Topic: Servo language question (Read 6779 times) previous topic - next topic
bren21m
ohh, well is that how my switch workss?
bren21m
i want the program on the arduino to say, when positiion 1 on the switch gets a signal in whatever pin it goes in on the arduino to make the delay this many milliseconds and so on. does anyone know what pins should be used for the switch i got?
zoomkat
Two servo test code that can be modified to position a single servo in several different positions depending on the switch position.
Code: [Select]
//zoomkat servo button test 12-29-2011
#include <Servo.h>
int button1 = 4; //button pin, connect to ground to move servo
int press1 = 0;
int button2 = 5; //button pin, connect to ground to move servo
int press2 = 0;
Servo servo1;
  pinMode(button1, INPUT);
  pinMode(button2, INPUT);
  servo1.attach(7);
  digitalWrite(4, HIGH); //enable pullups to make pin high
  digitalWrite(5, HIGH); //enable pullups to make pin high
  press1 = digitalRead(button1);
  if (press1 == LOW)
    servo1.write(170);
  press2 = digitalRead(button2);
  if (press2 == LOW)
    servo1.write(10);
  /*else {
    servo1.write(90);
Google forum search: Use Google Search box in upper right side of this page.
Why I like my 2005 Rio Yellow Honda S2000  https://www.youtube.com/watch?v=pWjMvrkUqX0
bren21m
that wouldn't adjust the delay for each switch postion would it? or i would have to chanfe it to do that?
bren21m
would a video explaining help? im a beginner so if you guys already put it in black and white please show me. i have no idea where to start, im not impatient its just people are annoying me to finish it, so id like toget it done soon. thanks
zoomkat
Quote
Sounds like a school assignment. So what have you tried on your own since your last post on July 19?
bren21m
i tried to see if i could find anything like a diagram or somthing on google showing how to connect the switch to the arduino but i couldnt find anything. i also looked to see if anyone did Anything similar to what im doing but i couldnt find anything i also made this video a few day ago scince i dont have my gopro at the moment.
http://www.youtube.com/watch?v=cx04r9GtnbU
i know it can be a whole lot better.  but thats just the way i am with everything. its also ok for my first video like that.
PeterH
What the bleep has that video got to do with your question?
zoomkat
It is what you do while waiting for somebody to do your homework for you.  :)
bren21m
lol, no i made that video the other day because the camera im making this wiper for is getting fixed. and it not my home work, my dad is nagging my to make it and all these people want me to make them it. they think i can just turn it out. like no i have no idea where to start i used a code that came with the program. this is the camera i use the wiper on. its a gopro
http://www.youtube.com/watch?v=ChzVGV9FtX0&feature=relmfu
you can see the wiper go like every 8 or 10 seconds i forget what i set it too
if you think a video would help ill make one.
and im only 16 so i wouldnt have a class that would expect me to build somthing like this and it is summer.
bren21m
Code: [Select]
#include <Servo.h>
int press1 = 0;
int press2 = 0;
Servo servo1;
  servo1.attach(7);
  if (press1 == LOW)
    servo1.write(170);
  if (press2 == LOW)
    servo1.write(10);
  /*else {
    servo1.write(90);
im pretty sure this would work its just i dont know how and where to insert it into my code to make it not change the position of the servo but change the delays and what pins on the arduino to connect the the pins on the switch
also can i just solder the servo positive to the positive on the switch to one pin and put that pin in the 5v on the arduino or would i need to get one of those breadboards that are like white plastic
bren21m
i made this video a while back then just stopped caring about gettingthe wiper done because race season was over, but now its possible we are going to have a race in mid febuary so i figured i would get it done now, i hope this clearly explains my question
http://www.youtube.com/watch?v=2IrCplYeUZw&feature=youtu.be
i know i sound like a dweeb, i was sick.
