Topic: Looking for some help to find (hardware) components from schematic... (Read 1 time) previous topic - next topic
xl97
:smiley-red:
hey gang-
I have a schematic/board layout that I am trying to piece together my BOM for...
1.) is a 100uF Tantalum capacitor (from adafruit library).. it is a C3225 package..
I cant seem to find these @ Digikey/Mouser..etc..     (but Im new to all this sourcing/building still)  ;)
These.. I believe I may have found..etc  but Id like a second set of eyes if any are available. :)
project calls for a
** (D1) DIODE: DO-214AC    (best I could find were these)
correct match found?
Part#: ES1D-E3/61T
a.   ES1D-E3/61TGICT-ND:   http://www.digikey.com/product-detail/en/ES1D-E3%2F61T/ES1D-E3%2F61TGICT-ND/1091571
b.   ES1D-TPCT-ND:    http://www.digikey.com/product-detail/en/ES1D-TP/ES1D-TPCT-ND/950612
(not sure of the difference?  results from searching it myself)
** DAC: MICROCHIP_MCP4921_SO-08 (SOIC8 package) of the Adafruit WaveShield DAC (not DIP, not MSOP, super tiny)
Part#: MCP4921-E/SN
URL: http://www.digikey.com/product-detail/en/MCP4921-E%2FSN
** BUFFER: 74AHC125D (SO14 package)
Part#: 74AHC125D,118
URL: http://www.digikey.com/product-detail/en/74AHC125D,118
I have attached the BOM I am working on.. (excel).. that I am putting together based on the part list export from EAGLE.
Thanks!   :)
-xl
oric_dan
I found the cap at mouser.
http://www.mouser.com/search/ProductDetail.aspx?qs=cdpe0LUyr8DJh2HwLQKWjQ==
If that doesn't work, it's down this path:
All Products » Passive Components » Capacitors » Ceramic Capacitors » Multilayer Ceramic Capacitors (MLCC) - SMD/SMT » C3225C0G2A153JT
The DO-214 is the diode "package" type, not the part#. You need the correct p/n.
Ddifferent diode package types have different lengths and wire-lead diameters.
On the others, whenever you see "SOxx", it means SOIC package type. The pins have
1/2 the normal spacing [0.05"], and are 1000X easier to solder than smaller smt
package types, like QFN/etc. SOIC8 is 8-pin, SOIC14 is 14-pin. Easy code.
xl97
hi-  :)
thanks for reply..
the cap is a TANTALUM cap Im looking for.. ;)
*is a 100uF Tantalum capacitor (from adafruit library).. it is a C3225 package..
I'll check on the DIODE info again..  (thanks)..
for everything else.. I 'think' I have the correct part picked out to match the 'part list' from Eagle..  ;)
thanks!
Docedison
Your capacitor is either a "C" package or a 3225 package, not really both, thats likely the issue you had in finding the part. The diode is a high speed type usually used in switching regulators as the 'catch' diode, it should work UNLESS the design calls for schottky diodes ( junction and point contact diodes have different conduction potentials) If it does, use them as the designer had a reason for calling out that part. Substitutions are ok... if you know why, then you know as much as the designer did and you wouldn't be asking questions... <BG>
Doc
--> WA7EMS <--
"The solution of every problem is another problem." -Johann Wolfgang von Goethe
I do answer technical questions PM'd to me with whatever is in my clipboard
xl97
Thanks!!..   :)
the 'cap' is being used on the speaker+ pad from the audio/amp..etc
does that help?
and for the diode.. I guess I have the wrong one picked.. it should be a schottky type..
couldnt find anything in the size I could be sure of (or anything) at Digikey..,but I think maybe this one will work from Mouser for the DIODE: (pad size/package DO-214AC)
http://www.mouser.com/ProductDetail/Bourns/CD214A-B120LF/?qs=VNGG2InBe5G0GFyCwvnjRA%3d%3d
datasheet: http://www.bourns.com/data/global/pdfs/CD214-B120_B1100.PDF
yes?
thanks  :smiley-mr-green:
