Topic: fingerprint scanner communication through uart (Read 14196 times) previous topic - next topic
drab
ok i changed char incomingByte[11] to byte incomingByte[11] was that correct..? and i also changed my for statement to
for(byte i=0; i<11;i++){}
            incomingByte = fdk.read();
now the only error im getting is that incompatible types in assignment of int to byte[11]
AWOL
Yes, that's quite an understandable error.
Which element of the array did you want to put the most recently-read character?
drab
I want the bits to go from 0 to 11 in the order they are read i think so i only have to  compare the 5th spot in the array and once it fills that spot and gets its match or no match its goes on and sets a pin high as well as other things
AWOL
No, you want the bytes that go from zero to ten
drab
ok so how do i get them and where is my mistake at ive seen lots of other code that has done what im trying to do and still cant figure out where im making my mistake at my teacher i had for programming has no clue at all so im stuck in the proverbial mud here....im learninng more here than i did in class and would love to have that lightbulb moment....
AWOL
Reply #26  looked to be going in the right direction, it was just missing a declaration of an index.
drab
ok what do you mean by a decleration of an index? what should i be indexing??? or where should i be indexing...
AWOL
The index is "i", and you didin't declare it.
drab
wow i just got it to compile.....heres what it looks like now
Code: [Select]
#include <NewSoftSerial.h>
#include <string.h>
NewSoftSerial fdk(2, 3);
int ledPin = 13;
byte incomingByte[10];
byte array1[]={
  0xFF, 0xFF, 0xFF, 0xF5, 0xC0, 0x13, 0x0E, 0xFF, 0xFF, 0xFF, 0xF5};
byte array2[]={
  0xFF, 0xFF, 0xFF, 0xF5, 0xC0, 0x10, 0x0E, 0xFF, 0xFF, 0xFF, 0xF5};
byte array3[]={
  0xFF, 0xFF, 0xFF, 0xF5, 0xC0, 0x12, 0x0E, 0xFF, 0xFF, 0xFF, 0xF5};
byte array4[]={
  0xFF, 0xFF, 0xFF, 0xF5, 0xC0, 0x11, 0x0E, 0xFF, 0xFF, 0xFF, 0xF5};
  fdk.begin(9600);
  pinMode(13,OUTPUT);
  pinMode(12,OUTPUT);
  if (fdk.available() >=10 )
    for(byte i=0; i<10;i++){
      incomingByte[10] = fdk.read();
  if(incomingByte[5]==array1[5])
    digitalWrite(13,HIGH);
as you can see on on the line incomingByte[10] = fdk.read(); i added my array value.....and thats what allowed it to compile. is that the index you was talkin about awol? if so then i see what you was getting at.... but when i uploaded it all i got was an autoscrolling F in my serial monitor after i added the serial.print command....
AWOL
Code: [Select]
...will overwrite the same eleven times.
The index should be "i", not "10".
PaulS
Quote
And, the assignment should be in the body of the for loop, not in a separate (useless) block after the for loop.
michael_x
Quote
indentation and the correct number of open/closed braces is fine, but not always sufficient ;)
PaulS
Quote
That depends on how you define "correct". If "correct" is simply the same number of each, then the number of curly braces in that code is correct.
If "correct" also includes only necessary (and optional, but highly recommended), then the number of curly braces in that code is not correct.
michael_x
