Topic: Using strcat to construct a variable URL/ adaptable url for php request (Read 10352 times) previous topic - next topic
SurferTim
What is the last message displayed on the serial monitor after the fail?
GoForSmoke
Instead of loading a buffer with a big string and printing it out, why not just print each piece in turn? If you need to print it to two devices then print each piece to each device before the next.
The concatenation will occur in the serial transmissions. Those could be done 1 byte at a time and still the Arduino would be idle _most_ of the time. You save the ram that may be crashing your sketch for no sacrifice except waste.
1) http://gammon.com.au/blink  <-- tasking Arduino 1-2-3
2) http://gammon.com.au/serial <-- techniques howto
3) http://gammon.com.au/interrupts
Your sketch can sense ongoing process events in time.
Your sketch can make events to control it over time.
C220amg
Actually, there is no fail, it just keeps printing 0's from the rfid_val to the serial monitor after connecting and uploading. It just doesn't allow me to read a tag and thus doesn't start to connect to the server.
PaulS
Code: [Select]
    if (rfid_val == 1|rfid_val==2){
This is probably NOT doing what you think it is. Big difference between | and ||.
GoForSmoke
nickgammon
Code: [Select]
  while(Serial.available()){
    int readByte = Serial.read(); //read next available byte
You are probably going to read one byte here ... unless there was a previous delay, which you had in setup.
Please post technical questions on the forum, not by personal message. Thanks!
More info: http://www.gammon.com.au/electronics
C220amg
Code: [Select]
Thanks, dumb mistake! Though it didn't solve my problem yet, is it possible there is some sort of while loop it doesn't get out from or whatever?
Maybe I need to say it only reads an rfid tag right after having it reset, when the program runs it just doesn't, even when it hasn't read something yet.
Niels,
PaulS
Quote
Then, you need to add more Serial.print() statements, to find out why the function is not being called.
C220amg
If i put different Serial.print() command it only seems to run the void .... sequences in my program.
PaulS
Quote
There are no "void ... sequences" in your program. There are functions, some of which have a void return type.
Post your code!
C220amg
This is the code i'm using.
Code: [Select]
#include <SPI.h>
#include <Ethernet.h>
IPAddress ip( );
IPAddress gateway( );
IPAddress subnet( );
byte mac[] = {  };
IPAddress server( );
EthernetClient client;
int totalCount = 0;
int loopCount = 0;
int connectLed=5;
int buttonState=0;
int connectedToServer=6;
/////////////////RFID/////////////////
int RFIDResetPin = 13;
int rfid_val;
//Register your RFID tags here
char tag1[13] = "4500530E9F87";
char tag2[13] = "450052E8E51A";
int led1=2;
int led2=3;
  pinMode(4,OUTPUT);
  digitalWrite(4,HIGH);
  Ethernet.begin(mac, ip, gateway, gateway, subnet);
  delay(2000);
  Serial.println("Ready");
  pinMode(RFIDResetPin, OUTPUT);
  digitalWrite(RFIDResetPin, HIGH);
  pinMode(led1, OUTPUT);
  pinMode(led2, OUTPUT);
  pinMode(connectedToServer, OUTPUT);
////////////////Ethernet////////
    Serial.print("RFID TAG ");
    Serial.println(rfid_val);
    if (rfid_val == 1||rfid_val==2){
    digitalWrite(connectLed, HIGH);
    Serial.print("If statement works");
    if(!getPage(server,"/add_db.php")) Serial.print("Fail ");
    else Serial.print("Pass ");
    Serial.println(totalCount,DEC);
   else {
    // turn LED off:
    digitalWrite(connectLed, LOW);
  char tagString[13];
  int index = 0;
  boolean reading = false;
    Serial.println("Serial.available");
    if(readByte == 2) reading = true; //begining of tag
    if(readByte == 3) reading = false; //end of tag
    Serial.print(readByte);
    if(reading && readByte != 2 && readByte != 10 && readByte != 13){
      //store the tag
      tagString[index] = readByte;
      Serial.println("(reading && readByte != 2 && readByte != 10 && readByte != 13)");
      index ++;
      Serial.print("index");Serial.println(index);
  checkTag(tagString); //Check if it is a match
  clearTag(tagString); //Clear the char of all value
  resetReader(); //eset the RFID reader
byte getPage(IPAddress ipBuf,char *page)
  int inChar;
  char outBuf[64];
  Serial.print("connecting...");
  if(client.connect(ipBuf,80))
    Serial.println("connected");
    sprintf(outBuf,"GET /add_db.php?Rfid=%u HTTP/1.0\r\nHost: www.**************.nl\r\n\r\n",rfid_val);
    client.write(outBuf);
    Serial.println("failed");
    return 0;
  while(client.connected())
    while(client.available())
      inChar = client.read();
      Serial.write(inChar);
    digitalWrite(connectedToServer, HIGH);
    digitalWrite(connectedToServer, LOW);
  Serial.println("disconnecting.");
  client.stop();
  return 1;
void checkTag(char tag[]){
   Serial.println("begin of void checkTag");
//Check the read tag against known tags
  if(strlen(tag) == 0){
   digitalWrite(led1,LOW);
   digitalWrite(led2,LOW);
   rfid_val=0;
    //return; //empty, no need to contunue
  if(compareTag(tag, tag1)){ // if matched tag1, do this
     rfid_val=1;
     digitalWrite(led1, HIGH);
     delay(2000);
  if(compareTag(tag, tag2)){ //if matched tag2, do this
     rfid_val=2;
     delay(2000);
  Serial.println("end of void checkTag");
//void lightLED(int pin){
////Turn on LED on pin "pin" for 250ms
//  Serial.println(pin);
//  digitalWrite(pin, HIGH);
void resetReader(){
//Reset the RFID reader to read again.
  digitalWrite(RFIDResetPin, LOW);
  delay(200);
  Serial.println("End of void resetReader");
void clearTag(char one[]){
//clear the char array by filling with null - ASCII 0
//Will think same tag has been read otherwise
  for(int i = 0; i < strlen(one); i++){
    one[i] = 0;
     Serial.print("void clearTag i value ");
    Serial.println(i);
  Serial.println("clearTag ");
boolean compareTag(char one[], char two[]){
//compare two value to see if same,
//strcmp not working 100% so we do this
  if(strlen(one) == 0) return false; //empty
  for(int i = 0; i < 12; i++){
    if(one[i] != two[i]) return false;
    Serial.print("boolean compareTag i value ");
    Serial.println(i);
  return true; //no mismatches
Thanks,
Niels
PaulS
How is the RFID reader really connected to the Arduino? You seem to be using Serial to read from/write to the Serial Monitor AND to read from the RFID reader. You can't do that.
C220amg
Well, that rather strange because I did combine two programs, an ethernet part together with a rfid part.
This is the rfid code only, which works. This code continuously prints the a 0, a 1 or a 2.
0 for no rfid
1 for rfid 1
and
2 for rfid 2
Code: [Select]
int rfid_val;
int led1=2;
int led2=3;
void setup(){
  //ONLY NEEDED IF CONTROLING THESE PINS - EG. LEDs
void loop(){
  char tagString[13];
  int index = 0;
      //store the tag
      index ++;
   rfid_val=0;
     rfid_val=1;
     delay(2000);
     rfid_val=2;
     delay(2000);
void resetReader(){
  delay(200);
    one[i] = 0;
PaulS
Why not use SoftwareSerial to read the RFID, using two other pins?
nickgammon
He can put the RFID reader on the Rx pin, and leave the Tx pin free for debugging.
