Topic: help on schematic (Read 14367 times) previous topic - next topic
Maks
Hello,
I looking for some good soul that might be able to do me a great favour.
i've found a company that fabs the boards for me at a good price but they ask some gerber files with the board design, though i've never done anything like that before so, i asking if anyone can make the board design for me, its not that big, the components i can list so you can get a picture of what i need.
Board dimensions: 3,5 x 1,5 cm
1 relay
3 resistors
2 diodes
2 transistors
1 ht12d (decoder)
1 rf module 315Mhz
and thats it... i know how the pieces needs to be, though i cant understand how to make it using computer software like Eagle or something.
Thanks in advance.
PS- Sorry if this is not the right place for the subject
CrossRoads
Sure, draw up how you want them connected.
Maks
thank you very very much for being ready to help, i know its a pain in the *** when someone basically comes and ask to do the job for them, im sorry about that...
about the draw, you prefer like a schematic or like the board as it should be, with holes and everything?
about the components, do you want the datasheet for every one of them?
i have a perforated pcb i can draw on it and take a picture, i think that way it will make your job easier no?
again, thank you very much, i really appreciate
Ps. ill send you a pm with my msn, in case you need have some quick questions
Maks
#3
Jun 14, 2012, 11:56 pm Last Edit: Jun 15, 2012, 12:58 am by Maks Reason: 1
i found a way to use other software then convert it to gerber, though im afraid that it might not be weel executed by me, can you check it for me please?
Thanks in advance
attach: gbr file and print
PS- if you can improove it feel free to
CrossRoads
I can't make gerbers without a schematic, eagle requires schematic entry first, pulls in PCB footprints from there.
Maks
i hope this is what you need...
Thanks in advance
CrossRoads
Any part numbers available for that?
CrossRoads
Try this
Maks
#8
Jun 16, 2012, 03:41 pm Last Edit: Jun 20, 2012, 07:22 pm by Maks Reason: 1
hello,
this looks good, though i think i mislead you on the relay when i did the chematic, i was at work and i used what i found most similar so sorry for that...
My relay is a latching relay, and the configuration is different.
Relay (RT314F05): http://elcodis.com/parts/3805534/RT314F05.html#datasheet
diode (1N4004): http://www.diodes.com/datasheets/ds28002.pdf
transistor (BC548B): http://www.datasheetcatalog.org/datasheet/philips/BC546_547_3.pdf
3 way terminal: http://www.123dapp.com/123D-3D-Model/3way-Terminal-Block/597576
decoder (HT12D): https://courses.cit.cornell.edu/ee476/FinalProjects/s2008/cl457_yft2/cl457_yft2/datasheets/HT12D.pdf
rf receiver : http://www.ebay.co.uk/itm/433Mhz-RF-transmitter-and-receiver-kit-Arduino-ARM-MCU-/230781136559?pt=UK_Sound_Vision_Other&hash=item35bba0aeaf#ht_1271wt_905
Im sorry and thank you
Maks
hello,
any news? im excited on get things going :D
Thanks
CrossRoads
Sorry, have been working other things, have not had time to work up new symbols for your parts.
Also, Does this board connect to the Tx module or to the Rx module?
What would help is a schematic of what you want.
I took a shot at it, you have a different circuit mind, please post what that is and we can go from there.
Maks
it connects to a rx module.
a schematic? what i post a few posts back wasnt a schematic like you wanted?
basically is a receiver module that after receiving the command will turn on/off a light/equipament...
The image you sent was pretty good with the exception of the realy and sv12 the should be a 3way terminal, for the rest i thought it was perfect...
If you can send me the file from eagle maybe i can try to change this 2 little things and show you so you can check if i messed up..
Thank you
CrossRoads
Put both in the same folder.
Do  not make changes to one without the other being open; that will corrupt their shared data.
Maks
your files gave me an error, "invalid data..."
im using eagle version 5.11.0 light
CrossRoads
Upgrade to 6.0, 6.2 light.
