passIDlast[i] = currentMillis;   //renew the last time that the passID was used
    if(GotAction != 0){
     /* DoAction processing */
     if(GotAction == 1){
      Serial.println("Received Web Server command on001");
      // do tasks in response to command 1 received
      LastAction = "Command on001 processed";
     if(GotAction == 2){
      Serial.println("Received Web Server command on002");
      // do tasks in response to command 2 received
      LastAction = "Command on002 processed";
     if(GotAction == 3){
      Serial.println("Received Web Server command on003");
      // do tasks in response to command 3 received
      LastAction = "Command on003 processed";
   //display the web page
   client.println("HTTP/1.1 200 OK"); //send new page
   client.println("Content-Type: text/html");
   client.println();
   client.println("<HTML>");
   client.println("<HEAD>");
   client.println("<STYLE TYPE=\"text/css\"><!--");     //set the style for the page to Courier New
   client.println("BODY   {   font-family:Courier New;   }");
   client.println("--></STYLE>");
   client.println("<TITLE>Home Control</TITLE>");       //browser tab title
   client.println("</HEAD>");
   client.println("<BODY>");                            //start of body section
   client.println("Home Control<br><br>");
   client.print("Current Millis value = ");
   client.print(currentMillis);
   client.println("<br><br>");
   client.print("Last Action : ");
   client.print(LastAction);
   if (passIDvalid == 0){  // this is not a valid passID - ask for the password
    client.print ("<form method=get>");
    client.print ("<input type=password name=logform size=10>");
    client.print (" <input type=submit value=Login>");
    client.print ("</form>");
   if (passIDvalid != 0){  // this IS a valid passID - display the web page
    client.print("System : <a href=\"./?");
    client.print(passIDvalid);
    client.print("DoActionon001");
    client.println("\"\">[Command 1]</a><br><br>");
    client.print("DoActionon002");
    client.println("\"\">[Command 2]</a><br><br>");
    client.print("DoActionon003");
    client.println("\"\">[Command 3]</a><br><br>");
   client.println("</BODY>");
   client.println("</HTML>");
   delay(1);
   client.stop();                /* Disconnect from the server          */
  }                                /*  end: while client connected        */
}                                   /*  end: if client connection          */
}                                      /*  end: loop()                        */
mohamed66
hi,
i like your project so much but when i tried it , it didn't work :(
i will tell u what i have done:
first upload code to arduino uno and connect it to ehternet shield and i update my mac address
then write 192.168.1.101:82
it tells me webpage not available . i don't know why ?
i need the part of the password to my project so urgently.
thanks in advance
DaveO
Hi
1. ensure that the IP address you enter, example :
Code: [Select]
does not conflict with another IP address on your network.
2. did you set port forwarding in your router to forward port 82 to the ethernet shield ?
3. you mentioned : 192.168.1.101:82    In your browser, you should use  "http://"  +  your public IP address  + :82  so look at http://www.whatismyip.com/ for your IP and add the  "http://" to the start, and  ":82"  at the end.
mohamed66
hi ,
i tried it in LAN so i didn't do port forwarding , i typed in browser 192.168.1.101:82
i want to add the password part to that code , when i tried that it gives my page to enter password when i entered it correctly it opened the page to control leds but when i press on anything nothing happens to leds and it opens the page of password again.
Code: [Select]
#include <SPI.h>
byte ip[] = { 192, 168, 1, 102 }; // ip in lan
byte gateway[] = { 192, 168, 1, 1 }; // internet access via router
byte subnet[] = { 255, 255, 255, 0 }; //subnet mask
EthernetServer server(84); //server port
String readString;
void setup(){
  pinMode(5, OUTPUT); //pin selected to control
  pinMode(6, OUTPUT); //pin selected to control
  pinMode(7, OUTPUT); //pin selected to control
  pinMode(8, OUTPUT); //pin selected to control
  //start Ethernet
  Ethernet.begin(mac, ip, gateway, gateway, subnet);
  server.begin();
  //enable serial data print
  Serial.println("server multi pin button test 1.0"); // so I can keep track of what is loaded
void loop(){
  // Create a client connection
  if (client) {
      if (client.available()) {
        //read char by char HTTP request
          //store characters to string
          readString += c;
          //Serial.print(c);
        //if HTTP request has ended
        if (c == '\n') {
          Serial.println(readString); //print to serial monitor for debuging
          client.println();
          client.println("<TITLE>Arduino GET test page</TITLE>");
          client.println("<H1>Zoomkat's simple Arduino button</H1>");
          // For simple testing, pin 5, 6, 7, and 8 are used in buttons
          // DIY buttons
          client.println("<a href=/?on2 >ON</a>");
          client.println("<a href=/?off3 >OFF</a>");
          client.println("&nbsp;<a href=/?off357 >ALL OFF</a><br><br>");
          // mousedown buttons
          client.println("<input type=button value=ON onmousedown=location.href='/?on4'>");
          client.println("<input type=button value=OFF onmousedown=location.href='/?off5'>");
          client.println("&nbsp;<input type=button value='ALL OFF' onmousedown=location.href='/?off3579'><br><br>");
          // mousedown radio buttons
          client.println("<input type=radio onmousedown=location.href='/?on6'>ON</>");
          client.println("<input type=radio onmousedown=location.href='/?off7'>OFF</>");
          client.println("&nbsp;<input type=radio onmousedown=location.href='/?off3579'>ALL OFF</><br><br>");
          // custom buttons
          client.print("<input type=submit value=ON style=width:100px;height:45px onClick=location.href='/?on8'>");
          client.print("<input type=submit value=OFF style=width:100px;height:45px onClick=location.href='/?off9'>");
          client.print("&nbsp;<input type=submit value='ALL OFF' style=width:100px;height:45px onClick=location.href='/?off3579'>");
          delay(1);
          //stopping client
          client.stop();
          ///////////////////// control arduino pin
          if(readString.indexOf('2') >0)//checks for 2
            digitalWrite(5, HIGH);    // set pin 5 high
            Serial.println("Led 5 On");
          if(readString.indexOf('3') >0)//checks for 3
            digitalWrite(5, LOW);    // set pin 5 low
            Serial.println("Led 5 Off");
          if(readString.indexOf('4') >0)//checks for 4
            digitalWrite(6, HIGH);    // set pin 6 high
            Serial.println("Led 6 On");
          if(readString.indexOf('5') >0)//checks for 5
            digitalWrite(6, LOW);    // set pin 6 low
            Serial.println("Led 6 Off");
           if(readString.indexOf('6') >0)//checks for 6
            digitalWrite(7, HIGH);    // set pin 7 high
            Serial.println("Led 7 On");
          if(readString.indexOf('7') >0)//checks for 7
            digitalWrite(7, LOW);    // set pin 7 low
            Serial.println("Led 7 Off");
            if(readString.indexOf('8') >0)//checks for 8
            digitalWrite(8, HIGH);    // set pin 8 high
            Serial.println("Led 8 On");
          if(readString.indexOf('9') >0)//checks for 9
            digitalWrite(8, LOW);    // set pin 8 low
            Serial.println("Led 8 Off");
          //clearing string for next read
          readString="";
iluvatarGats
hey man could you help me, with ur arduino ehthernet web server with password, it didnt work, i have my ports open and i tryed to see the code whit mi external ip and the :81 in your code, bud it didnt work, what  am i doing wrong. sorry for my bad English
or u could made a tutorial step by step thanks man
PaulS
@mohamed66
Code: [Select]
What did this print?
Regardless of what GET request the client made, you serve up the same page. That page does not contain any log on information, so how it relates to the topic you hijacked is a mystery.
@iluvatarGats
Quoting is a good thing, so we can see who you are talking to. Who's code are you interested in?
draythomp
Thanks for the code that uses a session ID.  Session IDs are cool, but I didn't want to spend a ton of time working the bugs out to implement it.  I have been taking a different tactic.  I sample the incoming IP address and compare it to my local netmask to see if the request is incoming from my local network.  If it is, I allow things to be done, if it isn't, they get denied.  To allow me to change things from way far away, I give it a secret word that turns off the check for a little while allowing me to change the temperature, close a door or whatever.  The security gets turned back on automatically on expiration of a timer so I can't forget.
This has been working fine and I get occasional (not very often) attempts to open my garage doors or something, but never a sophisticated attack.  On a device this dumb, sophisticated attacks just don't work.  The secret word is in the code only and never goes out over the web so it should be good for a long time.  The attempts to do things are most likely people clicking to see what happens, nothing bad, just curiosity.  Curiosity is fine, I don't mind that at all.
I gotta take your example an try it.
elik745i
Cool, currently trying to adapt your method to my little project on home automatisation, will post results here.
Thanks for idea!
Wake up NEO...
peixinho
Hi!
I'm new to arduino and registered just to say:
Thank you very much Sir!  8)
The code works very well on my platform (arduino Uno + Ethernet Shield with PoE) but a few strings were to be pulled:
The program left only 131 bytes of SRAM left on the processor (witch has 2k ) , the server didn't respond at all and the serial debugging was a mess with a lot of stupi charachters. So, I tried to reduce the SRAM space occupied by the program. And with a simple method I left the Arduino with an astonishing 963 bytes left to play (instead of the 131 bytes)
the method is very simple. In every line of the program with, for example
Code: [Select]
    Serial.print("Setup Done");
you (not the author of the code, you, who are going to use the code) should put the quotes inside the function "F"
Code: [Select]
    client.print(F("DoActionon003"));
    client.println(F("\"\">[Command 3]</a><br><br>"));
    Serial.print(F("Setup Done"));
with this, you are reducing the space written in the SRAM and passing it to program memory.
Cheers!
vanhaght
veys21
web sayfama parola ile giriyorum butona tıklıyorum aktif oluyor fakat butona tıkladıktan sonra boş sayfa çıkıyor. yardım lütfen..
veys21
I enter my web page with a password, I click on the button, but after clicking the button, the blank page opens. help please ..
Code: [Select]
 Web Server
 with
 http auth mod by Minh Truong
 5-18-215
#include <SPI.h>
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0x2D };
byte gateway[] = { 192, 168, 1, 1 }; //               <------- PUT YOUR ROUTERS IP Address to which your shield is connected Here
byte subnet[] = { 255, 255, 255, 0 }; //                <------- It will be as it is in most of the cases
IPAddress ip(192,168,1,33);
// Initialize the Ethernet server library
// with the IP address and port you want to use
// (port 80 is default for HTTP):
EthernetServer server(80);
//char userPass[200];
//char header[500];
String header;
//int bufferSize = 0;
#define RELAY_CH1  2
#define RELAY_CH2  3
#define RELAY_CH3  4
#define RELAY_CH4  5
#define RELAY_CH5  6
#define RELAY_CH6  7
#define RELAY_CH7  8
#define RELAY_CH8  9
String readString;
       pinMode(RELAY_CH1, OUTPUT);
  digitalWrite(RELAY_CH1, HIGH);  // switch on LED1
        pinMode(RELAY_CH2, OUTPUT);
  digitalWrite(RELAY_CH2, HIGH);  // switch on LED2
        pinMode(RELAY_CH3, OUTPUT);
  digitalWrite(RELAY_CH3, HIGH);  // switch on LED3
        pinMode(RELAY_CH4, OUTPUT);
  digitalWrite(RELAY_CH4, HIGH);  // switch on LED4
        pinMode(RELAY_CH5, OUTPUT);
  digitalWrite(RELAY_CH5, HIGH);  // switch on LED5
        pinMode(RELAY_CH6, OUTPUT);
  digitalWrite(RELAY_CH6, HIGH);  // switch on LED6
        pinMode(RELAY_CH7, OUTPUT);
  digitalWrite(RELAY_CH7, HIGH);  // switch on LED7
        pinMode(RELAY_CH8, OUTPUT);
  digitalWrite(RELAY_CH8, HIGH);  // switch on LED8
  Serial.begin(28800);
   while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
  // start the Ethernet connection and the server:
  Ethernet.begin(mac, ip);
  server.begin();
  Serial.print("server is at ");
  Serial.println(Ethernet.localIP());
  // listen for incoming clients
  if (client) {
    Serial.println("new client");
    // an http request ends with a blank line
    boolean currentLineIsBlank = true;
          readString += c;      //Serial.print(c);
        Serial.write(c);
        header += c;
        if (c == '\n' && currentLineIsBlank) {
          //parse headers
          //bWluaDp0ZXN0 = 'minh:test' (user:password) base64 encode
          Serial.print(header);
          // Simpler just to find the credential string
          // send a standard http response header
          if(header.indexOf("bWluaDp0ZXN0") >= 0) {
            //successful login
            client.println("Connection: close");  // the connection will be closed after completion of the response
          client.println("Refresh: 20");  // refresh the page automatically every 5 sec
            client.println();
              if(header.indexOf("GET / HTTP/1.1") >= 0) {
                client.println("<!DOCTYPE HTML>");
                client.println("<html>");
          client.println("<meta name='apple-mobile-web-app-capable' content='yes' />");
          client.println("<meta name='apple-mobile-web-app-status-bar-style' content='black-translucent' />");
          //client.println("<link rel=\"stylesheet\" type=\"text/css\" href=\"http://www.digital2u.net/autohome.css\" />");
          client.println("<meta http-equiv=\"refresh\" content=\"3;url=http://192.168.1.33/\"/>" );
          client.println("<body bgcolor=\"#D0D0D0\">");
          //client.println("<hr/>");
          //client.println("<h4><center><img border=\"2\" src=\"https://lh3.googleusercontent.com/-C6BoJrRUFko/UEUFeCwkvdI/AAAAAAAAAOc/E7gcYvPV6r4/s960/Logo.jpg\" /></center></h4>");
          client.print("<center> <p> <h1>HOSGELDINIZ</h1></p> ");
          //client.println("<br />");
          // Relay Status Display
          client.println("<center>");
              client.println("<table border=\"5\">");
veys21
kodun devamı
Code: [Select]
client.println("<tr>");
                      if (!digitalRead(RELAY_CH1))
                           client.print("<td> <p style=\"font-family:arial;color:black;font-size:26px;\">Device 1.</p><p style=\"font-family:arial;color:green;font-size:35px;\">ON</p> </td>");
                           client.print("<td> <p style=\"font-family:arial;color:black;font-size:26px;\">Device 1.</p><p style=\"font-family:arial;color:red;font-size:35px;\">OFF</p></td>");
                      if (!digitalRead(RELAY_CH2))
                           client.print("<td> <p style=\"font-family:arial;color:black;font-size:26px;\">Device 2.</p><p style=\"font-family:arial;color:green;font-size:35px;\">ON</p></td>");
                          client.print("<td> <p style=\"font-family:arial;color:black;font-size:26px;\">Device 2.</p><p style=\"font-family:arial;color:red;font-size:35px;\">OFF</p></td>");
                      if (!digitalRead(RELAY_CH3))
                           client.print("<td><p style=\"font-family:arial;color:black;font-size:26px;\">Device 3.</p><p style=\"font-family:arial;color:green;font-size:35px;\">ON</p></td>");
                          client.print("<td><p style=\"font-family:arial;color:black;font-size:26px;\">Device 3.</p><p style=\"font-family:arial;color:red;font-size:35px;\">OFF</p></td>");
                      if (!digitalRead(RELAY_CH4))
                         client.print("<td><p style=\"font-family:arial;color:black;font-size:26px;\">Device 4.</p><p style=\"font-family:arial;color:green;font-size:35px;\">ON</p></td>");
                          client.print("<td><p style=\"font-family:arial;color:black;font-size:26px;\">Device 4.</p><p style=\"font-family:arial;color:red;font-size:35px;\">OFF</p></td>");
                      if (!digitalRead(RELAY_CH5))
                           client.print("<td><p style=\"font-family:arial;color:black;font-size:26px;\">Device 5.</p><p style=\"font-family:arial;color:green;font-size:35px;\">ON</p></td>");
                          client.print("<td><p style=\"font-family:arial;color:black;font-size:26px;\">Device 5.</p><p style=\"font-family:arial;color:red;font-size:35px;\">OFF</p></td>");
                      if (!digitalRead(RELAY_CH6))
                           client.print("<td><p style=\"font-family:arial;color:black;font-size:26px;\">Device 6.</p><p style=\"font-family:arial;color:green;font-size:35px;\">ON</p></td>");
                          client.print("<td><p style=\"font-family:arial;color:black;font-size:26px;\">Device 6.</p><p style=\"font-family:arial;color:red;font-size:35px;\">OFF</p></td>");
                      if (!digitalRead(RELAY_CH7))
                           client.print("<td><p style=\"font-family:arial;color:black;font-size:26px;\">Device 7.</p><p style=\"font-family:arial;color:green;font-size:35px;\">ON</p></td>");
                          client.print("<td><p style=\"font-family:arial;color:black;font-size:26px;\">Device 7.</p><p style=\"font-family:arial;color:red;font-size:35px;\">OFF</p></td>");
                      if (!digitalRead(RELAY_CH8))
                         client.print("<td><p style=\"font-family:arial;color:black;font-size:26px;\">Device 8.</p><p style=\"font-family:arial;color:green;font-size:35px;\">ON</p></td>");
                          client.print("<td><p style=\"font-family:arial;color:black;font-size:26px;\">Device 8.</p><p style=\"font-family:arial;color:red;font-size:35px;\">OFF</p></td>");
veys21
continuation of the code
Code: [Select]
client.println("</tr>");
              client.println("</table>");
          client.println("</center>");
         /* Relay Control Code  */
          client.println("<a href=\"/?relay1on\"\"> <button style=\"width:360px;height:120px\"> <font size=\"7\"; color:red ;>Device 1 ON </font> </button> </a> ");
          client.println("<a href=\"/?relay1off\"\"> <button style=\"width:360px;height:120px\"> <font size=\"7\">Device 1 OFF </font> </button> </a> <br />");
          client.println("<a href=\"/?relay2on\"\"> <button style=\"width:360px;height:120px\"> <font size=\"7\">Device 2 ON </font> </button> </a> ");
          client.println("<a href=\"/?relay2off\"\"> <button style=\"width:360px;height:120px\"> <font size=\"7\">Device 2 OFF </font> </button> </a> <br />");
          client.println("<a href=\"/?relay3on\"\"> <button style=\"width:360px;height:120px\"> <font size=\"7\">Device 3 ON </font> </button> </a> ");
          client.println("<a href=\"/?relay3off\"\"> <button style=\"width:360px;height:120px\"> <font size=\"7\">Device 3 OFF </font> </button> </a> <br />");
          client.println("<a href=\"/?relay4on\"\"> <button style=\"width:360px;height:120px\"> <font size=\"7\">Device 4 ON </font> </button> </a> ");
          client.println("<a href=\"/?relay4off\"\"> <button style=\"width:360px;height:120px\"> <font size=\"7\">Device 4 OFF </font> </button> </a> <br />");
          client.println("<a href=\"/?relay5on\"\"> <button style=\"width:360px;height:120px\"> <font size=\"7\">Device 5 ON </font> </button> </a> ");
          client.println("<a href=\"/?relay5off\"\"><button style=\"width:360px;height:120px\"> <font size=\"7\">Device 5 OFF </font> </button> </a> <br />");
          client.println("<a href=\"/?relay6on\"\"><button style=\"width:360px;height:120px\"> <font size=\"7\">Device 6 ON </font> </button> </a> ");
          client.println("<a href=\"/?relay6off\"\"><button style=\"width:360px;height:120px\"> <font size=\"7\">Device 6 OFF </font> </button> </a> <br />");
          client.println("<a href=\"/?relay7on\"\"><button style=\"width:360px;height:120px\"> <font size=\"7\">Device 7 ON </font> </button> </a> ");
          client.println("<a href=\"/?relay7off\"\"><button style=\"width:360px;height:120px\"> <font size=\"7\">Device 7 OFF </font> </button> </a> <br />");
          client.println("<a href=\"/?relay8on\"\"><button style=\"width:360px;height:120px\"> <font size=\"7\">Device 8 ON </font> </button> </a> ");
          client.println("<a href=\"/?relay8off\"\"><button style=\"width:360px;height:120px\"> <font size=\"7\">Device 8 OFF </font> </button> </a> <br />");
          // control arduino pin via ethernet Start //
