Topic: 0v - 12v analog output for Peltier cell (Read 1 time) previous topic - next topic
il.teo
Hello,
I am a newbie, I tried to find some references on this, but I did not find anything.. Maybe someone can help me:
I am playing with Peltier cells and Arduino. Instead of only starting/stopping the cell, I would like to be able to control the power of the cell reducing the voltage applied.
I need an output variable from 0v to 12v. I know the analog output on the arduino are 0-5v, and not real analog, but PWM.
Is there a chip out there that I can connect to a PWM pin (and to an external 12v source of course) to make this conversion? I tried to look for DAC, but I need some suggestions for choosing the right one.
Thank you for your help!
Teo
Daniel2
hey
you need to raise both the current and voltage levels.
Look for a MOSFET driver diagram. The Arduino will drive the input (gate) side of the MOSFET, and the other side will have a 12V supply and the Peltier junction connected to it.
D
il.teo
#2
May 26, 2008, 03:53 pm Last Edit: May 26, 2008, 03:53 pm by il.teo Reason: 1
Thank you for the answer Daniel. ^_^
I will search for the correct MOSFET components for this application and try.
I only have a doubt: Using this method the MOSFET will provide an "amplified" PWM signal to the peltier cell, right?
Will this be a problem for the life and efficiency of the cell? I have read that turning on and off again and again those cells, on the long period may damage them. Using a real DAC should be preferred?
Thank you again, and sorry if I am writing stupid things..
Teo
