Topic: USBtinyISP will program bootloader but not sketch (Read 4259 times) previous topic - next topic
instrumentek
Hi, I'm trying to use a spark fun pocket programmer, same as USBtinyISP to program my sketch. It will program the bootloader fine through the Arduino tools menu. However it will not program any sketch. I'm using the blink example. And my arduino version is 22. I followed the instruction on http://arduino.cc/en/Hacking/Programmer. I changed the preferences.txt to :
upload.using=USBtinyISP
I get the folloing error:
Code: [Select]
Binary sketch size: 1018 bytes (of a 30720 byte maximum)
java.lang.NullPointerException
at processing.app.debug.AvrdudeUploader.getProgrammerCommands(AvrdudeUploader.java:106)
at processing.app.debug.AvrdudeUploader.uploadUsingPreferences(AvrdudeUploader.java:68)
at processing.app.Sketch.upload(Sketch.java:1603)
at processing.app.Sketch.exportApplet(Sketch.java:1568)
at processing.app.Sketch.exportApplet(Sketch.java:1524)
at processing.app.Editor$DefaultExportHandler.run(Editor.java:2293)
at java.lang.Thread.run(Thread.java:619)
I have tried updating my java version on my PC.
I have tried reinstalling Arduino 22
I have tried deleting the preferences.txt
I have tried another Arduino nano.
I have tried changing the boards.txt file instead to:
Code: [Select]
atmega328.name=Arduino nano ATmega328
atmega328.upload.using=USBtinyISP
atmega328.upload.protocol=usbtiny
atmega328.upload.maximum_size=30720
atmega328.upload.speed=57600
atmega328.bootloader.low_fuses=0xFF
atmega328.bootloader.high_fuses=0xDA
atmega328.bootloader.extended_fuses=0x05
atmega328.bootloader.path=atmega
atmega328.bootloader.file=ATmegaBOOT_168_atmega328.hex
atmega328.bootloader.unlock_bits=0x3F
atmega328.bootloader.lock_bits=0x0F
atmega328.build.mcu=atmega328p
atmega328.build.f_cpu=16000000L
atmega328.build.core=arduino
this is what my programmer file looks like:
Code: [Select]
avrisp.name=AVR ISP
avrisp.communication=serial
avrisp.protocol=stk500v1
avrispmkii.name=AVRISP mkII
avrispmkii.communication=usb
avrispmkii.protocol=stk500v2
usbtinyisp.name=USBtinyISP
usbtinyisp.protocol=usbtiny
parallel.name=Parallel Programmer
parallel.protocol=dapa
parallel.force=true
# parallel.delay=200
arduinoisp.name=Arduino as ISP
arduinoisp.communication=serial
arduinoisp.protocol=stk500v1
arduinoisp.speed=19200
I would appreciate and help or suggestions.
spycatcher2k
Code: [Select]
atmega328t.name=ATMega 328 - USBTinyISP
atmega328t.upload.maximum_size=32768
atmega328t.upload.speed=57600
atmega328t.upload.using=arduino:usbtinyisp
atmega328t.bootloader.low_fuses=0xFF
atmega328t.bootloader.high_fuses=0xDD
atmega328t.bootloader.extended_fuses=0x05
atmega328t.bootloader.path=atmega
atmega328t.bootloader.file=ATmegaBOOT_168_atmega328.hex
atmega328t.bootloader.unlock_bits=0x3F
atmega328t.bootloader.lock_bits=0x0F
atmega328t.build.mcu=atmega328p
atmega328t.build.f_cpu=16000000L
atmega328t.build.core=arduino
Thats what I use - try that ;-)
Mrs Drew
UK Based PCB Manufacturing - PM for details
I will design & code for you, but I will also charge you (PM me)
Use Google or search this site BEFORE asking!
instrumentek
strykeroz
Thanks from me too Drew.  I've a standalone board that's ignoring all attempts to program it via FTDI so needed to use 0.22 due to an older incompatible sketch, via USBtinyISP ...thanks for this!
Geoff
"There is no problem so bad you can't make it worse" - retired astronaut Chris Hadfield
timscott22
Thanks for your help.
I was able to use your work and the error codes produced by my attempts to come up with an updated  boards.txt entry.
On my mac the path to the boards.txt is:
Arduino.app/Contents/Resources/Java/hardware/arduino/avr/boards.txt
Here is the entry:
Code: [Select]
atmega328t.upload.tool=arduino:usbtinyisp
atmega328t.build.variant=standard
Thanks again for your help.
Regards Tim
