Topic: Help interfacing Parallax altimeter MS5607 and Arduino using SPI (Read 3373 times) previous topic - next topic
danidub
Hello, I recently buy a Altimeter Module MS5607 (http://www.parallax.com/Store/Sensors/AccelerationTilt/tabid/172/ProductID/780/List/0/Default.aspx?SortField=ProductName,ProductName) and I need to interface it with my Arduino UNO with SPI protocol.
In the Parallax site there is a I2C example (http://www.parallax.com/Portals/0/Downloads/docs/prod/sens/29124-AltimeterModule-v1.0.pdf) but I need to work in SPI mode.
I'm still trying and I made this code, that when a "0" is recieved in the serial, the arduino sends the conversion and read commands to the altimeter and stores the 24 bit data of the altitude. Till now, I get the data in three bytes, but for some reason I only get 3 bytes of 11111111, 11111111, 11111111.
I post the code:
Code: [Select]
Circuit:
SCK: pin 13
MISO: pin 12
MOSI: pin 11
SS: pin 9
const int ss = 9;
#include <SPI.h>
//3 bytes to get the 24 bit adc read
byte byte1;
byte byte2;
byte byte3;
 SPI.begin();
 SPI.setBitOrder(MSBFIRST);
 pinMode(ss, OUTPUT);
 if (Serial.available() > 0) {
   byte incomingByte = Serial.read();
   switch (incomingByte){
   case '0':
     read_alt();
   } //endswitch
 }//enif
}//endloop
void read_alt()
 //READ Altimeter
 digitalWrite(ss, LOW);
 SPI.transfer(0x50); //ADC conversion command
 delay(1);
 // and store read data into three bytes
 byte1 = SPI.transfer(0x00);//ADC conversion read command, first 8 bits
 byte2 = SPI.transfer(0x00);//ADC conversion read command, second 8 bits
 byte3 = SPI.transfer(0x00);//ADC conversion read command, third 8 bits
 //print the 3 bytes in serial
 Serial.println(byte1, BIN);
 Serial.println(byte2, BIN);
 Serial.println(byte3, BIN);
 //release chip, signal end transfer
 digitalWrite(ss, HIGH);
el_supremo
When using SPI, you must either use pin 10 as the chip select or, at the very least, you must configure it as an output. Otherwise the SPI library will start up in slave mode instead of master.
So if you want to keep using Pin 9 as chip select, you must also add this statement in your setup function even though you don't use pin 10:
Code: [Select]
pinMode(10, OUTPUT);
Or you can wire up CS to pin 10 and then just change "const int ss = 9;" to "const int ss = 10;"
The other thing to make sure of is that you have MOSI and MISO wired to the correct pins on the device.
In the case of the altimeter, I presume that SDA should be wired to MOSI, SDO goes to MISO.
Pete
Don't send me technical questions via Private Message.
danidub
Hello Pete, first of all thank you for answering, I check the MISO and MOSI and they are ok, and include the "pinMode(10, OUTPUT);" in my setup(); but no success on the bytes recieved, I'm still getting 11111111, 11111111, 11111111. Any ideas?
The way to recieve 24 bits in SPI is correct in the code?
On page 9 and 10 of the datasheet is the read and conversion sequence (http://www.amsys.de/sheets/amsys.de.ms5607b.pdf)
Thank you again,
Daniel
el_supremo
It does look like it should work.
I would put "digitalWrite(ss, HIGH);" immediately after you've read byte3, but that shouldn't make any difference. The fact you are getting all ones means that the MS5607 isn't seeing you set the chip select.
Oh, the "pinMode(10, OUTPUT);" must be before "SPI.begin();".
Other than that, I can only suggest you check the wiring again :-)
Pete
danidub
Hello Pete, I've made those changes but no success, still getting the 11111111, 11111111, 11111111  :~
Here is the new code:
Code: [Select]
Circuit:
SCK: pin 13
MISO: pin 12
MOSI: pin 11
SS: pin 10
const int ss = 10;
#include <SPI.h>
byte byte1;
byte byte2;
byte byte3;
  SPI.begin();
    case '0':
      read_alt();
    } //endswitch
  }//enif
}//endloop
void read_alt()
  //READ Altimeter
  delay(1);
