Topic: NewPing Library: HC-SR04, SRF05, SRF06, DYP-ME007, Parallax PING))) - v1.7 (Read 630487 times) previous topic - next topic
teckel
Quote
The problem with using Timer2 is that it's only 8 bit so you can't do a long timeout event.
You could add a counter in the timer2 ISR that will check only every 10 overflows (sort of cascading)
Code: [Select]
volatile byte counter = myPreferedValue;
void ISR()
  if (counter-- == 0)
    do your check
does that make sense?
Very true, I was hoping to avoid making things overly complex.
On that note, I've decided to only use Timer2 in NewPing.  Even though Timer1 was a little cleaner, I believe using Timer1 is a deal-breaker as the servo library uses Timer1 and ultrasonic sensors and servos are often found on the same project.  So, this still makes the library cleaner as it doesn't need the clutter of both Timer1 and Timer2 functions that basically do the same thing (not to mention the existing ping method which uses the old method).  3 different ping methods that all did the same thing was kind of overkill anyway.
As a bonus, the next release of NewPing will include general-use Timer2 interrupt methods that you could use in non-ping parts of your sketch.  I needed to break the timer interrupts up into individual functions anyway as they would be used multiple times, and why not at the same time allow these functions to be used in the rest of your sketch.  For that matter, you could use NewPing just for the simple Timer2 interrupt methods, and it is very simple.
Tim
My platforms Arduino, Teensy 3.2, Arduino Pro Mini, ATmega328
My libraries: NewPing, LCDBitmap, toneAC, toneAC2, NewTone, TimerFreeTone
My projects: https://dogblocker.com & https://baconorbeer.com
My beer: Great Lakes Brewing Co. Lake Erie Monster
teckel
NewPing v1.3 Released, download here
New in v1.3
Big feature addition, event-driven ping! Uses Timer2 interrupt, so be mindful of PWM or timing conflicts messing with Timer2 may cause (namely PWM on pins 3 & 11 on Arduino, PWM on pins 9 and 11 on ATmega, and Tone library). Simple to use timer interrupt functions you can use in your sketches totaly unrelated to ultrasonic sensors (don't use if you're also using NewPing's ping_timer because both use Timer2 interrupts). Loop counting ping method deleted in favor of timing ping method after inconsistant results kept surfacing with the loop timing ping method. Conversion to cm and inches now rounds to the nearest cm or inch. Code optimized to save program space and fixed a couple minor bugs here and there. Many new comments added as well as line spacing to group code sections for better source readability.
NOTE: For Teensy/Leonardo (ATmega32U4) the library uses Timer4 instead of Timer2. Also, only 16Mhz microcontrollers are supported with the timer methods, which means the ATmega8 and ATmega128 will not work with the timer methods. However, the standard ping method should work just fine on 8Mhz microcontrollers.
Tim
cyclegadget
Thank you for all your hard work! I will definitely try the new version out soon!
Good links: Eagle tutorial= http://www.youtube.com/playlist?list=PLDE1858BD83D19C70
General Arduion tutorials = http://tronixstuff.wordpress.com
http://www.gammon.com.au/forum/bbshowpost.php?bbtopic_id=123
trendski
Many thanks for doing this.
I was researching which sensors to buy.
NewPing v1.3 came just in time to help me make the right decision.
Cheers
Craig Turner, blog: http://gampageek.blogspot.co.uk/ It helps with my learning if I write things down, esp. for others to follow (constructive comments welcomed to improve)
yonatan36
how can i use the library with ultrasonic ks103 sensor?
www.dauxi.com/KS10X-V110_EN.pdf
thank you
AWOL
Quote
With great difficulty; it's an I2C device.
teckel
thank you
Do you already have the ks103 or is there a reason you want to use this model instead of the other, more typical ultrasonic sensors like the SR04?
Tim
AWOL
In which case, you're stuck with whatever algorithm is implemented in the device's firmware.
NewWorldScientist
Great work on the library! I thought I might use this thread for a bit of troubleshooting.
My HC-SR04 is doing some very bizarre things and I'm lost. When using newPing and it's included newpingexample sketch, the sensor returns "0 cm" and there is no reaction to changes in proximity to objects. I tried using the simplest code I could find which doesn't require libraries (pasted below), but the same thing happens, this time reporting strange negative distances (-39 through - 45). I've found that changing the voltage supply effects the numbers, but only once did I get it to correctly report distance and very briefly. Is it possible the sensor has been damaged in some way? I'm using an Uno Rev 3 and a macbook pro (10.6.8 ) for config.
Code: [Select]
  HC-SR04 Ping distance sensor]
  VCC to arduino 5v GND to arduino GND
  Echo to Arduino pin 13 Trig to Arduino pin 12
int echoPin = 13;
int trigPin = 12;
  Serial.begin (9600);
  pinMode(trigPin, OUTPUT);
  pinMode(echoPin, INPUT);
  int duration, cm;
  digitalWrite(trigPin, LOW);
  delayMicroseconds(20);
  digitalWrite(trigPin, HIGH);
  duration = pulseIn(echoPin, HIGH);
  cm = duration / 29 / 2;
/* Sound velocity=29cm/microsec,
    then divide by 2 because of the return time */
  Serial.print(cm);
  Serial.println(" cm");
teckel
If the unmodified NewPingExample sketch or the sketch you posted don't work, I would guess it's a faulty sensor.  It seems you're doing everything correctly.
Tim
keeper63
teckel:
I've only been keeping up now and then on this thread; I have yet to try the library, but I have to say it seems like an awesome improvement. I was wondering, though, if you were planning on:
1) Adding the original PING sensor from Parallax to it
2) Add code for the Polaroid/Senscomp 6500 sensor
I think the first should be done before the second (if the second is done at all), simply because there are some people out there using PING sensors with the Arduino, and it could potentially benefit from this library.
The second would only be worthwhile if it could support both the actual Senscomp 6500, as well as hacked Polaroid camera modules; these hacked modules are described in various places around the web, but the most recent version was done in an issue of Servo magazine not too long ago. In this version, it was described how to get the "old school" hack to work properly with the Arduino (as the original hack wasn't compatible with the Arduino in some manner). Then again, not many people likely purchase the Senscomp 6500 for the Arduino (they aren't cheap new), and most people probably don't hack old Polaroid cameras either (as it is cheaper and easier to buy the mass-produced dual-element modules).
Maybe the Maxbotix sensors should be done instead...?
:D
I will not respond to Arduino help PM's from random forum users; if you have such a question, start a new topic thread.
E40racer
Has anyone used this library in an obstacle avoiding robot sketch? I have a simple obstacle avoiding sketch that uses an old ultrasonic library, it works. But I wanted to try it with this library. Can I use "Distance = srf06.ping_cm();" in a sketch without the pingtimer/pingspeed code? Or do I have to use the "pingTimer" and "pingSpeed" like in the example? This makes it much harder to use in a sketch. I tried writing a function that returns the distance but I can't get it to work (I'm not much of a programmer).
www.bajdi.com
SANTIMO
I have read up on the prev posts. and i have to say i am impressed.   I have downloaded the V.1.3 and i have to say ...... beautiful. very good work Tim.
Now my question is how to implement this with an obstacle avoiding sketch. yes similar to the question posted by Bajidi
SANTI
cyclegadget
Here is the minimum amount of sketch you need to use the Newping library.
Code: [Select]
#include <NewPing.h>
#define TRIGGER_PIN  12  // Arduino pin tied to trigger pin on ping sensor.
#define ECHO_PIN     13  // Arduino pin tied to echo pin on ping sensor.
#define MAX_DISTANCE 200 // Maximum distance we want to ping for (in centimeters). Maximum sensor distance is rated at 400-500cm.
NewPing sonar(TRIGGER_PIN, ECHO_PIN, MAX_DISTANCE); // NewPing setup of pins and maximum distance.
unsigned int pingSpeed = 50;  // How frequently are we going to send out a ping (in milliseconds). 50ms would be 20 times a second.
unsigned long pingTimer = 75; // Holds the next ping time, start at 75ms to give time for the Arduino pins to stabilize.
  // Notice how there's no delays in this sketch to allow you to do other processing in-line while doing distance pings.
  if (millis() >= pingTimer) { // pingSpeed milliseconds since last ping, do another ping.
    pingTimer += pingSpeed;    // Set the next ping time.
    int cm = sonar.ping_cm();  // Send out the ping, get the results in centimeters.
This is the part that saves the results to a variabable named "cm". You could change "cm" to distance,  length, or fred if it makes you happy.
Code: [Select]
