Topic: Mistakes with shift operation (Read 1 time) previous topic - next topic
_Matt_
Hello everybody, can you please help me to find the mistake here? I can't understand what's the problem (probably some over overflow).
Here's my code:
Code: [Select]
uint32_t value = 0;
  for (int i = 0; i < 32; i++)
    value = 1 << i;
    Serial.print("value["); Serial.print(i); Serial.print("] = ");
    Serial.print(value);
    Serial.print(" - binary = ");
    Serial.println(value, BIN);
  while(1);
This is what I obtain (as you can see the values after the 14th are messed up)
I've also tried declaring value as an unsigned long (same results) and as an unsigned int (value[15] = 32768, value[16+] = 0). How to fix? Thank you for your help!
Marek080
Code: [Select]
value = uint32_t(1) << i;
Try this one in your loop. Looks like the compiler uses int for the 1 and int is only 16 bit. If you shift 16 times the 1 gets lost...
_Matt_
