Topic: Programmer not responding/heavy serial usage? (Read 604 times) previous topic - next topic
the_total
Apr 29, 2012, 02:49 pm Last Edit: Apr 29, 2012, 05:47 pm by the_total Reason: 1
Hi there,
I have a Nano which is not responding when I try and upload to it - although the board is still visible.
It seems to be stuck in an infinite loop. I uploaded a sketch to to read 3 potentiometers and send values back over serial, and I also set the LED on 13 to blink in the loop (the loop had a delay of 50 ms).
Now, the board is unresponsive, but the LED on 13 blinks constantly, and resumes the instant I release the reset button.  I have removed everything from the board...
Reading some other threads, I think this might be due to heavy use of Serial, or is this something else (sounds ridiculous)
The loopback test works, even when not in reset.
Any ideas what I can do?
Unfortunately, I don't have another arduino to try ISP...
Any help would be appreciated.
Thanks!
Krodal
It could be in a watchdog loop.
If you burn the bootloader with the Arduino, the fuses are also set. Or did you do that already?
