Topic: How to get USB-Serial hex back to Arduino UNO Rev3 / solved (Read 19424 times) previous topic - next topic
nickgammon
I got:
Code: [Select]
C:\Documents and Settings\Owner\Desktop>md5sum Arduino-COMBINED-dfu-usbserial-atmega16u2-Uno-Rev3.hex
374845d004d03c6ca0535bb4b6f19235 *Arduino-COMBINED-dfu-usbserial-atmega16u2-Uno-Rev3.hex
Please post technical questions on the forum, not by personal message. Thanks!
More info: http://www.gammon.com.au/electronics
nickgammon
Same as before:
Quote
Code: [Select]
MD5 (Arduino-COMBINED-dfu-usbserial-atmega16u2-Uno-Rev3.hex) = 374845d004d03c6ca0535bb4b6f19235
equuu
#17
May 20, 2012, 11:50 am Last Edit: May 20, 2012, 11:53 am by TT Reason: 1
I get
Code: [Select]
8642f9f240d1d0fdeb1d2f6fb0185452 for mine. Compared to your's which is 21kb, the one I was using so far is a whopping 34kb in size..
And for the one you linked, I get the same MD5 as you do
Code: [Select]
nickgammon
You don't have the right file. Edit the file. It should have this in it:
Code: [Select]
:1000000090C00000A9C00000A7C00000A5C000006B
:10001000A3C00000A1C000009FC000009DC0000060
:100020009BC0000099C0000097C0000048C40000B9
:100030000CC4000091C000008FC000008DC0000003
:100040008BC0000089C0000087C0000085C0000090
:1000500083C0000081C000007FC0000002C100001A
:100060007BC0000079C0000077C0000075C00000B0
:1000700073C0000071C000006FC000006DC00000C0
:100080006BC0000069C0000067C0000065C00000D0
:0A3CF0000FBE01960895F894FFCF6F
:103CFA0001021E948920DCFB120110010000002041
:103D0A00EB03EF2F00000001000109021B00010173
:103D1A000080320904000000FE01020009210300AC
:0A3D2A0000000C000104030904006E
:0400000300003000C9
:00000001FF
nickgammon
It should be 20907 bytes. If it isn't you don't have it.
nickgammon
Try this...
• Go here...
https://github.com/arduino/Arduino/blob/master/hardware/arduino/firmwares/Arduino-COMBINED-dfu-usbserial-atmega16u2-Uno-Rev3.hex
• On the right side, about 1/3 the way down, locate the Raw button
• Right-click Raw
• Click Save Link As
• Save the file to a convenient location
• Retry flipping
equuu
Yep, the second file I downloaded, gets the same md5 and the size is 20907 bytes..
Seems like its the same hex but you could email me yours to be sure? Three's a crowd  :)
nickgammon
If the md5 is the same I don't need to email it. Use that one.
Use the 20907 byte file with the md5 sum of 374845d004d03c6ca0535bb4b6f19235
equuu
#23
May 20, 2012, 05:24 pm Last Edit: May 20, 2012, 05:27 pm by TT Reason: 1
I got it working!!
We were trying to use the wrong HEX all the time.
Instead of Arduino-COMBINED-dfu-usbserial-atmega16u2-Uno-Rev3.hex  I had to use Arduino-usbserial-atmega16u2-Uno-Rev3.hex from here : https://github.com/arduino/Arduino/blob/master/hardware/arduino/firmwares/arduino-usbserial/Arduino-usbserial-atmega16u2-Uno-Rev3.hex
Code: [Select]
md5 ba4b38e08f625cacfbeb3fb4a70d5567
The first sign that got my attention was that this HEX was also 12228 bytes like the HID hex file. They appeared to be identical (at least size-wise).
Although the Flip software is a bit odd and doesn't always upload the hex although it seems to succeed (checked what was uploaded by saving the FLASH as a new file) I finally pulled it off.
Windows greeted me with a new device and after installing the UNO drivers I just successfully uploaded the Blink sketch :)
Amazing how much relief a blinking led can create.
Big thanks to Nick and Coding Badly for your support!
Coding Badly
Sorry about pointing you to the wrong file.  I'm glad you have it working.
paulsoulsby
Wow - this thread just saved me!  Successfully got my Uno r2 to be a USB MIDI device.  Then couldn't get it back to being an Uno again!  Basically all the things in the above posts happened to me too!
I don't have much to add apart from the correct .hex file link doesn't work anymore.  I managed to get the hex file from here: http://roboticsclub.org/redmine/projects/quadrotor/repository/revisions/58d82c77908eee0e1c222f7b38691e6532deb77b/entry/arduino-1.0/hardware/arduino/firmwares/arduino-usbserial/Arduino-usbserial-atmega16u2-Uno-Rev3.hex
