Topic: NewPing Library: HC-SR04, SRF05, SRF06, DYP-ME007, Parallax PING))) - v1.7 (Read 653770 times) previous topic - next topic
GertSanders
hi Tim,
it did not compile properly (it did not find an ASSR symbol). I tried changing things to allow it to use Timer0, which is the 8 bit timer on this MCU (Timer2 is 16 bit).
That also failed, but that is probably due to my poor understanding of the datasheet.
I do have another question:  when ping_cm() is called, will it execute for the duration of time needed for the echo to register (or up to the time needed for MAX_DISTANCE) ?
Does it basically only continue when either the echo is detected or the maximum wait time for MAX_DISTANCE expires ?
I use the SR-HC04 with a max distance of 150cm, and will be using it mostly for shorter distances, so that would mean that I can ping sensors every 89micro seconds (if I use 8 of them spread out to avoid false echo's).
Would be nice to get confirmation on this last question. Gert
teckel
hi Tim,
ping_cm() uses blocking mode, so yes, it will wait till it gets a ping back or it exceeds the defined max distance.  Remember it's not just what you set for the software as the max distance, there's the physical world to consider, and those pings may echo in the real world no matter how you set the max distance.  In other words, you could still have echo and cross-talk issues even if you only care about shorter distances.  Multiple sensors cause even more cross-talk and echo problems.  Nothing a library can do about this, as you're dealing with the speed of sound, echos (the physical world) and the sensitivity of the sensors (hardware limitations).
Tim
My platforms Arduino, Teensy 3.2, Arduino Pro Mini, ATmega328
My libraries: NewPing, LCDBitmap, toneAC, toneAC2, NewTone, TimerFreeTone
My projects: https://dogblocker.com & https://baconorbeer.com
My beer: Great Lakes Brewing Co. Lake Erie Monster
Student83
Hi :) I'm a student who is completing an HND in systems engineering, my graded unit project inlvolves and arduino, ultrasonic sensor, relay switch, buzzer and a pump. When the ultrasonic see's my given high and low parameters is switches the relay which activates both my pump and buzzer for the duration of filling the tank.
I have the programme working fine  :):) however i'm experiencing rapid switching when the sensor reaches around my high and low level. Through some research I have now added hysteresis to help issues, however, i can't seem to get it to work properly.
I have posted the current adapted programme below, can anyone help? Please.....
// defines pins numbers
const int trigPin = 9;
const int echoPin = 10;
const int buzzer = 11;
const int relayPin = 13;
// defines variables
long duration;
int distance;
int lastDistance;
int hysteresis = 2;
pinMode(trigPin, OUTPUT); // Sets the trigPin as an Output
pinMode(echoPin, INPUT); // Sets the echoPin as an Input
pinMode(buzzer, OUTPUT);
pinMode(relayPin, OUTPUT);
Serial.begin(9600); // Starts the serial communication
// Clears the trigPin
digitalWrite(trigPin, LOW);
delayMicroseconds(1000);
// Sets the trigPin on HIGH state for 30 micro seconds
digitalWrite(trigPin, HIGH);
// Reads the echoPin, returns the sound wave travel time in microseconds
duration = pulseIn(echoPin, HIGH);
// Calculating the distance
distance= duration*0.034/2;
lastDistance = distance;
if ((lastDistance + hysteresis) <= 12 && (lastDistance - hysteresis) >= 4){
digitalWrite(buzzer, HIGH);
digitalWrite(relayPin, HIGH);
else{
digitalWrite(buzzer, LOW);
digitalWrite(relayPin, LOW);
// Prints the distance on the Serial Monitor
Serial.print("Distance: ");
Serial.println(distance);
teckel
long duration;
int distance;
int lastDistance;
int hysteresis = 2;
else{
You're not even using the NewPing library, which is the purpose of this thread and would greatly clean up your code.  Also, putting code inside a code container would make your code much easier to read.  You could also use the ping_median() method in NewPing to even out a lot of the bouncing around that happens if you're only doing a single ping, this would greatly reduce the results you're getting.
Anyway, I'd start with using the NewPing library, using the example sketch, adding the buzzer instead of outputing the results to serial, and change the ping_cm() to ping_median() to smooth out the results better.  That's a good start.
Tim
Student83
Thank you for responding, I'm a new user and unsure how I start a new topic hence the backing onto this thread :O
I'll look over the info you have suggested and re-try. Thank you :)
teckel
I've converted your code to use NewPing and use NewPing's built-in ping_median() method which in this example will do 5 pings and return the median value.  This typically provides more stable results as it throws out the "noise".  Depending on how fast you need the loop to run, you could increase the MEDIAN_PINGS define to 7 or higher (typically odd numbers).  This would provide even more stable results.
Code: [Select]
#include <NewPing.h>
#define TRIGGER_PIN    9 // Arduino pin tied to trigger pin on the ultrasonic sensor
#define ECHO_PIN      10 // Arduino pin tied to echo pin on the ultrasonic sensor
#define BUZZER_PIN    11 // Arduino pin tied to buzzer pin
#define RELAY_PIN     13 // Arduino pin tied to relay pin
#define MAX_DISTANCE 200 // Maximum distance we want to ping for (in centimeters)
#define MEDIAN_PINGS   5 // The nubmer of pings to fire
NewPing sonar(TRIGGER_PIN, ECHO_PIN, MAX_DISTANCE); // NewPing setup of pins and maximum distance
unsigned long duration;
unsigned int distance, lastDistance, hysteresis = 2;
  pinMode(BUZZER_PIN, OUTPUT);
  pinMode(RELAY_PIN, OUTPUT);
  // Do 5 pings, use the median distance, returns the sound wave travel time in microseconds
  duration = sonar.ping_median(MEDIAN_PINGS);
  distance = duration / US_ROUNDTRIP_CM;
  if ((lastDistance + hysteresis) <= 12 && (lastDistance - hysteresis) >= 4) {
    digitalWrite(BUZZER_PIN, HIGH);
    digitalWrite(RELAY_PIN, HIGH);
    digitalWrite(BUZZER_PIN, LOW);
    digitalWrite(RELAY_PIN, LOW);
If, however, what you are measuring is moving, you may not wan to use the ping_median() method.  Instead, something like this would be better:
Code: [Select]
#define TRIGGER_PIN    9 // Arduino pin tied to trigger pin on the ultrasonic sensor.
#define ECHO_PIN      10 // Arduino pin tied to echo pin on the ultrasonic sensor.
#define MAX_DISTANCE 200 // Maximum distance we want to ping for (in centimeters). Maximum sensor distance is rated at 400-500cm.
NewPing sonar(TRIGGER_PIN, ECHO_PIN, MAX_DISTANCE); // NewPing setup of pins and maximum distance.
  delay(50); // Wait 50ms between pings (about 20 pings/sec)
  distance = sonar.ping_cm(); // Do a ping, returns the distnace in CM
Neither of these examples modify your hysteresis logic.  But, it may work better because you're using the NewPing library instead of rolling your own.
Tim
nskmda
What is the status of false positives the library may give?
In my situation I'm pointing an SR04 (4-prong model) into nowhere and setting the max distance to 400 cm (max per the spec).
I still get false positives quite often even outside of the house in the backyard.
I used single ping_cm() call , then did convert_cm(ping_median()) (default 5 signals) still the library returns false positives quite often.
Can it be the case of misbehaving sensor? Because I have 2 and with both the library behaves identically.
teckel
Returning false-positives is probably the sensor as I never get them.  Also, I don't hear of this kind of problem from others very frequently.
But, it's possible that if you're trying to do pings too frequently you could be doing a ping and stepping over the last ping, causing the echo pin to be high when it's being monitored.
It's also possible that your sensor needs more time to wait before listening for a ping.  There's a define in NewPing.h named MAX_SENSOR_DELAY that by default is set to 5800.  It's possible that your sensor needs more time.  Try setting MAX_SENSOR_DELAY to 40000 and see if that gives you better results.  This value is set via a define to allow you to change it if you're particular sensor needs more time.
Tim
nskmda
But, it's possible that if you're trying to do pings too frequently...
It's also possible that your sensor needs more time to wait before listening for a ping.  There's a define...
Tim, thanks a lot for the response.
I'll try to change the delay (is it in micro-seconds or in something else? i mean, why 40K as the new value).
Am I guessing it right I'm going to the lib's source code for that? Or can I override the #def in my sketch'es code? (I'm a Java guy, only have brief experience with C/C++).
If it doesn't help then it may totally be a sensor (it was shipped even w/o antistatic bag).
Also, my sketch has the main loop delay(250) between pings. Also, on a detection (distance > 0) I send a radio ping (which also takes some time).
Do you think I need to extend the delay?
teckel
It's in the NewPing source code, but it's very easy to change (just a txt file like your sketch).
Setting the MAX_SENSOR_DELAY to 40000 is in microseconds. I'm suggesting to set it high to see if that resolves anything. Setting it to just a slightly larger delay probably won't do anything, so it's not worth trying.
One thing you said was a little confusing. When you get a ping back you say you send a "radio ping". Is that another sonar ping or something else?
Maybe your sketch would help, as you could be song something incorrectly which I would never know without seeing your code. It's kinda a standard rule here that you should always post your sketch, as that's typically the only way anyone can help (or else they're just guessing).
nskmda
Tim,
I will try to post my sketch.
No, the 'radio ping' is just that - radio: I'm using the RadioHead lib + transmitter module (which should not interfere with the sonar, I hope!) to send signal from the backyard into the house.
I'll update and re-test the behavior.
One thing which I might have missed is what could interfere with sonar outside in the 'wild'?
Because I already tried a PIR module, but it turned out to get a lot of interference (like wind and sun) and I had to switch to sonar (as - hopefully - less prone to interference of those kinds).
Because, again, inside the sensor seemed to work more or less stable (in open space I didn't see too many positives in the serial output in monitor).
One thing which just came to my mind: I'm connecting the sensor directly, w/o any extra curcuitry (i.e., capasitors, diodes, resistors etc.) to the board and am using direct powering, not from the board's pins.
Have you heard about anything extra which may make those sensors be more stable?
But anyway, I did test it inside the house and the serial output looked pretty stable...
teckel
Tim,
Make sure all your grounds are tied together if you have multiple power sources or voltages, that can cause problems.
Maybe understanding better what you're doing would be helpful.  If it's outside, an insect, bird or whatever could easily be giving you these false-positives.  If you're trying to detect something that's mostly stationary or moving slowly, another technique is to do multiple pings per loop and only report a positive result if all (or most) have a ping result.  For example, something like this code snip-it:
Code: [Select]
NewPing sonar(12, 11, 500);
unsigned int pings[3];
  for (uint8_t i = 0; i < 3; i++) {
    delay(50);
    pings[i] = sonar.ping_cm();
    if (pings[0] > 0 and pings[1] > 0 and pings[2] > 0) {
      // ping the radio
This would only ping your radio if you received 3 positive pings in a row within 150ms.  You could easily change this from 2 to 3 pings if you wanted to require only 2 pings for a positive radio ping.
Again, seeing your sketch and what you're trying to accomplish can GREATLY help diagnosing and resolving your problem.
Tim
nskmda
Tim,
Here's the sketch:
Code: [Select]
#include <RH_ASK.h>
#include <SPI.h>
RH_ASK driver(500);
boolean driverInitialized = false;
boolean somethingStirring = false;
boolean messageSent = false;
const char *msg = "object around!";
#define SONAR_SENSORS 1
#define MAX_DISTANCE_CM 350
NewPing sonar[SONAR_SENSORS] =
  NewPing(8, 9, MAX_DISTANCE_CM)
  driverInitialized = driver.init();
  if (!driverInitialized)
    Serial.println("radio driver init failed");
    Serial.println("radio driver initialized");
  delay(5000);
  if (driverInitialized)
    if (shouldSendMessage())
      sendObjectDetected();
  delay(250);
boolean shouldSendMessage()
  boolean sonarDetected = false;
  for (int i=0; i<SONAR_SENSORS; i++)
    String distance = "Sonar ";
    distance.concat(i);
    distance.concat(" distance returned: ");
    int median_cm = NewPing::convert_cm(sonar[i].ping_median(3));
    distance.concat(median_cm);
    sonarDetected = sonarDetected || (median_cm>0);
    if (sonarDetected) { break; }
  return sonarDetected;
void sendObjectDetected()
  Serial.println("sending object signal");
  driver.send((uint8_t *)msg, strlen(msg));
  driver.waitPacketSent();
  Serial.println("object signal sent");
I originally planned to use 2 sensors, but now I'm only doing one.
teckel
Tim,
Something like this...
Code: [Select]
#include <RH_ASK.h>
#include <SPI.h>
RH_ASK driver(500);
NewPing sonar(8, 9, 350);
  if (!driverInitialized) {
  delay(5000);
  if (driverInitialized) {
      delay(50);
    unsigned int average_cm = 0;
      average_cm = (pings[0] + pings[1] + pings[2]) / 3;
    String distance = "Sonar distance returned: ";
    distance.concat(average_cm);
    if (average_cm > 0) {
void sendObjectDetected() {
nskmda
Yes, I got the idea.
I can totally do similar.
But I tried to experiment today and looks like there really might have been something which caused the sensor to receive a reflected signal back.
I put it on the front porch pointing to the sky. And it was okay for some time. Then there was a bit of drizzle and it started 'overreacting" again (it looked like water got on the protective mesh in front of the transmitter/receiver).
I will test more.
But I tried to change the '#define' and for some reason the IDE didn't pick up the change (i tried to put something non-compilable in the .h file and it still was okay with the sketch).
Do I need to find where the .zip file went? Or may be uninstall/reinstall the library somehow?
