Topic: strncpy() causes reset (Read 5295 times) previous topic - next topic
Scott216
I'm trying to take parse the HTTP reply I get from uploading data to pachube.com.  I'm using EhterCard.h and it has a function tcpReply() that returns the HTTP response, which is
HTTP/1.1 200 OK
Date: Fri, 13 Apr 2012 12:17:36 GMT
Content-Type: text/plain; charset=utf-8
Connection: close
X-Pachube-Logging-Key: logging.Lo55opRx5dl5UwAw2NUO
X-PachubeRequestId: 2ea1be6efb47aac0a0f47ec04196b14f721f605c
Cache-Control: max-age=0
Content-Length: 1
Vary: Accept-Encoding
According to strlen() it's 308 bytes long.  I want to use strtok (using \n as delimiter) to parse each line, but first I'm using strncpy() to prevent a
a invalid conversion from 'const char*' to 'char*'
But my sketch seems to be failing at the strncpy() function and reboots before I even get to strtok().  Below is my code, can anyone tell me what I am doing wrong?
Code: [Select]
  const char* reply = ether.tcpReply(session);    // part of EtherCard.h library
  if (reply != 0)
    char reply2[strlen(reply)+1];
    strncpy(reply2, reply, sizeof(reply));  // I think Arduino is rebooting here
    reply2[strlen(reply)] = '\0';
    char delims[] = "\n";
    char *result = NULL;
    result = strtok( reply2, delims );
    while( result != NULL )
        Serial.println(result);
        result = strtok( NULL, delims );
cmiyc
If reply is 308 bytes and reply2 is 309 bytes, that's 617 bytes of RAM for one operation.
Could you be running out of memory?
Capacitor Expert By Day, Enginerd by night.  ||  Personal Blog: www.baldengineer.com  || Electronics Tutorials for Beginners:  www.addohms.com
mrdovey
#2
Apr 17, 2012, 05:40 am Last Edit: Apr 17, 2012, 05:52 am by Morris Dovey Reason: 1
Code: [Select]
Umm reply is a pointer to char, yes?
sizeof(reply) will always be 2 on an Arduino!
(It's not blowing up where you think it is. What does ether.tcpReply() return?)
Edit: added conclusion.
Scott216
Oops, I should have used:
Code: [Select]
strncpy(reply2, reply, strlen(reply))
I made this change but it still reboots.  I don't know about running out of memory.  How do I tell?  When I compile it says Binary Sketch:  18,082 bytes (of a 30,720 byte maximum)
AWOL
Quote
That only reports program (flash) memory - the amount of SRAM used is not reported.
My guess is that you have lots of strings consuming RAM.
But without seeing code, it really is just a guess.
PaulS
Quote
The proper cast would prevent the "problem" without the need to copy the string.
Scott216
Quote
How do I do that?
PaulS
Quote
How do I do that?
Wouldn't that depend on where the "problem" is occurring? You haven't said.
Scott216
It looks like I'm running out of RAM.  I added a FreeMemory routine I found here: http://arduino.cc/playground/Code/AvailableMemory
Before I define reply2, I have less then 200 bytes.  reply2 would be 308 bytes.   I'd like not have to create reply2 and just use reply with strtok(), but reply is a const char and strtok() doesn't like that.  So my solution is to strncpy reply to reply2.
I think I'm running out of ram when I define reply2 on line 451.
I would also like to free up some ram, but I'm not sure how to do that.   Attached is the entire sketch, except for PachubeAPIKey.h which is just a #DEFINE with my API key (65 characters).
I'm using a Nanode, which is similar to Arduino Deumilanove.
Scott216
I got it working.  I shortened a bunch of strings in my Serial.print() statements and that freed up some RAM.
I also figured out how to cast my const char to char:
char* reply = const_cast<char*> (ether.tcpReply(session));
I'm not changing the reply string, so I felt comfortable doing this.
PaulS
I'll never understand why Microsoft invented a bunch of complex templates for casting, and why anyone uses them.
Code: [Select]
char *reply = (char *)(ether.tcpReply(session));
No templates; smaller footprint; easier (for me) to understand.
Scott216
Code: [Select]
I like your method better.
liuzengqiang
You should move your Serial.print strings to PROGMEM.
A lazy way is to use the Serial.print(F("ahaqoihio"));
Unless every output string is unique you are duplicating strings in PROGMEM.
Serial LCD keypad panel,phi_prompt user interface library,SDI-12 USB Adapter
Scott216
I'm going to do that.  I learned a lot about strings and RAM in trying to debug this problem.
liuzengqiang
If you do need a lot of strings even the PROGMEM can't hold, you can still get an EEPROM to store the strings. There's solutions to these problems :)
