Long time no post. Other projects demanding time and whatnot..
So, I'm putting together a test PCB design for this. I'd like to accommodate a switched "accessory" input, to provide a clean, protected 5v signal line to the downstream load.
My gut feeling is that the vehicle's accessory input should be protected to the same degree as the 12v power input. I.e., a diode, a TVS, and a current limiting resistor. Since the accessory input only needs to have enough current drive to turn on a MOSFET or something (remember, this just forms a TTL-level indicator), I should be able to use a higher value R1 (I dunno -- maybe even 1k?) and scale back the TVS and D1 diode to lower current parts, right? I'll do some simulations, just thinking out loud for now.
Looking back on car stereos and such, it seems the accessory lead is very rarely fused. But, I see no reason why I should treat it any different, w.r.t. its ability to start an electrical fire if shorted to ground.. Thoughts?
