Topic: ANSI C (Read 2816 times) previous topic - next topic
elico
Hi all
Can I program C code based on ANSI C on the ARDUINO IDE ?
Thanks
Elico
Coding Badly
No.  It's a C++ compiler.  I believe several ANSI C things are not supported in C++.
Coding Badly
Yes.  If you create a "tab" with a dot-C extension.
elico
Waht is a "tab" ?
jraskell
Don't you know the appropriate thing to do is to wipe out all evidence of your first post?  Or were you just waiting for somebody to quote you first, to add to the confusion?  If so, there you go. ;)
Coding Badly
Why would I do that?  The question was precise; the expected response would include similar precision.  Both responses are correct.  The "sketch tab" is not processed by an ANSI C compiler.
Quote
What part of my response is confusing?  If elico truly wants ANSI C (which was his question) he will not get it from the "sketch tab".  If elico truly wants ANSI C from the ARDUINO IDE (which was his question) he can get it from a dot-C tab.
If, instead, elico was seeking a "good C or C++ compiler on the Arduino IDE" then he can state so.
Coding Badly
@jraskell: I apologize.  Now that I've climbed off my jackbox# I can see my posts are indeed confusing.
@elico: Do you really need an "ANSI C" compiler?
# Like a soapbox but instead of the person standing on the box rambling about politics the person is acting like a jack... Well, you get the idea.
nickgammon
... based on ANSI C ...
Based on? But not actually C?
Please post technical questions on the forum, not by personal message. Thanks!
More info: http://www.gammon.com.au/electronics
skyjumper
What parts of ANSI C are not incorporated into C++? I think his question was more along the lines of, can he tell the compiler to reject C++ features and act as a strict C compiler. I don't believe the Arduino environment can do that. So if that was the question, I think the answer is no.
nickgammon
I'm not sure that was the question. But only OP knows that ...
Coding Badly
Quote
Function declarations / definitions were a problem at my old job.
Legal ANSI but not C++...
Code: [Select]
noreturntype()
In ANSI, the declaration does not have to match the definition...
Code: [Select]
noreturntype();
noreturntype( int whateverdude )
skyjumper
Quote
Code: [Select]
noreturntype()
Code: [Select]
noreturntype();
Hm, I would have to dig into the spec, and maybe this depends upon how on defines "ANSI C", but I don't think those examples are valid C or C+ code. Perhaps they were at one time, but I don't think that's legal syntax today.
Coding Badly
Care to place a wager?   $)   :D
nickgammon
Waht is a "tab" ?
There is an icon on the top RH corner of the IDE screen. That makes a new "tab" in the project which you can name xxx.c, xxx.cpp, or xxx.h.
elico
Thanks
I am asking this because I wonder if after getting used to  ARDUINO ide , will i be able to program
in the AVR STUDIO withot much sweat ..
That is the point .
Elico
