Topic: Problem measuring servomotor current (Read 8773 times) previous topic - next topic
Ischia
I'm trying to measure how much current my servo motor pulls in order to setup the circuit properly (I have to reduce 9V to 6V for the servo). The servo is a Futaba S3003.
The problem is, I can only get normal behavior when my multimeter's plug is in the 10A (unfused) connector. I get readings between 0.1 and 0.4 (therefore 100 and 400 mA), but when I plug the cable into the "mA" (fused) connector the servo behaves very strangely, and stops responding to commands.
I'm not sure I'm checking this correctly so please help if you can.
Also, the manufacturer doesn't list the operating current of the device. Any way to figure this out easily, or do I just need to check different transistor values in series and see which is the minimum current for proper operation?
Thanks.
DuaneB
Read the two links in my signature for an idea of the current draw and how you need to build your circuit to cope with it.
Duane B
Ischia
Thank you, both posts are helpful for the beginner that I am, but I still don't understand why my multimeter behaved the way it did. There is also a big difference between the current you measured and the one I did. I'm not saying you're wrong, of course, just trying to understand what's going on here...
MarkT
The lower current-measuring range has too much series resistance, so the servo is dropping supply voltage when it tries to draw current.  Expect the peak currents to be several amps, the multimeter can't follow the fast spikes.
Ischia
Thank you very much! Much clearer now.
DuaneB
I assume that you are not putting any load on your servos yet, this will greatly increase the current draw as well.
Duane B
rcarduino.blogspot.com
Ischia
I will be testing some loads this afternoon. Have you noticed major increases in 60° speed with light loads (weighing as much as a small-to-average screwdriver)? I will be needed very small travels (10°) but they'll need to be fast. I have 5 x S3003 plugged into a 5.2A 6V power supply.
zoomkat
Quote
You also need to measure the voltage drop from your power supply when the servos are under load. Measuring short duration events may not be easy using inexpensive test equipment.
Google forum search: Use Google Search box in upper right side of this page.
Why I like my 2005 Rio Yellow Honda S2000  https://www.youtube.com/watch?v=pWjMvrkUqX0
oric_dan
Quote
http://rcarduino.blogspot.com/2012/04/servo-problems-with-arduino-part-1.html
One problem is, Duane does not say how he made the servo current measurements.
Servo current is not a simple D.C. value, so it's unclear if a DMM will give an accurate
value.
When the servo is not loaded, the current tends to have a pulse waveform, with the
pulse being about 2-msec long and occurring every 20-msec, in step with the signal
input. When the servo is "statically" loaded, ie twisting the servo horn, this pulse
gets longer, up to 8-10 msec long. When the servo is moving, the waveform is much
more complicated, and has an average value, a lot of ripple, and some noise spikes.
So, it depends upon how you measure it.
Docedison
Very MUCH so. Consider a meter that 'samples every 1/3 second for an update of 3/sec... If a current pulse occurs during the in between time (non sampled) then the meter will not see it except the amount of current flowing when the meter does sample. In effect you have in the meter a high pass filter and will begin to give accurate readings when Fsample = Fload or direct multiples thereof. Ideally the meter should sample @ 2X Fload and multiples of that. This point is if I remember properly called the Nyquist frequency and is considered the minimum sampling rate. These meters work well with regular recurring ac wave forms and all are specified with a minimum measurement frequency. Your real issue is that you have not met that minimum frequency and your measurements are far too low in frequency to be accurately sampled and reported on the display. There is another more complicated factor and that is the waveform of the load current. Absolute current measurements are best done with a 'sampling' resistor and an O'scope since the O'scope can be set to trigger on the change and report the absolute or peak current which should be taken into account when specifying power sources, remember that wiring, switches, fuses are all series resistances and therefore affect the 'available' current. a 6V 10 A battery @ 10 ohm load will never deliver the whole 10A current, it will over time but the peak current can only be the short circuit current or 6A. It will deliver the whole 10A but over time/resistance.. it will deliver 6 A for 10/6 hours or 1 2/3 hours. a rather big difference... IMO
Doc
--> WA7EMS <--
"The solution of every problem is another problem." -Johann Wolfgang von Goethe
I do answer technical questions PM'd to me with whatever is in my clipboard
zoomkat
With these types of measurements I fall back to my old analog multimeter.
Docedison
Use a scope and sampling resistor, an analog meter will only give accurate information about RMS (Root Mean Square) voltages and only for periodic waveforms that are sinusoidal in nature. As you depart from a sine wave to a pulse the meter averages the readings and thus doesn't even come close to the required or load current measurement which can lead you in a decidedly wrong direction as I tried to point out in my last post. That was the reason for the battery and load example. Remember that a Fourier transform will show that the faster the rise time of a pulse the more energy there is in it and when time converges to 0 the current becomes infinite that is IF the current can rise in 0 time it is infinite in value.
It is the Current pulses that drive the stepper/servo, coil or relay, not the available voltage.
Doc
--> WA7EMS <--
zoomkat
Use a scope and sampling resistor, an analog meter will only give accurate information about RMS (Root Mean Square) voltages and only for periodic waveforms that are sinusoidal in nature. As you depart...
Totally impractical hanger flying for a simple servo setup.  :smiley-roll-blue:
Ischia
Thank you, if I go the scope & RMS route I'll surely be diving into much deeper territory that I need right now, instead of figuring out if what I'm building is doable in the first place... I'll get back to the current issue when I've made some progress (unless I set the house on fire first).
Docedison
I really brought up all that cr*p to point out how easy it is to be fooled by measurements that from all outward indications look good both in data returned and technique. Frequently there is more than appears on the surface, it helps a little to consider how a device works before attempting to power it up... Saves a world of wasted time and measurement as well...
Doc
--> WA7EMS <--
