Forgive me, but i've spent the majority of my life focusing on software development, and have a very weak knowledge of electrical engineering concepts, but hey, that's why i got an arduino!
now, this isnt what you're most likely expecting, i'm familiar with the reasons and construction of a transistor/diode/resistor setup for triggering a relay with the arduino, but i want to be 100% certain i'm setting up the 12v power source correctly, and that i ultimately wont set my car on fire...
I've got a TIP120 Transistor triggering a 40A 12v Automotive Relay, and if im certain of anything, its that taking a screwdriver and shorting out the terminals of a car battery is a pretty bad idea... as far as the construction of a relay is concerned, on the coil side, its simply a spool of wire wrapped around an iron rod... my question is, how is it that you properly power the coil of a relay in a car? does the relatively thin wire of the coil prevent the sudden and nearly instantaneous transfer of power that we see with Mr Screwdriver? am i required to somehow step something down to safe levels to prevent the relay from effectively shorting out the battery, or will it only draw as much current as is necessary to itself?
