Topic: What is the status of serial on a tiny85 (Read 19248 times) previous topic - next topic
Erni
Success.
I tried with attiny85 at 8Mhz and it worked just fine.
I only tried with 4800, but will  test with higher baudrate.
my test sketch:
Code: [Select]
#include <SoftwareSerial.h>
const int rx=2;
const int tx=3;
SoftwareSerial mySerial(rx, tx);
int i=0;
char buf[10];
  pinMode(rx,INPUT);
  pinMode(tx,OUTPUT);
   mySerial.begin(4800);
  if (mySerial.available()>0){
    buf[i]= mySerial.read();
    if (int(buf[i])==13 || int(buf[i])==10 ){  //If Carriage return has been reached
        mySerial.println(buf);
      for(int x=0;x<=8;x++){
      buf[x]=' ';
     i=0;  //start over again
    } //if enter
    i++;
    } //IF mySerial.available
}//LOOP
JohnO
Hi, I am keen to see this fix in the tiny84 currently I get the compile error:
C:\Users\John\Documents\arduino\libraries\jeelib/Ports.h:325: error: conflicting return type specified for 'virtual void UartPlug::write(byte)'
C:\Dropbox\SKETCHES\hardware\tiny\cores\tiny/Print.h:73: error:   overriding 'virtual size_t Print::write(uint8_t)'
Erni
In the first sketch I used the serial monitor as input.
Now I tried this sketch on my Uno, connected UNO tx->tiny rx
It works as it should, no garbled characters and at 9600 baud.
I use a CP2103 serial/USB converter from Ebay to test the output from the Tiny
Code: [Select]
int x=0;
char buffer[10];
  sprintf(buffer, "Test:%03d",x);
Serial.println(buffer);
  x++;
}//LOOP
Coding Badly
With the version in Reply #14?
Coding Badly
JohnO
Hi, I tried the above version before posting. It doesn't appear to clear the issue for me.
Coding Badly
Where did you get this file...
JohnO
This file is part of the jeelib library: https://github.com/jcw/jeelib/
Do you think the issue is in this library?
Coding Badly
You will have to use a previous version of the Tiny Core...
http://arduino-tiny.googlecode.com/files/arduino-tiny-0100-0013.zip
JohnO
No joy yet I'm afraid:
In file included from TinyRF12_Demo.cpp:7:
C:\Users\John\Documents\arduino\libraries\SoftwareSerial/SoftwareSerial.h:92: error: conflicting return type specified for 'virtual size_t SoftwareSerial::write(uint8_t)'
C:\Dropbox\SKETCHES\hardware\tiny\cores\tiny/Print.h:71: error:   overriding 'virtual void Print::write(uint8_t)'
I replaced my tiny & tools directory with the ones in arduino-tiny-0100-0013.zip
Thank you for spending time on this.
Coding Badly
Please post the sketch you are trying to compile.
JohnO
Coding Badly
I hate to be a pain but in the long run it will be worth it...
• Remove the previous version of the Tiny Core (arduino-tiny-0100-0013.zip).
• Install the latest version of the Tiny Core...
http://arduino-tiny.googlecode.com/files/arduino-tiny-0100-0014.zip
• Navigate to the [font=Courier New]libraries/JeeLib[/font] directory
• Locate and open [font=Courier New]Ports.h[/font] in a text editor
• Towards the top of the file make this change...
Quote
[font=Courier New]// keep the ATtiny85 on the "old" conventions until arduino-tiny gets fixed
#if ARDUINO >= 100 // && !defined(__AVR_ATtiny84__) && !defined(__AVR_ATtiny85__) && !defined(__AVR_ATtiny44__) && !defined(__AVR_ATtiny45__)
#define WRITE_RESULT size_t
#else
#define WRITE_RESULT void
#endif[/font]
• Save and close [font=Courier New]Ports.h[/font]
• If the Arduino IDE was running, close it and restart it
• Try again to compile the sketch
JohnO
You are certainly not a pain! I have made the changes you recommended and you have indeed move the problem forward. I am now seeing:
C:\Users\John\Documents\arduino\libraries\SoftwareSerial\SoftwareSerial.cpp: In member function 'void SoftwareSerial::begin(long int)':
C:\Users\John\Documents\arduino\libraries\SoftwareSerial\SoftwareSerial.cpp:396: error: 'digitalPinToPCICR' was not declared in this scope
C:\Users\John\Documents\arduino\libraries\SoftwareSerial\SoftwareSerial.cpp:398: error: 'digitalPinToPCICRbit' was not declared in this scope
C:\Users\John\Documents\arduino\libraries\SoftwareSerial\SoftwareSerial.cpp:399: error: 'digitalPinToPCMSK' was not declared in this scope
C:\Users\John\Documents\arduino\libraries\SoftwareSerial\SoftwareSerial.cpp:399: error: 'digitalPinToPCMSKbit' was not declared in this scope
C:\Users\John\Documents\arduino\libraries\SoftwareSerial\SoftwareSerial.cpp: In member function 'void SoftwareSerial::end()':
C:\Users\John\Documents\arduino\libraries\SoftwareSerial\SoftwareSerial.cpp:414: error: 'digitalPinToPCMSK' was not declared in this scope
C:\Users\John\Documents\arduino\libraries\SoftwareSerial\SoftwareSerial.cpp:415: error: 'digitalPinToPCMSKbit' was not declared in this scope
Coding Badly
Do you have an ATtiny25, ATtiny45, or ATtiny85 board selected?
