Topic: My first robot (Read 12525 times) previous topic - next topic
hoff70
I wasn't planning on getting into robots with the Arduino but I saw this at the dollar store for five bucks:
A few hours later it was this:
Pretty neat little dude  :)  I "neutered" a couple of servos and rigged them up to drive it. I have a couple of sr04 ping sensors so I guess I'll build an obstacle avoiding robot. I just ran the servos directly off the pins (Not good, I know) but I have a motor shield.
I want to build a bot with the ping sensor mounted to a servo or either 2 sensors. Any advise?
Ufoguy
Here is a link that I found useful. http://www.akeric.com/blog/?p=1590
Also try searching Google for " ping scan robot ".
If you want to meet a beautiful nurse you must be patient.
oric_dan
Best thing is to use a separate battery to power the servos. I use
4-6 rechargeable NiMH AA-cells in series to power all of my robots.
Those cells have 2000-2500 mA-hr of energy and can run your robot
for several hours.
Also, in the Files -> Examples section of the Arduino IDE, there are
example sketches for controlling servos and PIng sonars, etc.
DuaneB
   I am seriously jealous of your chassis ! I built a paper shell for my robot thinking the kids might like it but there were completely dismissive of it. If I had had that chassis I would never get the thing back from them.
As for advice, if you have kids, try and mount the electronics underneath so that you can keep the original design on top.
Duane B
rcarduino.blogspot.com
Read this
http://rcarduino.blogspot.com/2012/04/servo-problems-with-arduino-part-1.html
then watch this
http://rcarduino.blogspot.com/2012/04/servo-problems-part-2-demonstration.html
Rcarduino.blogspot.com
hoff70
Well, here he is now:
There's room for 8 AA's and a small breadboard.
Thanks for the input guys!
Now to get him working  :) I have an Arduino motor shield and my sensor is an SR04 so the code is going to be different from a regular PING.
hoff70
Code: [Select]
//"Arduino Garage Tennis Ball."  A distance sensor with LED Stoplights for people with multiple vehicles going into a limited space.
#include <Servo.h> // includes library
Servo servoLeft;
Servo servoRight;
const int triggerPin = 8;
const int echoPin = 9;
int redPin=13;
int yellowPin=12;
int greenPin=11;
long duration;
long distance;
void setup(){
  servoLeft.attach(10);
  servoRight.attach(7);
  pinMode (13, OUTPUT);
  pinMode (12, OUTPUT);
  pinMode (11, OUTPUT);
  servoLeft.write(0);
  servoRight.write(180);
  int stopDistance=6;//object distance in inches from sensor that you want to trigger the Red LED.
  int warnDistance=60;//object distance in inches from sensor that you want to trigger the Yellow LED.
  pinMode(triggerPin, OUTPUT);
  digitalWrite(triggerPin, LOW);
  delayMicroseconds(2);
  digitalWrite(triggerPin, HIGH);
  delayMicroseconds(5);
  pinMode(echoPin, INPUT);
  duration = pulseIn(echoPin, HIGH);
  distance = duration / 72 / 2;//determines distance in inches of object from sensor by microseconds to inches formula.
  if (distance >= warnDistance){
    digitalWrite (redPin, LOW);
    digitalWrite (yellowPin, LOW);
    digitalWrite (greenPin, HIGH);
  else if((distance>stopDistance) && (distance<warnDistance)){
    digitalWrite (yellowPin, HIGH);
    digitalWrite (greenPin, LOW);
  else{
    digitalWrite (redPin, HIGH);
    servoLeft.write (0);
    delay (2000);
    servoRight.write (0);
    delay (2000);
  Serial.println (distance);
Here's what it does:
http://www.youtube.com/watch?v=WO_lZbVlgPM&feature=youtu.be
Any help on what I'm missing?
JimboZA
How do you mean, paper, Duane? Like paper mache?
Johannesburg hams call me: ZS6JMB on Highveld rep 145.7875 (-600 & 88.5 tone)
Dr Perry Cox: "Help me to help you, help me to help you...."
Your answer may already be here: https://forum.arduino.cc/index.php?topic=384198.0
hoff70
#7
Jun 17, 2012, 06:27 am Last Edit: Jun 17, 2012, 07:18 am by hoff70 Reason: 1
Code: [Select]
/*MAEP 2.0 Navigation
by Noah Moroze, aka GeneralGeek
This code has been released under a Attribution-NonCommercial-ShareAlike license, more info at http://creativecommons.org/licenses/
PING))) code by David A. Mellis and Tom Igoe http://www.arduino.cc/en/Tutorial/Ping
#include <Servo.h> //include Servo library
const int RForward = 0;
const int RBackward = 180;
const int LForward = RBackward;
const int LBackward = RForward;
const int RNeutral = 90;
const int LNeutral = 90; //constants for motor speed
const int echoPin = 9;  //Sharp infrared sensor pin
const int dangerThresh = 10; //threshold for obstacles (in cm)
int leftDistance, rightDistance; //distances on either side
Servo panMotor;
Servo leftMotor;
Servo rightMotor; //declare motors
long duration; //time it takes to recieve PING))) signal
long distance;
 rightMotor.attach(11);
 leftMotor.attach(10);
 panMotor.attach(6); //attach motors to proper pins
 panMotor.write(90); //set PING))) pan to center
 int distanceFwd = ping();
 if (distanceFwd>dangerThresh) //if path is clear
   leftMotor.write(LForward);
   rightMotor.write(RForward); //move forward
 else //if path is blocked
   leftMotor.write(LNeutral);
   rightMotor.write(RNeutral);
   panMotor.write(0);
   rightDistance = ping(); //scan to the right
   panMotor.write(180);
   delay(700);
   leftDistance = ping(); //scan to the left
   panMotor.write(90); //return to center
   delay(100);
   compareDistance();
void compareDistance()
 if (leftDistance>rightDistance) //if left is less obstructed
   leftMotor.write(LBackward);
   rightMotor.write(RForward); //turn left
 else if (rightDistance>leftDistance) //if right is less obstructed
   rightMotor.write(RBackward); //turn right
  else //if they are equally obstructed
   rightMotor.write(RBackward); //turn 180 degrees
long ping()
 // Send out PING))) signal pulse
 //Get duration it takes to receive echo
 //Convert duration into distance
 return duration / 29 / 2;
I'm trying to get serial output of what the sensor is seeing. It works with the first sketch I posted but I'm not having any luck with this...
This prints to the monitor when something gets close to the threshold:
Code: [Select]
Servo servoLeft;
Servo servoRight;
Servo servoScan;
///const int dangerThresh = 10; //threshold for obstacles (in cm)
long distance;
  servoLeft.attach(11);
  servoRight.attach(10);
  servoScan.attach(6); //attach motors to proper pins
  servoScan.write(90); //set PING))) pan to center
  ///int distanceFwd = ping();
  if (distance>dangerThresh) //if path is clear
    servoLeft.write(180);
    servoRight.write(0); //move forward
    servoLeft.write(90);
    servoRight.write(90);
    servoScan.write(0);
    servoScan.write(180);
    delay(700);
    servoScan.write(90); //return to center
    delay(100);
    compareDistance();
    servoRight.write(180); //turn left
    servoLeft.write(0);
    servoRight.write(0); //turn right
    servoLeft.write(0);
    servoRight.write(0); //turn 180 degrees
long ping()
  ////return duration / 29 / 2;
It's getting closer but he's still pretty spastic  :P
cyclegadget
#8
Jun 17, 2012, 07:10 am Last Edit: Jun 17, 2012, 07:12 am by cyclegadget Reason: 1
In this sketch, I think you need something like this:
Code: [Select]
distance =  ping();
I say this because I do not see where you are getting the latest value for distance. You define the variable distance before the set-up but, you never change it's value.
Currently, you are using the function ping() to = int distanceFwd .
In your previous sketch you did work with the variable distance:
Code: [Select]
Good links: Eagle tutorial= http://www.youtube.com/playlist?list=PLDE1858BD83D19C70
General Arduion tutorials = http://tronixstuff.wordpress.com
http://www.gammon.com.au/forum/bbshowpost.php?bbtopic_id=123
hoff70
Thanks! I edited my last post with some updated code. I'm slowly working my way through the different parts of the sketch to try and understand what is doing what.
Here's the original code:
Code: [Select]
const int pingPin = 7;
const int irPin = 0;  //Sharp infrared sensor pin
Servo panMotor;
Servo leftMotor;
    panMotor.write(0);
    delay(700);
    delay(100);
    compareDistance();
long ping()
  pinMode(pingPin, OUTPUT);
  digitalWrite(pingPin, LOW);
  digitalWrite(pingPin, HIGH);
  pinMode(pingPin, INPUT);
  duration = pulseIn(pingPin, HIGH);
Along with the project link: http://www.instructables.com/id/How-To-Make-an-Obstacle-Avoiding-Arduino-Robot/
DuaneB
#10
Jun 17, 2012, 08:10 am Last Edit: Jun 17, 2012, 08:16 am by DuaneB Reason: 1
Regarding the paper body shell, I made a few paper templates and ran them for a while before cutting a final version from plastic card. The plastic card version is reinforced in the joins using epoxy putty. It works well as a quick way to build a body.
Two other ideas I have seen are paper craft, these are printed nets that you can download, cut out and fold to get cars, tanks, planes, robots etc.
Another nice idea I have seen is cutting bodyshells from aluminium baking trays, same idea as paper nets, but these are easy to weather and dent for a post apocalyptic look.
Off topic - (only a little bit, why shouldn't our robots have decent bodyshells ?)
An example of some not quite post apocalyptic weathering on a plastic bodyshell of mine -
More here -
http://rcarduino.blogspot.com/p/cars.html
Duane B
Read this
then watch this
JimboZA
#11
Jun 17, 2012, 08:51 am Last Edit: Jun 17, 2012, 09:05 am by JimboZA Reason: 1
I do like the Baja Bug...
I found some paper nets- so far only London buses but Google will find more when I search properly. Thanks for that idea.
Edit...There are some nice nets here at Papertoys
Seems I need to pop down to the China Mall or whatever it's called today for a look around at toys. Basically an aircraft hangar sized mall with individual shops all selling cheap junk... might find a toy or two to use.
hoff70
#12
Jun 17, 2012, 07:30 pm Last Edit: Jun 17, 2012, 07:57 pm by hoff70 Reason: 1
Nice work on the baja!  I like the weathered look, in fact I thought I was looking at a real car  8)
I decided to give the copy/paste a rest. It's really confusing and I'm learning more by "writing" code than just tinkering with other peoples.
I'm just starting over here:
Code: [Select]
#include <Servo.h>
Servo servoLeft;          // Define left servo
Servo servoRight;         // Define right servo
Servo servoScan;          // Define US scan servo
 servoLeft.attach(10);  // Set left servo to digital pin 10
 servoRight.attach(9);  // Set right servo to pin 9
 servoScan.attach(11);  // Set scan servo to digital pin 11
void loop() {            // Loop through motion tests
 forward();             // Example: move forward
 delay(2000);           // Wait 2000 milliseconds (2 seconds)
 reverse();
 delay(2000);
 turnRight();
 delay(2000);
 turnLeft();
 delay(2000);
 stopRobot();
 delay(5000);
 ///scan
// Motion routines for forward, reverse, turns, and stop
void forward() {
 servoLeft.write(0);
void reverse() {
void turnRight() {
void turnLeft() {
 servoLeft.write(0);
void stopRobot() {
 servoRight.write(97);
 if (stopRobot) {
   servoScan.write(0);
I need to get the "scan" servo code more in line with the rest of the sketch and work on "if" "else" but I understand a lot more about what's happening now. I also had to regroup some on the hardware because 90 wasn't stopping one of my servo's. Weird that it took a value of 97... but it now stops. That was causing me some grief.
I added a longer delay for the STOP, plus 1 sec delays on the scanning servo but it seems like there is some kind of accumulation because it stops for 7 seconds. I'm guessing that the scan + motor delay is doing this?
I plan on just working towards:
Forward until obstacle- stop- scan R & L- print values- reverse.  Then work from there.
I have all the puzzle pieces, I just need to fit them together.
I'm a hobby machinist/weldor so I hope to take what I'm learning and scale it up to some type of yard rover.
Here he is:
http://www.youtube.com/watch?v=RyPL9w83QXs&feature=youtu.be
hoff70
Well, here he is:
http://www.youtube.com/watch?v=Sit6Zq13QN4&feature=youtu.be
Code: [Select]
const int RNeutral = 97;
const int pingPin = 12;
const int irPin = 13;  //Sharp infrared sensor pin
Servo panMotor;
Servo leftMotor;
    panMotor.write(0);
    delay(700);
    delay(100);
    compareDistance();
long ping()
  pinMode(irPin, INPUT);
  duration = pulseIn(irPin, HIGH);
The right motor is pin 11
The left motor is pin 10
the scanning servo is pin 6
the trig is pin 12
the echo is pin 13
I just powered the servo motors with a 5V regulator with a heat sink and the SR04 off the Arduino.
I guess I'll take him apart now. I really need several boards for tinkering...
cyclegadget
Nice job! It looks like the object avoidance is working. It might work a little quicker if it turned when backing-up. I have a similar Tamiya track set-up and I want it to work similar to yours someday.
Keep it up!
