Topic: Pure AVR equivalent of attachInterrupt() ? (Read 2618 times) previous topic - next topic
cmagagna
I'd like to add a "system halt" button to my mill running GRBL. The button is on D2, hardware interrupt 0. In Arduino-speak I can set it up with attachInterrupt(0...) but for GRBL I need a pure AVR C implementation.
Before I start trying to pull apart the source code in WInterrupts.c etc. I was wondering if anyone's already done this or has a reference to an example.
Thanks in advance.
Coding Badly
Processor?
Trigger (CHANGE, RISING, FALLING, LEVEL)?
cmagagna
I apologize. I'm using a Uno with a 328P and would like the trigger to be on RISING.
Thanks!
Coding Badly
For INT0 on the 328 processor, we end up at the interrupt service routine on line #276...
https://github.com/arduino/Arduino/blob/master/hardware/arduino/cores/arduino/WInterrupts.c#L276
We'll use the modern macro instead of the deprecated SIGNAL macro...
ISR( INT0_vect )
  // Your stuff goes here
The EICRB register does not exist does we end up with this initialization code on line #95...
https://github.com/arduino/Arduino/blob/master/hardware/arduino/cores/arduino/WInterrupts.c#L95
      EICRA = (EICRA & ~((1 << ISC00) | (1 << ISC01))) | (mode << ISC00);
      EIMSK |= (1 << INT0);
RISING is defined as 3...
https://github.com/arduino/Arduino/blob/master/hardware/arduino/cores/arduino/Arduino.h#L40
...so the initialization code becomes this...
      EICRA = (EICRA & ~((1 << ISC00) | (1 << ISC01))) | (3 << ISC00);
And, we're done.
cmagagna
That's great, thanks! I won't be able to test it out until tomorrow evening but I'll let you know how it goes.
Thanks again.
cmagagna
It compiled fine but didn't function until I added
#include <avr/interrupt.h>
Once I did that it worked as designed.
Thanks again for your help.
Coding Badly
Excellent.  I'm glad you have it working.
