Topic: DCF77 library for Arduino - synchronize with atomic clock (Read 41539 times) previous topic - next topic
babutian
Hello after downloading the DCF77 lib (including Time and TimeZone) I keep getting the following errors:
Code: [Select]
Build options changed, rebuilding all
\\nas\Main\DOCUMENTS\Arduino\libraries\DCF77\DCF77.cpp: In static member function 'static void DCF77::finalizeBuffer()':
\\nas\Main\DOCUMENTS\Arduino\libraries\DCF77\DCF77.cpp:160:25: error: 'now' was not declared in this scope
   filledTimestamp = now();
\\nas\Main\DOCUMENTS\Arduino\libraries\DCF77\DCF77.cpp: In static member function 'static bool DCF77::receivedTimeUpdate()':
\\nas\Main\DOCUMENTS\Arduino\libraries\DCF77\DCF77.cpp:189:50: error: 'now' was not declared in this scope
  time_t processedTime = latestupdatedTime + (now() - processingTimestamp);
\\nas\Main\DOCUMENTS\Arduino\libraries\DCF77\DCF77.cpp:197:20: error: 'SECS_PER_MIN' was not declared in this scope
  if(difference < 2*SECS_PER_MIN) {
\\nas\Main\DOCUMENTS\Arduino\libraries\DCF77\DCF77.cpp:209:25: error: 'SECS_PER_MIN' was not declared in this scope
  if(shiftDifference < 2*SECS_PER_MIN) {
\\nas\Main\DOCUMENTS\Arduino\libraries\DCF77\DCF77.cpp: In static member function 'static bool DCF77::processBuffer()':
\\nas\Main\DOCUMENTS\Arduino\libraries\DCF77\DCF77.cpp:271:2: error: 'tmElements_t' was not declared in this scope
  tmElements_t time;
\\nas\Main\DOCUMENTS\Arduino\libraries\DCF77\DCF77.cpp:284:12: error: request for member 'Second' in 'time', which is of non-class type 'time_t(time_t*) {aka long unsigned int(long unsigned int*)}'
       time.Second = 0;
\\nas\Main\DOCUMENTS\Arduino\libraries\DCF77\DCF77.cpp:285:9: error: request for member 'Minute' in 'time', which is of non-class type 'time_t(time_t*) {aka long unsigned int(long unsigned int*)}'
    time.Minute = rx_buffer->Min-((rx_buffer->Min/16)*6);
\\nas\Main\DOCUMENTS\Arduino\libraries\DCF77\DCF77.cpp:286:12: error: request for member 'Hour' in 'time', which is of non-class type 'time_t(time_t*) {aka long unsigned int(long unsigned int*)}'
       time.Hour   = rx_buffer->Hour-((rx_buffer->Hour/16)*6);
\\nas\Main\DOCUMENTS\Arduino\libraries\DCF77\DCF77.cpp:287:12: error: request for member 'Day' in 'time', which is of non-class type 'time_t(time_t*) {aka long unsigned int(long unsigned int*)}'
       time.Day    = rx_buffer->Day-((rx_buffer->Day/16)*6);
\\nas\Main\DOCUMENTS\Arduino\libraries\DCF77\DCF77.cpp:288:12: error: request for member 'Month' in 'time', which is of non-class type 'time_t(time_t*) {aka long unsigned int(long unsigned int*)}'
       time.Month  = rx_buffer->Month-((rx_buffer->Month/16)*6);
\\nas\Main\DOCUMENTS\Arduino\libraries\DCF77\DCF77.cpp:289:12: error: request for member 'Year' in 'time', which is of non-class type 'time_t(time_t*) {aka long unsigned int(long unsigned int*)}'
       time.Year   = 2000 + rx_buffer->Year-((rx_buffer->Year/16)*6) -1970;
\\nas\Main\DOCUMENTS\Arduino\libraries\DCF77\DCF77.cpp:290:37: error: 'makeTime' was not declared in this scope
    latestupdatedTime = makeTime(time);
\\nas\Main\DOCUMENTS\Arduino\libraries\DCF77\DCF77.cpp: In static member function 'static time_t DCF77::getTime()':
\\nas\Main\DOCUMENTS\Arduino\libraries\DCF77\DCF77.cpp:310:48: error: 'now' was not declared in this scope
   time_t currentTime =latestupdatedTime + (now() - processingTimestamp);
\\nas\Main\DOCUMENTS\Arduino\libraries\DCF77\DCF77.cpp: In static member function 'static time_t DCF77::getUTCTime()':
\\nas\Main\DOCUMENTS\Arduino\libraries\DCF77\DCF77.cpp:325:42: error: 'SECS_PER_HOUR' was not declared in this scope
   int UTCTimeDifference = (CEST ? 2 : 1)*SECS_PER_HOUR;
\\nas\Main\DOCUMENTS\Arduino\libraries\DCF77\DCF77.cpp:326:68: error: 'now' was not declared in this scope
   time_t currentTime =latestupdatedTime - UTCTimeDifference + (now() - processingTimestamp);
exit status 1
Error compiling for board Arduino/Genuino Mega or Mega 2560.
for just this code:
Code: [Select]
#include "DCF77.h"
#include "Time.h"
char time_s[9];
char date_s[11];
#define DCF_PIN 2           // Connection pin to DCF 77 device
#define DCF_INTERRUPT 0    // Interrupt number associated with pin
time_t t;
DCF77 DCF = DCF77(DCF_PIN,DCF_INTERRUPT);
  DCF.Start();
  Serial.println("Warte auf Zeitsignal ... ");
  Serial.println("Dies kann 2 oder mehr Minuten dauern.");
Any suggestions would be greatly appreciated!
6v6gt
Try:
#include <TimeLib.h>
Instead of:
#include "Time.h"
babutian
Hi, unfortunately I don't have the timeLib.h file, there is only time.h in the appropriate Time lib folder... Where do I get it?
regards
ProLaser2846
Hi, my name is Mateusz and I'm from west part of Poland, so distortions in signal I received is not bad. Thank you for your library! ;)
My question is, How can I print on lcd or maybe just serial monitor parity bits of DCF77 signal? I have got built a prototype of DCF77 clock and I want to add some gadgets to it. ;P
Thanks and regards! :)
6v6gt
The format of the signal is described here and includes the parity bits:
https://en.wikipedia.org/wiki/DCF77
I guess when you say you want to print the parity bits, you mean you want to print if the parity bit check passed or failed.
CEST/CET timezones (bit 17 and 18) can also be used as a check. These bits cannot be equal.
ProLaser2846
Exactly!
I want to checks every parity bit in signal (P1, P2, P3 and maybe "S" bit too [yes I know S bit is not a parity bit]) and display it on lcd by
if (parityBitP1 == 1) {
   lcd.print("1");
if (parityBitP2 == 1) ...
But I can't write program that will do this because I don't know how. :/
Can someone help me with that? I don't even know how to start writing this code... :(
6v6gt
You have got the code linked in the OP http://thijs.elenbaas.net/downloads/?did=1 installed and working ?
The parity checking is done here:
Code: [Select]
// Check parities
    if (flags.parityMin == rx_buffer->P1  &&
        flags.parityHour == rx_buffer->P2 &&
        flags.parityDate == rx_buffer->P3 &&
rx_buffer->CEST != rx_buffer->CET)
   // parity ok
    else {
       // parity check failed
So, for example, flags.parityMin is the parity pit for Minutes calculated from this bits received in the data stream from the DCF transmitter.
rx_buffer->P1 is the actual parity bit received in the data stream from the DCF transmitter.
Clearly, if the calculated and actual parity bits don't match, there is a parity error.
From that, you should be able to find something to print to the LCD screen.
