Topic: NewPing Library: HC-SR04, SRF05, SRF06, DYP-ME007, Parallax PING))) - v1.7 (Read 569965 times) previous topic - next topic
teckel
I'm trying to use an SR04 with the single-pin method, but I can't get it to work.  I've tried it with two different identical looking sensors purchased from Amazon and eBay.  This is on an Arduino Uno (might be a SainSmart recreation but it looks like an authentic one, not sure.
What troubleshooting steps can I try?
Start with supplying your sketch, schematic, and exactly what your results are. "can't get it to work" is too vague to diagnose over the internet with no other information.
Tim
My platforms Arduino, Teensy 3.2, Arduino Pro Mini, ATmega328
My libraries: NewPing, LCDBitmap, toneAC, toneAC2, NewTone, TimerFreeTone
My projects: https://dogblocker.com & https://baconorbeer.com
My beer: Great Lakes Brewing Co. Lake Erie Monster
MetalEd222
really new to arduino and coding, so I am trying to figure out this library.  I have been searching and trying things out on my own, but haven't see any examples of using the 2 commands the way I am attempting.  I think I have figured it out... at least it appears this snippet of my code is working.
What I am trying to do with this is return the center reading (median) out of 15. using convert_in to convert it to inches. I figure returning 15 readings, choosing the median one is the middle between the high and low readings.
Is this correct?
centerDist = (sonar.convert_in(sonar.ping_median(15)));
//median ping (out of 15), distance in inches and assign to centerDist on sensor named "sonar"
I run it and it seems to give me a very accurate reading, in inches.  Is there anything wrong with this format?
teckel
Is this correct?
That's correct.  That command will return the median distance measurement in inches out of 15 pings.  With that many iterations, it should give very stable results.
If you find that the distance is slightly off, it's because of the convert_in() math, which by default simply divides the ping microseconds by 146.  For example, the following code will give the same result:
centerDist = sonar.ping_median(15) / 146;
If you find that you need more accurate conversion from ping time to distance and wish to create a calculation based on temperature readings, you can replace the division by 146 (or the convert_in()) to whatever calculation you wish based on temperature, altitude, humidity, or whatever level of accuracy you wish.  The convert_in() is designed to be fast, create small code, not require additional sensors, and be fairly accurate for almost all users.  If you need higher accuracy, you can use whatever calculations you wish with NewPing.
Tim
teckel
#393
Jul 11, 2013, 07:17 pm Last Edit: Jul 11, 2013, 07:36 pm by teckel Reason: 1
A common problem with using NewPing is getting a `__vector_7' error during compile.  What this error means is that you're using two libraries that are both trying to use timer 2.  The timer 2 stuff is only in NewPing for the timer interrupt method ping_timer().  If you're just using the standard ping(), ping_in(), ping_cm(), or ping_median() methods, NewPing is not using timer 2.  However, the compiler is not smart enough to know that you're not using those interrupts. So you'll get this error if any other library is also using timer 2.
There's an easy solution as long as you're not using ping_timer().  Change the NewPing.cpp program and comment out the section that calls timer 2.  Find this section at around lines 210 - 216 in version 1.5:
#if defined (__AVR_ATmega32U4__) // Use Timer4 for ATmega32U4 (Teensy/Leonardo).
ISR(TIMER4_OVF_vect) {
#else
ISR(TIMER2_COMPA_vect) {
#endif
if(intFunc) intFunc(); // If wrapped function is set, call it.
Comment it all out like this:
#else
#endif
That's it!  Also, if the conflict is with the tone library, you can use a different tone library that doesn't use timer 2.  I've created a couple tone replacement libraries that not only use timer 1 instead of timer 2 to avoid a conflict, they also have many other advantages:
NewTone - About 1,200 bytes smaller code size than the standard tone library. Faster execution time. Exclusive use of port registers for fastest and smallest code. Higher quality sound output than tone library. Plug-in replacement for Tone. Uses timer 1 which may free up conflicts with the tone library.
toneAC - Nearly twice the volume (because it uses two out of phase pins in push/pull fashion). Higher quality (less clicking). Capability of producing higher frequencies (even if running at a lower clock speed). Nearly 1.5k smaller compiled code. Bug fixes (standard tone library can generate some odd and unpredictable results). Can set not only the frequency but also the sound volume. Less stress on the speaker so it will last longer and sound better.
In addition, version 1.6 of the NewPing library (currently under development) will include a setting that allows you to easily turn off the timer 2 stuff if you're not using the ping_timer() method.
If, however you are using the ping_timer() method you still may have options.
First, do you really need to use the ping_timer() method?  Many people incorrectly assume that if they're using multiple sensors they must use the ping_timer() method shown in my 15 sensor example.  That's simply not the case.  It's best to do it that way for "multitasking" reasons.  But, there's no reason why you can't just ping() multiple sensors like in the NewPingExample sketch.
Secondly, maybe you can use a different library that's causing the timer 2 conflict.  I've shown two other tone libraries above that use timer 1 instead of timer 2.  But, if the timer 2 conflict is with a different library, there's still a chance that you have another option.  For example, maybe the timer 2 conflict is with an LED dimmer library.  Try to find another LED dimmer library that uses timer 1 instead.  While this may not be an option for every library, there are many libraries out there so it's worth looking into.
Tim
terryking228
Hi Tim,
This is great information! Many people have no idea about timers and conflicts.
Can you include this in the NewPing documentation, or point to this post there?  I KNOW I'll need this in the future..
Regards, Terry King terry@yourduino.com  - Check great prices, devices and Arduino-related boards at http://YourDuino.com
HOW-TO: http://ArduinoInfo.Info
teckel
Hi Tim,
I have this post linked from the opening post in this thread.  Also, I created Wiki pages for this as well as another common question here: https://code.google.com/p/arduino-new-ping/w/list
Tim
terryking228
Thanks, Tim!  I linked to your WIKI pages from the ArduinoInfo.Info WIKI here:
http://arduino-info.wikispaces.com/UltraSonicDistance
robtillaart
Please use code tags (# button above the smileys)
Please press CTRL-T in the IDE to autoformat the layout before copying, makes it far more readable and debugable,
Thank you
Rob Tillaart
kevin8
// walkerForwardComplete.pde - Two servo walker.
// Complete code with obstacle avoidance
// (c) Kimmo Karvinen & Tero Karvinen http://BotBook.com
// Updated by Joe Saavedra, 2010
#include <Servo.h>
Servo frontServo;
Servo rearServo;
/* Servo motors - global variables */
int centerPos = 90;
int frontRightUp = 72;
int frontLeftUp = 108;
int backRightForward = 75;
int backLeftForward = 105;
int walkSpeed = 150; // How long to wait between steps in milliseconds
int centerTurnPos = 81;
int frontTurnRightUp = 63;
int frontTurnLeftUp = 117;
int backTurnRightForward = 66;
int backTurnLeftForward = 96;
/* Ping distance measurement - global variables */
int pingPin = 4;
long int duration, distanceInches;
long distanceFront=0; //cm
int startAvoidanceDistance=20; //cm
long microsecondsToInches(long microseconds)
 return microseconds / 74 / 2;
long microsecondsToCentimeters(long microseconds)
 return microseconds / 29 / 2;
long distanceCm(){
 pinMode(pingPin, OUTPUT);
 digitalWrite(pingPin, LOW);
 delayMicroseconds(2);
 digitalWrite(pingPin, HIGH);
 delayMicroseconds(5);
 pinMode(pingPin, INPUT);
 duration = pulseIn(pingPin, HIGH);
 distanceInches = microsecondsToInches(duration);
 return microsecondsToCentimeters(duration);
void center()
 frontServo.write(centerPos);
 rearServo.write(centerPos);
void moveForward()
 frontServo.write(frontRightUp);
 rearServo.write(backLeftForward);
 delay(125);
 delay(65);
 frontServo.write(frontLeftUp);
 rearServo.write(backRightForward);
 delay(125);
 delay(65);
void moveBackRight()
 rearServo.write(backRightForward-6);
 delay(125);
 rearServo.write(centerPos-6);
 delay(65);
 frontServo.write(frontLeftUp+9);
 rearServo.write(backLeftForward-6);
 delay(125);
 delay(65);
void moveTurnLeft()
 frontServo.write(frontTurnRightUp);
 rearServo.write(backTurnLeftForward);
 delay(125);
 frontServo.write(centerTurnPos);
 rearServo.write(centerTurnPos);
 delay(65);
 frontServo.write(frontTurnLeftUp);
 rearServo.write(backTurnRightForward);
 delay(125);
 delay(65);
 frontServo.attach(2);
 rearServo.attach(3);
 distanceFront=distanceCm();
 if (distanceFront > 1){ // Filters out any stray 0.00 error readings
   if (distanceFront<startAvoidanceDistance) {
     for(int i=0; i<=8; i++) {
       moveBackRight();
       delay(walkSpeed);
     for(int i=0; i<=10; i++) {
       moveTurnLeft();
       delay(walkSpeed);
   else {
     moveForward();
     delay(walkSpeed);
Moderator edit: Please don't use copy for forum - just cut and paste between code tags.
Was there a question?  AWOL
kevin8
Good day
Sorry I am new to this forum and Arduino. With regards to the insect bot code I posted. The question was, how do I addapt the code to use a 4 pin ultrasonic sensor.
Kind regards
Kevin
robvoi
#400
Jul 23, 2013, 03:47 pm Last Edit: Jul 23, 2013, 07:15 pm by robvoi Reason: 1
first - big thanks for this fantastic library. I used it in two projects so far. Works perfectly.
With my new project I am pushing the Arduino Mega to its limits. I need to drive two steppers - that's the time critical part.
When I enable the pings (using the timer from the 15 sensor example) they sometimes start to stutter as it can't keep the step frequency. As far as I can see it's when the distance to ping is high. If I hold my hand in front of the sensor it's much better.
I went through all the rest of my code. No delays (all implemented as FSM) and no unnecessary complicated calculations.
So I thought it might be possible to get out the last bit of performance with direct addressing of the pins (http://forum.arduino.cc/index.php/topic,46896.0.html) and with an alternative solution on the micros delays in newPing::ping_trigger()
But it is above my capabilities. I assume if it would be simple it would be in the library  XD
Does someone see an "easy" to implement approach? Or am I on the wrong track at all?
Thanks
Robert
teckel
Good day
Kind regards
Kevin
You would change the distanceCm() routine to accommodate a different sensor.
Tim
kevin8
If I understand correctly, I should change the ping pin to trigger pin and add a routine with the echo pin as an input.  I'm sorry that I'm asking in detail, but I'm new to this and my strong point is not programming.
teckel
You would replace that entire routine with something similar to the NewPing example sketch. Probably best to get the sensor working with just the example sketch and then implement it as a replacement to the distanceCm() routine.
Tim
teckel
Thanks
Robert
NewPing is already using port register calls like in digitalWriteFast, so no additional speed would be gained. If there is a timing problem, it has nothing to do with the ATmega processor. The issue would be with the sensor and how quickly you are trying to ping. There's set delays and dead periods with ultrasonic sensors. Try changing the ping to once every 100ms, that get around any kind of delay inherent with the sensor. If you still have a problem, please post your code so someone can maybe point you in the right direction.
Tim
