Topic: SD error 0XA and 0X1 when changing to net supply (Read 1 time) previous topic - next topic
dieselboris
Jun 12, 2012, 09:05 pm Last Edit: Jun 12, 2012, 09:51 pm by dieselboris Reason: 1
Hi all,
I use the SdFat library.
I log data from 8 accelerometers at 50 hz on a SD card. While this works fine when the arduino is fed trough power supply instead of USB, the sd card module stops working. It states
Code: [Select]
Can't access SD card. Do not reformat.
SD errorCode: 0XA
This typically happens when i first power on USB, then (while running) plug the net supply and press reset.
Sometimes the reported code is 0X1. I cannot reproduce when this happens exactly.
I read in another post that this could be due to power issues: http://arduino.cc/forum/index.php?topic=87325.15;wap2
Since i change the power supply it seems most likely that this is the source of my problem.
What can i do to fix this?
EDIT: i think i need this: http://www.ladyada.net/library/equipt/diypsupp.html Please confirm!
Thank you
my adapter:
