Topic: Running Arduino 1.0 on 64bit Linux, IDE won't start (Read 1 time) previous topic - next topic
joefernandez
Hi All,
I'm getting a weird error when I try to run the 64-bit version of the Arduino IDE on a 64-bit linux (Ubuntu 10.04):
Code: [Select]
joefernandez@joefernandez:~/opt/arduino-1.0-64bit$ ./arduino
java.lang.UnsatisfiedLinkError: /home/joefernandez/opt/arduino-1.0-64bit/lib/librxtxSerial.so: /home/joefernandez/opt/arduino-1.0-64bit/lib/librxtxSerial.so: wrong ELF class: ELFCLASS64 (Possible cause: architecture word width mismatch) thrown while loading gnu.io.RXTXCommDriver
Exception in thread "main" java.lang.UnsatisfiedLinkError: /home/joefernandez/opt/arduino-1.0-64bit/lib/librxtxSerial.so: /home/joefernandez/opt/arduino-1.0-64bit/lib/librxtxSerial.so: wrong ELF class: ELFCLASS64 (Possible cause: architecture word width mismatch)
at java.lang.ClassLoader$NativeLibrary.load(Native Method)
at java.lang.ClassLoader.loadLibrary0(ClassLoader.java:1755)
at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1680)
at java.lang.Runtime.loadLibrary0(Runtime.java:840)
at java.lang.System.loadLibrary(System.java:1047)
at gnu.io.CommPortIdentifier.<clinit>(CommPortIdentifier.java:83)
at processing.app.Editor.populateSerialMenu(Editor.java:969)
at processing.app.Editor.buildToolsMenu(Editor.java:697)
at processing.app.Editor.buildMenuBar(Editor.java:482)
at processing.app.Editor.<init>(Editor.java:204)
at processing.app.Base.handleOpen(Base.java:700)
at processing.app.Base.handleOpen(Base.java:665)
at processing.app.Base.handleNew(Base.java:561)
at processing.app.Base.<init>(Base.java:301)
at processing.app.Base.main(Base.java:190)
I tried running the 32-bit version on the same machine, and it works fine.
What gives?
joefernandez
Ah, I found the problem!  8)
In the current (4/27/12), 64-bit version distribution there are two librxtxSerial files:
Code: [Select]
joefernandez@joefernandez:~/opt/arduino-1.0-64bit/lib$ ls -la lib*
-rw-r--r-- 1 joefernandez eng 182189 2011-11-28 17:05 librxtxSerial64.so
-rw-r--r-- 1 joefernandez eng 182189 2011-11-28 17:05 librxtxSerial.so
However, you can see from the file sizes that they exactly the same size (~177.9 KB). In the (working) 32-bit version they are different:
Code: [Select]
joefernandez@joefernandez:~/opt/arduino-1.0-32bit/lib$ ls -la lib*
-rw-r--r-- 1 joefernandez eng 182189 2011-11-28 16:56 librxtxSerial64.so
-rw-r--r-- 1 joefernandez eng  48304 2011-11-28 16:56 librxtxSerial.so
So I copied lib/librxtxSerial.so from the 32-bit distribution into the 64-bit /lib directory (overwriting the original) and now it works!
Looks like a mistake in the 64-bit linux distribution package. Please fix this, guys!
\\Joe
joefernandez
Follow-up on the original solution to this problem.
I have since switched my primary JVM from a version of the 64-bit OpenJDK to the 64-bit Oracle Java JDK, by making the Oracle JDK the first one on my PATH. Now the Arduino environment starts up with no problems, using the distribution as provided (i.e., *without* swapping the serial libraries around).
