Topic: random led blink code check (Read 14437 times) previous topic - next topic
Arrch
so how do i make them fade between each phase ?
Look at the Fade example for the code to use in place of just turning the LED off.
Sembot
Hai ,
Fantastic project, this is what I was looking for to make my drawbot work autonomously
I still have a question, is it possible to burn the 2 LEDs that I use simultaneously as random
So you could choose between 1led on, or 2nd led on or both on in random
Can you help me please
Code: [Select]
int ranNum;
int ranDel;
  Serial.println("Starting new Random Number Sequence");
    randomSeed(analogRead(0));          // Seed RNG from analog port.
 pinMode(2, OUTPUT);                    // Setup 2 output ports for LED's
 pinMode(3, OUTPUT);
    ranNum=random(2,4);                 // Generate random number between 2 and 3
    ranDel=random(25,300);              // Generate random delay time 25,300
    digitalWrite(ranNum, HIGH);         // Turn on the LED
    delay(ranDel);
    digitalWrite(ranNum, LOW);          // Turn off the LED
    delay(ranDel);
  Serial.print("The Random Number is = ");
  Serial.println(ranNum : ranDel) ;
  //Serial.print("The Random Delay is  = ");
  //Serial.println(ranDel);
