Topic: faire un get via 3g (Read 4483 times) previous topic - next topic
djo54150
bonjour,
alors voila j ai un probleme dans mon code je pense car quand j envoie les commande manuel ca marche
mon code bloque apres Serial.println(port); Serial.flush();
car il est censé lire REQUEST et continuer mais rien ...
Code: [Select]
char data[1024];
int data_size;
int led = 13;
int onModulePin = 2;        // the pin to switch on the module (without press on button)
int x = 0;
char server[ ]="www.google.lu";
char port[ ]="80";
void switchModule(){
    digitalWrite(onModulePin,HIGH);
    delay(2000);
    digitalWrite(onModulePin,LOW);
void setup(){
    Serial.begin(115200);                // UART baud rate
    delay(2000);
    pinMode(led, OUTPUT);
    pinMode(onModulePin, OUTPUT);
    switchModule();                    // switches the module ON
    for (int i=0;i< 5;i++){
        delay(5000);
    Serial.println("AT+CPIN=1234");     //active le code pin
    delay(8000);
    Serial.println("AT+CGDCONT=1,\"IP\",\"orange.lu\"");
    Serial.flush();
    while(Serial.read()!='K');
    Serial.print("AT+CHTTPACT=\""); //Connects with the HTTP server
    Serial.print(server);
    Serial.print("\",");
    Serial.flush();
    x=0;
    do{
        while(Serial.available()==0);
        data[x]=Serial.read();
        x++;
    }while(!(data[x-1]=='T'&&data[x-2]=='S'));        //waits for response "REQUEST"
    Serial.println("GET /index.html HTTP/1.1");
    Serial.println("Host: www.google.lu");
    Serial.println("Content-Length: 0");
    Serial.write(0x1A);       //sends ++
    Serial.write(0x0D);
    Serial.write(0x0A);
  while(Serial.read()!=' ');
  data_size=0;
  do{
    data_size*=10;
    data_size=data_size+(Serial.read()-0x30);
  }while(Serial.peek()!=0x0D);
  for(x=0;x< data_size;x++){
  Serial.print(data);
    while(1);
en manuel le code marche tres bien car j obtiens bien ce que je veux :
Code: [Select]
at+csq
+csq: 17,99
OK
AT+CGDCONT=1,"IP","orange.lu"
OK
AT+CHTTPACT="www.google.lu",80
+CHTTPACT: REQUEST
GET /index.html HTTP/1.1 Host: www.google.lu Content-Length: 0
OK
+CHTTPACT: DATA,1068
http/1.0 400 bad request
content-type: text/html; charset=utf-8
content-length: 925
date: thu, 10 may 2012 08:17:53 gmt
server: gfe/2.0
<!DOCTYPE html>
               <html lang=en>
                               <meta charset=utf-8>
                                                     <meta name=viewport content
="initial-scale=1, minimum-scale=1, width=device-width">
                                                          <title>Error 400 (Bad
Request)!!1</title>
                     <style>
                                *{margin:0;padding:0}html,code{font:15px/22px ar
ial,sans-serif}html{background:#fff;color:#222;padding:15px}body{margin:7% auto
0;max-width:390px;min-height:180px;padding:30px 0 15px}* > body{background:url(/
/www.google.com/images/errors/robot.png) 100% 5px no-repeat;padding-right:205px}
p{margin:11px 0 22px;overflow:hidden}ins{color:#777;text-decoration:none}a img{b
order:0}@media screen and (max-width:772px){body{background:none;margin-top:0;ma
x-width:none;padding-right:0}}
                                </style>
                                          <a href=//www.google.com/><img src=//w
ww.google.com/images/errors/logo_sm.gif alt=Google></a>
                                                         <p><b>400.</b> <ins>Tha
t’s an error.</ins>
                       <p>Your client has issued a malformed or illegal request.
  <ins>That’s all we know.</ins>
+CHTTPACT: 0
skizoh
bonjour,
bon je ne vois pas de chose anormal dans ton programme donc je ne serais pas te dire ce qui va pas, la vitesse est peut être inadapter? mais je ne crois, fait gaff avec le serial.println, il balance un fin de ligne + carriage return en fin de ce que tu envoie ce qui correspond a /r/n donc éssaye avec Serial.write(.. si tu veux mon avis.
Skizo !
djo54150
le serial.println du port tu penses?
jai deja essayé de le modifier
c est une probleme avec request
car quand j enlève la verification de request ca va jusqu au get (ce qui est normal en meme tps)
du coup ca vient d avant ....
en gros un commentaire pour rien dire mais la flemme de l effacer
infobarquee
bonjour,
as tu essayé de remplacer
Code: [Select]
par
Code: [Select]
char server[ ]={74,125,132,94};
AUCUNE AIDE PAR MP
djo54150
djo54150
djo54150
#6
May 10, 2012, 12:14 pm Last Edit: May 10, 2012, 12:22 pm by djo54150 Reason: 1
c est ma réponse dans le sérial monitor
pour l instant jai rajouté la commande at+cgauth
plus que a avoir pourquoi jai pas la bonne réponse ;)
Code: [Select]
AT+CPIN=1234
AT+CGAUTH=1,1,,
Host: www.google.lu
Content-Length: 0
ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÑå
skizoh
je n'ai pas tout compris, mais prend garde au terminal, parfois ta donnée est juste, elle est juste mal traduite et tu peut avoir des caractère bizarre alors que ta variable est niquel..
Skizo !
djo54150
tu me conseil quoi alors pour vérifier
djo54150
jai testé avec hypertherminal
mais a mon avis il ya un probleme avec la réponse
infobarquee
je dirais que le mieux serait d'interroger un server perso et regarder les logs apache avec une page toute bête.
AUCUNE AIDE PAR MP
skizoh
ba déja quel le type de ce que tu veux? char? byte? int?
parce que si j'ai bien vue tu à des caractère bizarre ici:
Code: [Select]
   Serial.write(0x1A);       //apartir d'ici
   Serial.write(0x0D);
   Serial.write(0x0A);
donc c'st que ton 0x1A etc s'affiche mal, donc c'est la qu'il va falloir essayer, j'ai tester ça pour toi:
     Serial.write(byte(0x0D)); donne rien
     Serial.write(0x0D+48); donne "="
     Serial.write(0x0D);  donne rien
.. déjà la on est mal tu vois donc cherche par la..
djo54150
la réponse est juste mais je dois mal la traité
avez vous un moyen simple de l afficher
skizoh
#13
May 10, 2012, 02:02 pm Last Edit: May 10, 2012, 02:04 pm by skizoh Reason: 1
a la ligne:
Code: [Select]
tu peut tenter de faire un cast byte ou char comme ça:
Code: [Select]
data[x]=char(Serial.read());
ou
data[x]=byte(Serial.read());
je propose des truc comme ça ^^
Skizo !
skizoh
Ce que tu reçois au final c'est une page web c'est ça? et tu comptait l'afficher comment? sur le terminal?
Skizo !
