Topic: POV - Probleme mit Code (Read 863 times) previous topic - next topic
ICwiener
Hallo zusammen,
ich habe mir ein kleines POV gebaut. Leider habe ich etwas Probleme bei der Erweiterung des Codes von Michael Zöllner.
Das Problem ist folgendes:
Ich habe zusätzlich einen Tiltsensor verbaut. Leider bekomme ich es nicht hin, dass die Buchstaben immer in eine Richtung angezeigt werden. Je nach dem, wo man beim "Schütteln" ist, werden die Buchstaben spiegelverkehrt angezeigt. Vielleicht könnt ihr mir ja helfen.
Danke euch.
Code: [Select]
persistence of vision typography with arduino
michael zoellner - march 2006
http://i.document.m05.de
connect anodes (+) of 5 leds to digital ports of the arduino board
and put 20-50 ohm resistors from the cathode (-) to ground.
the letters are lookup tables consisting arrays width the dot status in y rows.
// defining the alphabet
int _[] = {0,0,0,0,0, 0,0,0,0,0, 0,0,0,0,0};
int A[] = {0,1,1,1,1, 1,0,1,0,0, 0,1,1,1,1};
int B[] = {1,1,1,1,1, 1,0,1,0,1, 0,1,0,1,0};
int C[] = {0,1,1,1,0, 1,0,0,0,1, 1,0,0,0,1};
int D[] = {1,1,1,1,1, 1,0,0,0,1, 0,1,1,1,0};
int E[] = {1,1,1,1,1, 1,0,1,0,1, 1,0,1,0,1};
int F[] = {1,1,1,1,1, 1,0,1,0,0, 1,0,1,0,0};
int G[] = {0,1,1,1,0, 1,0,1,0,1, 0,0,1,1,0};
int H[] = {1,1,1,1,1, 0,0,1,0,0, 1,1,1,1,1};
int I[] = {0,0,0,0,1, 1,0,1,1,1, 0,0,0,0,1};
int J[] = {1,0,0,0,0, 1,0,0,0,1, 1,1,1,1,1};
int K[] = {1,1,1,1,1, 0,0,1,0,0, 0,1,0,1,1};
int L[] = {1,1,1,1,1, 0,0,0,0,1, 0,0,0,0,1};
int M[] = {1,1,1,1,1, 0,1,1,0,0, 0,1,1,1,1};
int N[] = {1,1,1,1,1, 1,0,0,0,0, 0,1,1,1,1};
int O[] = {0,1,1,1,0, 1,0,0,0,1, 0,1,1,1,0};
int P[] = {1,1,1,1,1, 1,0,1,0,0, 0,1,0,0,0};
int Q[] = {0,1,1,1,1, 1,0,0,1,1, 0,1,1,1,1};
int R[] = {1,1,1,1,1, 1,0,1,0,0, 0,1,0,1,1};
int S[] = {0,1,0,0,1, 1,0,1,0,1, 1,0,0,1,0};
int T[] = {1,0,0,0,0, 1,1,1,1,1, 1,0,0,0,0};
int U[] = {1,1,1,1,1, 0,0,0,0,1, 1,1,1,1,1};
int V[] = {1,1,1,1,0, 0,0,0,0,1, 1,1,1,1,0};
int W[] = {1,1,1,1,0, 0,0,1,1,0, 1,1,1,1,0};
int X[] = {1,1,0,1,1, 0,0,1,0,0, 1,1,0,1,1};
int Y[] = {1,1,0,0,0, 0,0,1,0,0, 1,1,1,1,1};
int Z[] = {1,0,0,1,1, 1,0,1,0,1, 1,1,0,0,1};
int letterSpace;
int dotTime;
int richtung = 0;
  // setting the ports of the leds to OUTPUT
  pinMode(9, OUTPUT);
  pinMode(10, OUTPUT);
  pinMode(11, OUTPUT);
  pinMode(12, OUTPUT);
  pinMode(13, OUTPUT);
  pinMode(2, INPUT);
  // defining the space between the letters (ms)
  letterSpace = 12;
  // defining the time dots appear (ms)
  dotTime = 6;
void printLetter(int letter[])
  richtung = digitalRead(2);
  if (richtung == HIGH) {
  int y;
  // printing the first y row of the letter
  for (y=0; y<5; y++)
    digitalWrite(y+9, letter[y]);
  delay(dotTime);
  // printing the second y row of the letter
  for (y=0; y<5; y++)
    digitalWrite(y+9, letter[y+5]);
  delay(dotTime);
  // printing the third y row of the letter
  for (y=0; y<5; y++)
    digitalWrite(y+9, letter[y+10]);
  delay(dotTime);
  // printing the sspace between the letters
  for (y=0; y<5; y++)
    digitalWrite(y+9, 0);
  delay(letterSpace);
int y;
  for (y=0; y<5; y++)
  delay(dotTime);
  for (y=4; y>-1; y--)
  delay(dotTime);
  delay(dotTime);
  delay(letterSpace);
  // printing some letters
  printLetter(_);
  printLetter(_);
  printLetter(Z);
  printLetter(_);
  printLetter(_);
  printLetter(_);
