Hi there
I bought one of sparkfuns trackballs and want to incorperate it into a midi controller. They give code that lets it control pitch and volume.
Thing is i'm new to this and can understand code. What i'm kinda looking to do is control one parameter (control change like modulation) with the x or y data and another cc change with the other cc data. I can see how to substitute this code to do that. If I could do that I wanted then to use a push button to allow me to select a number of other cc's, maybe cycling threw 3 or 4 of them. Also ithe code seems very complicated to just control two things( pitch and volume) or is it?
Roll-a-tone Example Code
SparkFun Electronics 2011
N.Poole
This is some really awfully messy code that I created for the product video.
It's essentially a mashup of the Musical Instrument Shield example code by
Nathan Seidle and the PS/2mouse Library example found at:
www.arduino.cc/playground/ComponentLib/Ps2mouse
I left most of the original comments intact so it shouldn't be too difficult to
pick it apart and figure out what the heck I was thinking.
Roll the ball up and down to control the volume (velocity) of the notes,
Roll side to side to play different notes,
Press the buttons (Yellow and White wires pulled to Ground) to change instruments.
Have fun! Make Music! Modify my code! Who Cares?
#define MDATA 5
#define MCLK 6
#include <NewSoftSerial.h>
NewSoftSerial mySerial(2, 3); //Soft TX on 3, we don't use RX in this code
byte note = 0; //The MIDI note value to be played
byte resetMIDI = 4; //Tied to VS1053 Reset line
byte ledPin = 13; //MIDI traffic inidicator
int instrument = 11;
int lnote = 0;
int vel = 0;
void gohi(int pin)
pinMode(pin, INPUT);
digitalWrite(pin, HIGH);
void golo(int pin)
pinMode(pin, OUTPUT);
digitalWrite(pin, LOW);
void mouse_write(char data)
char i;
char parity = 1;
// Serial.print("Sending ");
// Serial.print(data, HEX);
// Serial.print(" to mouse\n");
// Serial.print("RTS");
/* put pins in output mode /
gohi(MDATA);
gohi(MCLK);
delayMicroseconds(300);
golo(MCLK);
golo(MDATA);
delayMicroseconds(10);
/ start bit /
gohi(MCLK);
/ wait for mouse to take control of clock); /
while (digitalRead(MCLK) == HIGH)
/ clock is low, and we are clear to send data /
for (i=0; i < 8; i++) {
if (data & 0x01) {
gohi(MDATA);
else {
golo(MDATA);
/ wait for clock cycle /
while (digitalRead(MCLK) == LOW)
parity = parity ^ (data & 0x01);
data = data >> 1;
/ parity /
if (parity) {
gohi(MDATA);
else {
golo(MDATA);
/ stop bit /
gohi(MDATA);
delayMicroseconds(50);
/ wait for mouse to switch modes /
while ((digitalRead(MCLK) == LOW) || (digitalRead(MDATA) == LOW))
/ put a hold on the incoming data. */
golo(MCLK);
// Serial.print("done.\n");
- Get a byte of data from the mouse
char mouse_read(void)
char data = 0x00;
int i;
char bit = 0x01;
// Serial.print("reading byte from mouse\n");
/* start the clock /
gohi(MCLK);
gohi(MDATA);
delayMicroseconds(5); / not sure why /
while (digitalRead(MCLK) == LOW) / eat start bit /
if (digitalRead(MDATA) == HIGH) {
data = data | bit;
bit = bit << 1;
/ eat parity bit, which we ignore /
/ eat stop bit */
/* put a hold on the incoming data. */
golo(MCLK);
// Serial.print("Recvd data ");
// Serial.print(" from mouse\n");
return data;
void mouse_init()
gohi(MCLK);
gohi(MDATA);
// Serial.print("Sending reset to mouse\n");
mouse_write(0xff);
mouse_read(); /* ack byte /
// Serial.print("Read ack byte1\n");
mouse_read(); / blank /
// Serial.print("Sending remote mode code\n");
mouse_write(0xf0); / remote mode /
mouse_read(); / ack */
// Serial.print("Read ack byte2\n");
delayMicroseconds(100);
mouse_init();
//Setup soft serial for MIDI control
mySerial.begin(31250);
//Reset the VS1053
pinMode(resetMIDI, OUTPUT);
digitalWrite(resetMIDI, LOW);
delay(100);
digitalWrite(resetMIDI, HIGH);
delay(100);
- get a reading from the mouse and report it back to the
- host via the serial line.
char mstat;
char mx;
char my;
/* get a reading from the mouse /
mouse_write(0xeb); / give me data! /
mouse_read(); / ignore ack */
mstat = mouse_read();
mx = mouse_read();
my = mouse_read();
/* send the data back up /
Serial.print(mstat, DEC);
Serial.print("\tX=");
Serial.print(mx, DEC);
Serial.print("\tY=");
Serial.print(my, DEC);
delay(20); / twiddle */
talkMIDI(0xB0, 0x07, 120); //0xB0 is channel message, set channel volume to near max (127)
//Demo Basic MIDI instruments, GM1
talkMIDI(0xB0, 0, 0x00); //Default bank GM1
talkMIDI(0xC0, instrument, 0); //Set instrument number. 0xC0 is a 1 data byte command
note = map(mx, -127, 127, 30, 90);
vel = map(my, -127, 127, 0, 120);
if(lnote != note){
//Note on channel 1 (0x90), some note value (note), middle velocity (0x45):
noteOn(0, note, vel);
delay(50);}
if(mstat == 9){
instrument--;
talkMIDI(0xC0, instrument, 0);}
if(mstat == 10){
instrument++;
lnote = note;
//Send a MIDI note-on message. Like pressing a piano key
//channel ranges from 0-15
void noteOn(byte channel, byte note, byte attack_velocity) {
talkMIDI( (0x90 | channel), note, attack_velocity);
//Send a MIDI note-off message. Like releasing a piano key
void noteOff(byte channel, byte note, byte release_velocity) {
talkMIDI( (0x80 | channel), note, release_velocity);
//Plays a MIDI note. Doesn't check to see that cmd is greater than 127, or that data values are less than 127
void talkMIDI(byte cmd, byte data1, byte data2) {
digitalWrite(ledPin, HIGH);
mySerial.print(cmd, BYTE);
mySerial.print(data1, BYTE);
//Some commands only have one data byte. All cmds less than 0xBn have 2 data bytes
//(sort of: MIDI Communication Protocol)
if( (cmd & 0xF0) <= 0xB0)
mySerial.print(data2, BYTE);
digitalWrite(ledPin, LOW);
