Topic: Looking for someone to make changes/edits to an existing schematic/pcb (Read 2790 times) previous topic - next topic
xl97
Hey gang...
I have a schematic & pcb file/project (Eagle)..  that I would like to make some changes... and a little re-working of audio/amp portion...   (this is sort of copying the WaveShield from Adafruit hardware/capabilities...but SMD)...
maybe get a second set of professional eyes...(since this is going to fab house?)
PS..
(the board/pcb is SMALL and needs to stay that way.)  :)
thanks
jonisonvespa
#1
May 17, 2012, 07:08 pm Last Edit: May 17, 2012, 07:30 pm by jonisonvespa Reason: 1
i can do this design/edit/smd components any board size,  right down to supplying gerber files for pcb manufacturing, but in return i would like some programming done for a simple task.
did you see my PCB dESIGN  post a few of my pcbs.
http://arduino.cc/forum/index.php/topic,104885.0.html
jonisonvespa
its quit simple, im trying to read a transducer, take a reading from it, if the level falls below a level alarm goes off.
jonisonvespa
#5
May 17, 2012, 07:53 pm Last Edit: May 17, 2012, 08:22 pm by jonisonvespa Reason: 1
hi,
ive sent you my email, can send you a more info.
i noticed youve made a home brew breakout board, ive got one using smd components just add regulated +5v, the bottom one is the best as you can connect to every pin.
xl97
hi-
yes I have made a few DIY board attempts.. ;)
the form factor is also a focus.. (small as can be and still 'usable' of course)..
just learning as I go.. how to home etch..
then learning to work in Eagle.
(get stencils made, pcbs' made.. and re-flow at home too)..etc..
one step at a time..LOL
