Topic: Arduino cannot run error.... please help (Read 1 time) previous topic - next topic
fxmech
I don't know what happened...  Arduino ran fine last time I used it.  Today I tried opening it and got this message
"Arduino cannot run because it could not create a folder to store your settings."
I have Arduino 022, arduino 1.0 and processing installed in my system....  all three stopped working and give me the same error message.
I checked the preferences.txt file in
C:/users/fxmech/appData/Arduino
reads:
last.sketch5.location=812,40,500,992,819
export.application.fullscreen=false
preproc.imports.list=java.applet.*,java.awt.Dimension,java.awt.Frame,java.awt.event.MouseEvent,java.awt.event.KeyEvent,java.awt.event.FocusEvent,java.awt.Image,java.io.*,java.net.*,java.text.*,java.util.*,java.util.zip.*,java.util.regex.*
editor.font.macosx=Monaco,plain,10
preproc.web_colors=true
last.sketch2.path=C:\Users\fxmech\Desktop\armtests\DavidSUPER_FINALTx_further2\DavidSUPER_FINALTx_further2_pde\DavidSUPER_FINALTx_further2_pde.pde
export.application.platform=true
update.check=true
update.id=9074203461584183919
editor.indent=true
serial.stopbits=1
serial.databits=8
editor.font=Monospaced,plain,12
editor.window.height.default=600
run.options.memory=false
editor.divider.size=2
editor.caret.blink=true
preproc.color_datatype=true
export.applet.separate_jar_files=false
last.sketch3.path=C:\Users\fxmech\Documents\Documents\Arduino\arduino-1.0\libraries\XBee\examples\Series1_Rx\Series1_Rx.pde
editor.update_extension=true
preproc.output_parse_tree=false
run.window.bgcolor=#F0F0F0
console.lines=4
upload.using=bootloader
console.error.file=stderr.txt
run.options.memory.maximum=256
editor.tabs.expand=true
editor.window.height.min=530
editor.keys.home_and_end_travel_far=false
board=diecimila
console=true
run.present.exclusive.macosx=true
last.sketch4.path=C:\Users\fxmech\Documents\Documents\Arduino\arduino-1.0\libraries\LPD8806\EXAMPLES\locoLED23\locoLED23.ino
serial.parity=N
editor.tabs.size=2
console.length=500
last.sketch0.location=-4,-4,1928,1036,854
serial.port=COM19
last.sketch2.location=285,435,500,600,427
run.options=
console.auto_clear=true
update.last=1336766728444
last.sketch4.location=865,4,585,997,824
editor.window.width.min=400
run.present.exclusive=false
export.application.platform.linux=true
last.sketch6.location=215,222,500,600,427
last.sketch5.path=C:\Users\fxmech\AppData\Local\Temp\untitled2133632202565610254.tmp\sketch_mar15f\sketch_mar15f.ino
editor.keys.home_and_end_travel_far.macosx=true
editor.window.height.min.windows=530
run.present.bgcolor=#666666
export.application.platform.windows=true
target=arduino
run.options.memory.initial=64
editor.keys.alternative_cut_copy_paste=true
editor.window.width.default=500
console.output.file=stdout.txt
preproc.substitute_unicode=true
run.present.stop.color=#cccccc
editor.external=false
last.screen.height=1080
last.sketch6.path=C:\Users\fxmech\AppData\Local\Temp\untitled2133632202565610254.tmp\sketch_mar15g\sketch_mar15g.ino
editor.keys.shift_backspace_is_delete=true
editor.window.height.min.macosx=450
last.sketch.count=0
export.delete_target_folder=true
last.sketch0.path=C:\Users\fxmech\Documents\Arduino\Wild_Thumper_Controller3\Wild_Thumper_Controller3.ino
last.serial.location=887,185,837,637
preproc.substitute_floats=true
editor.keys.alternative_cut_copy_paste.macosx=false
serial.line_ending=1
browser.linux=mozilla
editor.invalid=false
serial.debug_rate=9600
sketchbook.path=C:\Users\fxmech\Documents\Arduino
export.application.stop=true
editor.divider.size.windows=2
last.sketch1.path=C:\Users\fxmech\Desktop\armtests\DavidSUPER_FINALTx_further2\DavidSUPER_FINALTx_further2_pde\DavidSUPER_FINALTx_further2_pde.pde
preproc.enhanced_casting=true
run.display=1
last.sketch1.location=810,340,500,600,427
platform.auto_file_type_associations=false
editor.antialias=false
programmer=arduino:avrispmkii
last.sketch3.location=620,40,1059,817,644
preproc.save_build_files=false
last.screen.width=1920
export.application.platform.macosx=true
I do have a folder called C:/users/fxmech/My Documents/Arduino
and my sketches are in there...
User fxmech is the administrator (and only) user on this windows 7 PC....
Any ideas???   I tried re uploading Arduino 1.0 and installing it in a new folder for that one gave me the same error message....
fxmech
OK looks like the problem is solved.
The fix was to go to the Arduino.exe file and open up the properties and within that choose RUN AS ADMINISTRATOR...
Not sure what changed them all...  maybe a windows update????
Hope this helps if any one else runs into the same issue.
Nishant_Sood
Most probably a systems settings was altered by the firewall or you or the upadate ,any one of the three causing Run as Administrator needed.
"Real Men can Accomplish  Anything"
- skype : nishants5
ਫ਼ਤੇਹ ਕਰੁਂ!
www.winacro.com
