Topic: Serial monitor: bug in Arduino 1.0.1 (Read 4318 times) previous topic - next topic
leo72
I think there's a bug in the serial monitor.
If you try a simple sketch like this:
Code: [Select]
  delay(2000);
  Serial.begin(19200);
  Serial.println("Hello");
If you open the serial monitor and you have a baud rate different than the speed that you set into the sketch (i.e. 9600 bps), trying to change the baud speed will generate a Java error:
Code: [Select]
Experimental:  JNI_OnLoad called.
Stable Library
Native lib Version = RXTX-2.1-7
Java lib Version   = RXTX-2.1-7
Exception in thread "AWT-EventQueue-0" java.lang.StringIndexOutOfBoundsException: String index out of range: -1
at java.lang.String.substring(String.java:1958)
at processing.app.SerialMonitor$6.actionPerformed(SerialMonitor.java:137)
at javax.swing.JComboBox.fireActionEvent(JComboBox.java:1260)
at javax.swing.JComboBox.setSelectedItem(JComboBox.java:588)
at javax.swing.JComboBox.setSelectedIndex(JComboBox.java:624)
at javax.swing.plaf.basic.BasicComboPopup$Handler.mouseReleased(BasicComboPopup.java:835)
at java.awt.AWTEventMulticaster.mouseReleased(AWTEventMulticaster.java:290)
at java.awt.Component.processMouseEvent(Component.java:6505)
at javax.swing.JComponent.processMouseEvent(JComponent.java:3312)
at javax.swing.plaf.basic.BasicComboPopup$1.processMouseEvent(BasicComboPopup.java:499)
at java.awt.Component.processEvent(Component.java:6270)
at java.awt.Container.processEvent(Container.java:2229)
at java.awt.Component.dispatchEventImpl(Component.java:4861)
at java.awt.Container.dispatchEventImpl(Container.java:2287)
at java.awt.Component.dispatchEvent(Component.java:4687)
at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4832)
at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4492)
at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4422)
at java.awt.Container.dispatchEventImpl(Container.java:2273)
at java.awt.Window.dispatchEventImpl(Window.java:2719)
at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:703)
at java.awt.EventQueue.access$000(EventQueue.java:102)
at java.awt.EventQueue$3.run(EventQueue.java:662)
at java.awt.EventQueue$3.run(EventQueue.java:660)
at java.security.AccessController.doPrivileged(Native Method)
at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76)
at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:87)
at java.awt.EventQueue$4.run(EventQueue.java:676)
at java.awt.EventQueue$4.run(EventQueue.java:674)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:673)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:244)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:163)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:151)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:147)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:139)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:97)
(message kept under Arch Linux)
This happens with Linux and Windows versions of Arduino IDE.
The same operation can be done without issues with Arduino 0022.
dalubar
ratto93
Same for me under Windows 7
+1
Same for me under Windows xp sp1, sp2 and Windows 7
Se corri veloce come un fulmine, ti schianterai come un tuono.
dxw00d
pictux
No problem also for me, on Linux Debian.
lestofante
the rror is here, SerialMonitor.java:
Code: [Select]
serialRates.addActionListener(new ActionListener() {
     public void actionPerformed(ActionEvent event) {
       String wholeString = (String) serialRates.getSelectedItem();
       String rateString = wholeString.substring(0, wholeString.indexOf(' '));
       serialRate = Integer.parseInt(rateString);
       Preferences.set("serial.debug_rate", rateString);
       closeSerialPort();
       try {
         openSerialPort();
       } catch (SerialException e) {
         System.err.println(e);
can you change it to
Code: [Select]
System.out.println("serialRates: "+(String) serialRates.getSelectedItem());
       System.out.println("wholeString: "+wholeString);
       System.out.println("wholeString: "+rateString);
       closeSerialPort();
       try {
         openSerialPort();
and tell me what appen? i can't reproduce the error!
Guida per principianti http://playground.arduino.cc/Italiano/newbie
Unoffical Telegram group https://t.me/genuino
leo72
I'm not able to recompile the IDE (no Java experience).
Federico_Vanzati
If you want to recompile the Arduino IDE under Linux, it's quite easy and doesn't need Java experience. The steps you must follow are:
1) Download from Github the souce code of the Arduino IDE
2) Make sure that on your linux box "apache ant" is installed, if not install it.
3) Apply your modification to the code
4) When you are ready to compile the IDE open a shell, move to the dir ".../Arduino/build" and type:
Code: [Select]
ant; ant clean; ant build
5) The build process will start and after it finishes you can launch the IDE using the command "ant run" or moving to the directory that the build process has generated: ".../Arduino/build/linux/work" and launch the IDE as usually.
F
lestofante
i want to let you know that EVERY arduino 1.0.1 is afflicted by this problem, and i've open an issue with the solution:
http://code.google.com/p/arduino/issues/detail?id=964&can=6&sort=-id
testato
- [Guida] IDE - http://goo.gl/ln6glr
- [Lib] ST7032i LCD I2C - http://goo.gl/GNojT6
- [Lib] PCF8574+HD44780 LCD I2C - http://goo.gl/r7CstH
leo72
