Topic: What is the status of serial on a tiny85 (Read 19247 times) previous topic - next topic
Osgeld
I have use for software serial on a ATTINY85 using arduino tiny, what is the status of serial communications? I started to design a board and thought I better check, using the 1.0 included lib results in issue 49 ... any work arounds? I just need to receive streams of characters
Thanks
http://arduino.cc/forum/index.php?action=unread;boards=2,3,4,5,67,6,7,8,9,10,11,66,12,13,15,14,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,86,87,89,1;ALL
Coding Badly
I have not tried it myself.  As far as I know, the solution is...
http://arduino.cc/forum/index.php/topic,58756.msg422560.html#msg422560
http://arduino.cc/forum/index.php/topic,51984.msg472041.html#msg472041
Osgeld
#2
Jun 08, 2012, 05:47 am Last Edit: Jun 08, 2012, 05:52 am by Osgeld Reason: 1
cool, I will play around with it tomorrow and over the weekend (search was failing me)
at work they tore down quite a few old test carts that were in storage, our lab is now the proud owners of 7 boards containing 24, 60 volt, 3 amp SSR's each, and I would rather not use the old ISA machines they were attached to ... FTDI cable + tiny + 595's = happy
Coding Badly
Please report back with a thumbs-up or thumbs-down.
Quote
60 volts?  What were they controlling?  Motors?
Quote
If you use the internal oscillator, how have you been tuning (or do you)?
Osgeld
Quote
will do
Quote
no light testers @ 13VDC, the current was the important part
Quote
I havent been before
Coding Badly
If you decide to tune let me know.  I have something that should make the process painless.
Osgeld
ok well the software serial included in 1.0...
Quote
formerly NewSoftSerial
does not contain the lines given in the link above, so I am going to get the older verion and see what happens
Osgeld
here is what I am getting with the "new" software serial included in 1.0
Quote
In file included from Blink.cpp:1:0:
/usr/share/arduino/libraries/SoftwareSerial/SoftwareSerial.h:92:18: error: conflicting return type specified for 'virtual size_t SoftwareSerial::write(uint8_t)'
/usr/share/arduino/hardware/arduino/cores/tiny/Print.h:71:18: error:   overriding 'virtual void Print::write(uint8_t)'
Osgeld
nothing I try seems to work, and I cant find a older version of new soft serial
crap  =(
Coding Badly
NewSoftwareSerial 10c from this post does not work?
Coding Badly
here is what I am getting with the "new" software serial included in 1.0 ...error: conflicting return type specified for 'virtual size_t SoftwareSerial::write(uint8_t)'
Several folks are complaining about that problem.  I'll try to get it knocked out this week.  The problem is that the Tiny Core still includes Print.* from 0022.  You may be able to drop in the two files from 1.0.  Wait, that probably won't work.
Osgeld
Osgeld
I used
http://hlt.media.mit.edu/?p=1695
and its quite crappy but I was able to get 2400 baud to work properly once tonight @8Mhz, maybe with a arduino tiny tuneup I can get it consistant, and maybe faster (though I am sending 3 whole bytes at a time speed isnt really an issue here)
Coding Badly
Perfect!  That is exactly what I needed to know.  I've been trying to set aside some time to run that exact test.  Thank you for posting!
I can now go back to mucking with the TIny Core.
Quote
If you want to test drive an experimental replacement let me know.
Coding Badly
Please give this a try...
http://arduino-tiny.googlecode.com/files/arduino-tiny-0100-0014.zip
Only support for the ATtiny85 family was added.  After a few folks have tested it, I will add support for the ATtiny84 family and the ATtiny2313 family.
If anyone reading this tests SoftwareSerial with the Tiny Core, please report back.
