Topic: Leonardo drivers for W7 (Read 56408 times) previous topic - next topic
Bemused
Hi, first post here.
Just had my first Arduino, a Leonardo.
Cant get the usb drivers on windows.
I get the message 'windows was unable to install your arduino leonardo bootloader'
The device is listed in device manager under \ other devices \ arduino leonardo bootloader.
Hope you can help me get over this first hurdle
Tony
Louis Davis
You should be able to install the driver for this device by pointing to the Arduino\Drivers folder.
Right click the device in Device Manager \ Other Devices
Select Update Driver Software
Select Browse my computer for software
Click Browse button
Select the Drivers folder under the location of your Arduino software installation
Click OK
Click Next
Bemused
#2
Jun 01, 2012, 06:08 pm Last Edit: Jun 01, 2012, 06:12 pm by Bemused Reason: 1
Thanks Louis
I can get to your Click OK step but windows says
windows could not find driver software for your device
before I can get to Click Next step
I know I will look back in this with amusement when I work out what is wrong but right now its been four hours of frustration.
Tony
Louis Davis
What version of the IDE do you have?
It needs to be 1.0.1: http://arduino.googlecode.com/files/arduino-1.0.1-windows.zip
Make sure you are selecting the Drivers folder(see attached image)
Bemused
Yes version and method just like your instruction.
Device manager adds two devices that I can see when the Leonardo is connected.
Device Manager \ Other Devices \ arduino leonardo bootloader
The drivers for this device are not installed. (Code 28)
this has the yellow ! and is what I try to install drivers for.
Device Manager \ Human interface devices \ USB input device
This device is working properly.
Tony
Louis Davis
Open Device Manager
Right Click the Device Manager \ Other Devices \ arduino leonardo bootloader
Select Properties
Select Details tab
Choose Hardware Ids from the Property drop-down
Send us the Hardware Ids that show in the Value section.
Bemused
Hardware Ids
USB\VID_2341&PID_0034&REV_0100&MI_00
USB\VID_2341&PID_0034&MI_00
Louis Davis
It looks like you must have an older version of the bootloader because the Arduino Leonardo.inf file is looking for:
USB\VID_2341&PID_0036
It looks like Arduino IDE 1.0 has the Arduino Leonardo.inf that has that hardware ID.
Since I am not that familiar with the Leonardo, I am not sure the bootloader on your board is compatible with the 1.0.1 IDE.
I have seen mention in the forum that the Leonardo bootloader changed just before the official release.
Hopefully someone else can step in a clear this up.
Bemused
Thanks Louis, you seem to have found my problem pretty fast, I was sure it was me doing something sooo stupid.
Not sure what the boot loader is, boot loader is initiated at run time from firmware maybe.
I have just been surfing and discovered there are different (clone) Leonardo on the market.
I had mine from http://www.olimex.com/dev/olimexino-32u4.html
At the bottom of the above page it mentions
Quote
Latest BOOTLOADER for ARDUINO IDE 1.0.1
Thanks
Tony
Bemused
#9
Jun 01, 2012, 08:29 pm Last Edit: Jun 01, 2012, 08:43 pm by Bemused Reason: 1
I down loaded 1.0.0 and the usb drivers are installed  :smiley-mr-green:
Arduino Leonardo on com 3
No Leonardo in the board choice though so will put 1.0.1 back on and see what happens
So 1.0.1 back and tried to upload blink, failed a few times giving
Quote
avrdude: ser_send(): write error: sorry no info avail
So I guess I need to burn the updated boot loader, might need some direction on this.
Many thanks
Tony
mellis
Bemused, if you're using an Olimex board, you should ask them for help.  Unfortunately, we can't support other people's products (because we don't know how they work, etc).
Bemused
Ok, just working out what I have done.
Sorry I did not know the product was not yours.
Help here has been great so point me to a url to buy your Leonardo please.
Tony
mellis
We have a list of distributors here: http://arduino.cc/en/Main/Buy
For example, Adafruit in the US: http://www.adafruit.com/products/849
Or the Arduino store here: http://store.arduino.cc/ww/index.php?main_page=product_info&cPath=11_12&products_id=225
http://store.arduino.cc/ww/index.php?main_page=product_info&cPath=11_12&products_id=226
Bemused
Ok so I just ordered an official Leonardo from one of your links, this will come with a 1.0.1 compatible bootloader I expect.
From this new standpoint I will be able to re-flash the the hooky Leonardo via the official working Leonardo?
Many thanks
Tony
Bemused
So I found the Leonardo board commented out in the
c:\arduino-1.0\hardware\arduino\boards.txt" file
I removed the comments, Leonardo appeared in the boards menu and we are away having a little fun.
Tony
