Topic: OBD.h not compiling (Read 3111 times) previous topic - next topic
stoopkid
I just got an OBD library here. I opened an example sketch and tried to upload it but got errors that I do not understand.
code:
Code: [Select]
* Sample sketch based on OBD-II library for Arduino
* Distributed under GPL v2.0
* Copyright (c) 2012 Stanley Huang <stanleyhuangyc@gmail.com>
* All rights reserved.
#include <OBD.h>
COBD obd;
  // we'll use the debug LED as output
  pinMode(13, OUTPUT);
  // start serial communication at the adapter defined baudrate
  Serial.begin(OBD_SERIAL_BAUDRATE);
  // initiate OBD-II connection until success
  while (!obd.Init());
  int value;
  if (obd.ReadSensor(PID_RPM, value)) {
    // RPM is read and stored in 'value'
    // light on LED when RPM exceeds 5000
    digitalWrite(13, value > 5000 ? HIGH : LOW);
errors:
Quote
In file included from rpm_led.cpp:8:
C:\Users\Nick\Documents\Arduino\libraries\OBD/OBD.h:46: error: 'byte' has not been declared
C:\Users\Nick\Documents\Arduino\libraries\OBD/OBD.h:48: error: 'byte' does not name a type
C:\Users\Nick\Documents\Arduino\libraries\OBD/OBD.h:49: error: 'byte' does not name a type
C:\Users\Nick\Documents\Arduino\libraries\OBD/OBD.h:54: error: 'byte' has not been declared
C:\Users\Nick\Documents\Arduino\libraries\OBD/OBD.h:55: error: 'byte' has not been declared
C:\Users\Nick\Documents\Arduino\libraries\OBD/OBD.h:75: error: 'byte' does not name a type
C:\Users\Nick\Documents\Arduino\libraries\OBD/OBD.h: In constructor 'COBD::COBD()':
C:\Users\Nick\Documents\Arduino\libraries\OBD/OBD.h:41: error: 'dataMode' was not declared in this scope
C:\Users\Nick\Documents\Arduino\libraries\OBD/OBD.h:42: error: 'errors' was not declared in this scope
OBD.h is located in "C:\Users\Nick\Documents\Arduino\Libraries\OBD"
I've tried with IDE 1.0 and 1.0.1. What could be causing this?
Thanks
Coding Badly
#1
Jun 07, 2012, 09:06 am Last Edit: Jun 07, 2012, 09:08 am by Coding Badly Reason: 1
• Locate and open OBD.h in your favourite text editor
• Change the top of the file to this (basically add the #ifndef through the #include)...
Quote
[font=Courier New]/*************************************************************************
* OBD-II (ELM327) data accessing library for Arduino
#ifndef OBD_h
#define OBD_h
#include <Arduino.h>
#define OBD_TIMEOUT_SHORT 2000 /* ms */
#define OBD_TIMEOUT_LONG 7000 /* ms */[/font]
• Add a #endif to the bottom of the file...
Quote
[font=Courier New]   virtual char ReadData();
   virtual byte WriteData(const char* s);
#endif[/font]
• Save and close OBD.h
• Try again (you do not need to restart the IDE)
stoopkid
Thank you that got it to compile... However I'm still having trouble, it doesn't seem to respond to the device. I think it was incorrect for me to assume that this USB device could be interfaced as easily as an RS232 one.
Coding Badly
You are welcome.  I don't have any experience with OBD so I can't help with the next problem.
