Topic: Using mini breadboard to make connections without power distribution buses (Read 5171 times) previous topic - next topic
LouSag
Hi I am new to Arduino, and would appreciate your help/advice.
I have just purchased a mini breadboard for a small project, the link is outlined below.
http://www.jaycar.com.au/productView.asp?ID=PB8832
However, unlike the typical breadboards I have researched this breadboard does not have power distribution buses.
I have an 8x2 LCD Display and 2 Infrared Proximity Sensors which I would like to connect to the board as a result of their multiple connections to GND and 5v pins on the Arduino Uno Board.
How can I connect these components to the breadboard if there is no power buses?
Thanks in Advance
dkl65
I guess you have to use a few of the 5 pin rows (A-E) as GND and V+. The connection is messier. You know how breadboard's internal connetions work, right? I have a small red breadboard without the rails, too. I got a full sized breadboard for $6.75 later.
lemming
Plug your positive power into socket A1 and your negative into J1.
B1, C1, D1 and E1 will now be your positive rail and F1, G1, J1 and I1 will be your negative rail. If you need more, then bridge to row 2 or maybe to a row at the opposite end of the board (e.g. row 30 or closer to your group of components).
terryking228
Some info on breadboarding here:  http://arduino-info.wikispaces.com/LowCostStarterSet-Connecting-Breadboarding
For $2.50 I really like these breadboards:  8Cm Breadboard with power buses
DISCLAIMER: Mentioned stuff from my own shop...
Regards, Terry King terry@yourduino.com  - Check great prices, devices and Arduino-related boards at http://YourDuino.com
HOW-TO: http://ArduinoInfo.Info
