So I've wired up a little robot with a sound shield and some sensors. I'm trying to write a sketch that will let check the sensors.
What I'd like for it to do is print out a little menu over serial, wait until the user sends a selection, jump to the function that matches their selection, then (once the function is done) jump back and print the menu again. What it actually does is just loop the menu again and again, completely bypassing the while loop (I've tested this by putting a Serial.print in the loop to see if it gets in or not).
Here's what I've written, but I'm not a that good of a coder, so it doesn't work. Where am I going wrong?
#include <Servo.h>
Servo steering;
Servo throttle;
int pos = 0;
int val = 0;
void setup(){
throttle.write(90);
steering.write(90);
pinMode(A0, INPUT);
pinMode(7, INPUT);
char ch = 0;
void loop(){
Serial.println("Menu");
Serial.println("--------------------");
Serial.println("1. Motion Readout");
Serial.println("2. Distance Readout");
Serial.println("3. SD Directory Listing");
Serial.println("4. Sound Test");
Serial.println("5. Car Test");
Serial.println("Type the number and press enter");
while(char ch = 0){
ch = Serial.read();
char ch;
switch(ch)
case '1':
motion();
ch = 0;
//menu over, lets get to work.
void motion(){
Serial.println("Haha, it works!");
I'm pretty sure a While loop is the right thing to do, but I'm probably implementing it wrong. Can anyone shed some light on this?
