Topic: Porting Jeelib for Attiny85 + RFM12B (Read 4221 times) previous topic - next topic
martin_bg
I am trying to get the Jeelib work for an Attiny85 with pinchange interrupts. See the schematic attached for the hardware part.
I have modified the RF12B.cpp in the following way:
I added a "always on" PINCHG_IRQ for ATTiny85
Code: [Select]
#if defined(__AVR_ATtiny85__) || defined(__AVR_ATtiny45__)
#define PINCHG_IRQ 1
#endif
I have added a section fot that MCU in the SPI defines:
Code: [Select]
#elif defined(__AVR_ATtiny85__) || defined(__AVR_ATtiny45__)
#define RFM_IRQ     4
#define SS_DDR      DDRB
#define SS_PORT     PORTB
#define SS_BIT      3
#define SPI_SS      3
#define SPI_MISO    0
#define SPI_MOSI    1
#define SPI_SCK     2
I have added a section in the
Code: [Select]
#if PINCHG_IRQ
        ISR(PCINT0_vect) { if (!bitRead(PINB, RFM_IRQ )) rf12_interrupt(); }
#else ......
I added a section in the rf12_initialize procedure as follows:
Code: [Select]
#if PINCHG_IRQ
        if ((nodeid & NODE_ID) != 0) {
            bitClear(DDRB, RFM_IRQ);      // input
            bitSet(PORTB, RFM_IRQ);       // pull-up
            bitSet(PCMSK, RFM_IRQ);      // pin-change
            bitSet(GIMSK, PCIE);         // enable
        } else
            bitClear(PCMSK, RFM_IRQ);
#else ...
Just to see if the thing is alive, I have a LED on the PB2, it flashes once then freezes, right when it is supposed to talk to the RFM12b..
Any help to get this working is appreciated
Schematic
The actual project on stripboard
http://forum.jeelabs.net/files/IMAG0219.jpg
The sketch
http://forum.jeelabs.net/files/test_rfm12b_0.ino
martmaiste
Hi Martin
Are you sure your MISO and MOSI pins/signals are not swapped?
Märt
