Ok now I understand you are trying to control a wind or solar power installation. I fail to see where you need to block anything with that device. I would connect it EXACTLY as the Mfr suggests and leave it alone, if your connections aren't correct you could do a lot of damage. Be Very careful with anything that connects and or supplies power back... That Circuit breaker that is inline is a pretty big one. Lots of AMPS available. I do know why a diode is used with a PV system but that simply prevents the solar cells from discharging the battery, usually it is a schottky diode rated at about 4 X the available charge current from the PV panels.
Doc
